* Makefile.am: Build file IO related tests even with POSIX threading is
disabled.
* configure.ac: Don't add -fasm to CFLAGS.
* block01/.cvsignore: New file.
* aclocal/check-custom-bsp.m4: Fix up AC_REQUIRES.
* aclocal/canonical-target-name.m4: Remove RTEMS_HOST (unused).
* sp32/init.c: Lengthen the clock tick and move configuration to the
bottom of the file.
* psxtimer01/psxtimer.c: It is not necessarily an error for the time
remaining to not equal the period.
* tmck/task1.c: Ignore numbers that are too large but keep going -- do
not abort.
* unlimited/test1.c: Spacing.
* tmck/task1.c: Remove support for "unix".
Remove posix/unix simulator.
* cpuuse/init.c, cpuuse/system.h: Use minimum stack size.
* psx05/init.c, psx05/psx05.scn: Add test for bad mutex type.
* psxcleanup/system.h: Fix typo.
* Makefile.am, configure.ac: Add new test for exercising pushing
and popping a clean up handler without actually executing it.
* psxcleanup01/.cvsignore, psxcleanup01/Makefile.am,
psxcleanup01/init.c, psxcleanup01/psxcleanup01.doc,
psxcleanup01/psxcleanup01.scn: New files.
* Makefile.am, configure.ac: Add new test to ensure that canceling an
alarm works as defined.
* psxalarm01/.cvsignore, psxalarm01/Makefile.am, psxalarm01/init.c,
psxalarm01/psxalarm01.doc, psxalarm01/psxalarm01.scn: New files.
* psxtimer01/psxtimer.c: Actually pass the pointer we initialized.
* psxtimer01/psxtimer.c: Make sure we have null and not-null as return
parameter to timer_settime().
* psxtimer01/psxtimer.c: Modify so it passes in a NULL to
timer_settime() for previous value. We are not using the
value in this particular case and this path must be exercised.
* psxtimer01/psxtimer01.scn: Update so it matches output on sis.
* Makefile.am, configure.ac: Add new test to exercise when the ticks
since boot wraps around 0 and the timer server must deal with that
condition.
* sp67/.cvsignore, sp67/Makefile.am, sp67/init.c, sp67/sp67.doc,
sp67/sp67.scn: New files.
* sp40/init.c, sp40/sp40.doc, sp40/sp40.scn: New test cases.
* spintrcritical09/init.c, spintrcritical10/init.c,
spintrcritical11/init.c: Fixed potentially infinite loops.
* sptests/spintrcritical09/init.c, sptests/spintrcritical10/init.c,
sptests/spintrcritical11/init.c: Fixed potentially infinite loops.
* sp20/system.h: Increased micro seconds per tick in order to be more
independent of the console output speed.
* sp07/init.c, sp07/sp07.scn, sp09/init.c, sp09/screen01.c,
sp09/sp09.scn, sp28/init.c, sp62/init.c, sp62/sp62.scn, sp64/init.c,
sp64/sp64.scn: Add more test cases highlighted on SPARC at -O2, x86
at -Os and m68k at -Os. Fix typos.
* sp54/init.c: Use rtems_build_id to make building Objects_Id
RTEMS_USE_16_BIT_OBJECT clean.
* hello/init.c: Remove call to devFS_Show() which had accidentally
gotten committed.
* Makefile.am, configure.ac, termios01/termios_testdriver.c: Do not use
CONSOLE_USE_INTERRUPTS. That is in use by BSPs and we should not use
it.
* termios02/.cvsignore, termios02/Makefile.am, termios02/init.c,
termios02/termios02.doc, termios02/termios02.scn: New files.
termios02 is a test for tcdrain().
* termios01/init.c, termios01/termios_testdriver.c:
Reflect changes to termios.
* Makefile.am, configure.ac: Add new test to exercise when notepads are
not configured.
* spnotepad01/.cvsignore, spnotepad01/Makefile.am, spnotepad01/init.c,
spnotepad01/spnotepad01.doc, spnotepad01/spnotepad01.scn: New files.
* psxcancel/init.c, psxcancel/psxcancel.scn, psxcancel01/init.c,
psxcancel01/psxcancel01.scn: Add missing pthread cancellation test
cases.
* Makefile.am, configure.ac: Add new test for calling pthread_cancel()
from an ISR.
* psxcancel01/.cvsignore, psxcancel01/Makefile.am, psxcancel01/init.c,
psxcancel01/psxcancel01.doc, psxcancel01/psxcancel01.scn: New files.
* sp09/screen01.c, sp09/screen02.c, sp09/screen03.c, sp09/screen05.c,
sp09/screen09.c, sp09/screen14.c, sp09/sp09.scn, sp28/init.c,
sp28/sp28.scn, sp43/init.c: Add more error cases uncovered by uC5282
coverage runs.
* sp09/screen02.c, sp09/screen04.c, sp09/screen07.c, sp09/screen09.c,
sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/sp09.scn: Add
some error cases uncovered by uC5282 coverage runs.
* sp33/init.c, sp33/sp33.scn: Add some barrier error cases uncovered by
* sp59/init.c, spintrcritical15/init.c, spintrcritical16/init.c:
Correct minor issues uncovered on uC5282.
* psxfatal_support/init.c, psxfatal_support/system.h: Eliminate use of
deprecated rtems_extension.
* sp04/tswitch.c, sp07/system.h, sp07/taskexit.c, sp07/tdelete.c,
sp07/tstart.c, spfatal_support/init.c, spfatal_support/system.h:
Eliminate use of deprecated rtems_extension.
* cpuuse/tswitch.c: Eliminate use of deprecated rtems_extension.
* sp14/asr.c, sp14/sp14.doc, sp14/task1.c, sp14/task2.c: Adjust test to
run when IO speed varies.
* stackchk01/stackchk01.doc: Add content.
* Makefile.am, configure.ac: Add initial test for
rtems_stack_checker_is_blown.
* stackchk01/.cvsignore, stackchk01/Makefile.am, stackchk01/init.c,
stackchk01/stackchk01.doc, stackchk01/stackchk01.scn: New files.
* psxclock/init.c, psxclock/psxclock.scn: Add test case for negative
nanoseconds.
* psxsysconf/init.c, psxsysconf/psxsysconf.scn: Add test for
getpagesize().
* sp43/init.c, sp43/sp43.scn: Minor correction to test case so it hits
the intended code.
* configure.ac: Revert accidentally committed lines.
* Makefile.am, configure.ac, sp65/init.c: Add new test to exercise very
simple priority ceiling case that was previously only tested via the
POSIX API.
* sp66/.cvsignore, sp66/Makefile.am, sp66/init.c, sp66/sp66.doc,
sp66/sp66.scn: New files.
