An invalid heap usage such as a double free is usually a fatal error
since this indicates a use after free. Replace the use of printk() in
free() with a fatal error.
Update #3437.
Add RTEMS_FATAL_SOURCE_PANIC to rtems_fatal_source_text().
Update #3244.
Avoid resource allocation problems with unlimited objects.
_Timespec_Equal_to() does not set errno, hence avoid using perror(),
instead use fprintf() to stderr, and extend the error message to provide
information about what the error is (measured timer value after
re-arming is not equal to the configured interval), and how large of a
difference was measured.
Signed-off-by: Martin Erik Werner <martin.werner@aacmicrotec.com>
This configuration define is not supported.
Update #3358.
Update #3358.
Move FTP client filesystem to separate library libftpfs.a.
Update #3419.
Always build remote TCP support since it depends only on the POSIX
socket API. It works with the legacy network stack and libbsd. Move it
to a separate libdebugger.a library to allow an easy use with libbsd via
"-ldebugger -lbsd" otherwise we would have a cyclic dependency between
libbsd.a and librtemscpu.a.
Update #3419.
Remove shell script variant.
Close #3418.
Update #3409.
Update #3285.
It tests the (never really working) strict order mutex option. That
option does not exist any more. Mutexes by other good means (spmutex01,
spsem*).
Update #3406.
Somehow it does not work. With this Automake option you get:
gmake[6]: Entering directory '/build/sparc-rtems5/c/erc32/testsuites/ada/sptests'
Making all-am in sp01
gmake[7]: Entering directory '/build/sparc-rtems5/c/erc32/testsuites/ada/sptests/sp01'
gmake[7]: *** No rule to make target 'init.o', needed by 'ada_sp01.exe'. Stop.
Update #3387.
Update #3285.
This test loads a RAP format file that contains calls that are not
in the kernel and linked from libm. It uses and test rtems-ld.
Update #2769
Update #3254.
upgrade to that version.
Close #3387.
Also generate an error if the architecure does not match the --target
architecture given to configure's command line.
Close #2641.
Add tests to check the patches for this ticket exist and are fixed.
Close #3089
Update #3382.
Leave the parallel support so each test group builds in parallel.
Update #3382
Update #3382
Update #3382
Update #3382
Update #3382
Update #3382
Update #3382
Update #3382
Update #3382
Update #3382
Update #3382
Update #3382
The autoconf function checks the state of a test for the BSP and
controls the building of the test.
This change is part of the testsuite Makefile.am reorganisation.
Update #3382
Update #3325.
Do not use fprintf() in non-fp tasks.
Close #3320.
