* sp69/init.c: Use "ld" instead of PRId32 to print
struct timespec->tv_nsec.
* support/include/tmacros.h: Remove PRIxblksize_t, PRIxblkcnt_t.
* include/pmacros.h: Add PRIxblksize_t, PRIxblkcnt_t.
* configure.ac: Add AC_CHECK_SIZEOF([blksize_t]),
AC_CHECK_SIZEOF([blkcnt_t]).
* sp19/inttest.h: Use PRIx32 instead of "lx".
* sp04/tswitch.c: Shrink memory requirements.
* cpuuse/tswitch.c: Shrink memory requirements.
* math/math.scn, mathf/mathf.scn, mathl/mathl.scn: Regenerate.
* Makefile.am, configure.ac: Add mathf/, mathl/.
* math/init.c, math/Makefile.am: Reflect having split-out
mathl and mathf.
* math/domathf.c, math/domathl.c: Remove.
* mathf/Makefile.am, mathf/domathf.c, mathf/init.c,
mathf/mathf.scn: New (Split out from math/).
* mathl/Makefile.am, mathf/domathl.c, mathl/init.c,
mathl/mathl.scn: New (Split out from math/).
* math/init.c, complex/init.c:
Use fprintf(stdout,..) instead of printf.
Use CONFIGURE_APPLICATION_DISABLE_FILESYSTEM.
* POSIX/clock_gettime.c, POSIX/gettimeofday.c: New.
* POSIX/Makefile.am: Add clock_gettime, gettimeofday.c.
* Makefile.am: Add clock_gettime, gettimeofday.c.
PR 1661/testing
* termios06/init.c: Extend the test to cover sections related to
flow control in termios.c
* termios06/termios06.doc: Updated test concept
* termios06/termios06.scn: Updated test run log
* Makefile.am, configure.ac: Add psxaio03/.
* psxaio03/Makefile.am, psxaio03/init.c, psxaio03/psxaio03.scn
psxaio03/system.h: New.
* math/domath.in: Fix typo in printf.
* math/domath.c, math/domathf.c, math/domathl.c: Regenerate.
* math/math.scn: Regenerate.
* configure.ac: Use ac_cv_header_complex_h.
* psxaio02/init.c: Improve aio_cancel() coverage.
* psx05/init.c: Spacing.
* math/Makefile.am, math/init.c: Init task has to be floating point and
there is no point in using optional manager stubs since libio needs
semaphores.
* loopback/init.c: Loop back interface will be initialized now during
normal initialization via rtems_bsdnet_initialize_network().
* configure.ac: Add initial small set of POSIX Timing Tests.
* README: Add initial small set of POSIX Timing Tests.
* .cvsignore, ChangeLog, Makefile.am, README, configure.ac,
psxtmtests_plan.csv, psxtmmutex02/.cvsignore,
psxtmmutex02/Makefile.am, psxtmmutex02/init.c,
psxtmmutex02/psxtmmutex02.doc, psxtmthread01/.cvsignore,
psxtmthread01/Makefile.am, psxtmthread01/init.c,
psxtmthread01/psxtmthread01.doc, psxtmthread03/.cvsignore,
psxtmthread03/Makefile.am, psxtmthread03/init.c,
psxtmthread03/psxtmthread03.doc: New files.
* configure.ac: Check for complex.h.
Add AM_CONDITIONAL(HAS_COMPLEX) to allow building with outdated
toolchains.
* complex/Makefile.am: Apply HAS_COMPLEX.
* Makefile.am: Add complex, math subdirs.
* configure.ac: Add complex, math subdirs.
* complex/Makefile.am, complex/init.c, complex/docomplex.c,
complex/docomplexf.c, complex/complex.scn, complex/docomplex.in,
complex/complex.doc, complex/docomplexl.c: New.
* math/Makefile.am, math/init.c, math/domath.c,
math/domathf.c, math/math.scn, math/domath.in,
math/math.doc, math/domathl.c: New.
* spchain/init.c: Added test case.
* tm26/task1.c, tm27/task1.c: Update for API changes.
* spchain/init.c, spchain/spchain.scn: More test cases.
PR 1647/cpukit
* tm26/task1.c, tm27/task1.c: Update documentation to reflect
refactoring of SuperCore to add Scheduler Handler.
PR 1647/cpukit
* spsize/size.c: Update documentation to reflect refactoring of
* sp70/init.c, sp70/sp70.scn: Fix bug in test which lead to random
memory corruption.
* psxaio01/init.c, psxaio02/init.c: Improve coverage.
* spchain/init.c: Attempt to improve coverage.
* spchain/init.c, spwatchdog/task1.c: Do not violate chain API.
* tm26/task1.c, tm27/task1.c: Do not violate chain API.
* psx05/init.c: Check for correct status returned.
* psxrwlock01/psxrwlock01.scn, psxrwlock01/test.c: Add test code
to exercise path when attempting to lock for reading but there
is at least one writer blocked waiting for access.
* Makefile.am, configure.ac: New test to ensure pthread_cond_wait() and
sleep() (e.g. interruptible blocking and sleeping) are interruptible
by signal.
* psxsignal06/.cvsignore, psxsignal06/Makefile.am, psxsignal06/init.c,
psxsignal06/psxsignal06.doc, psxsignal06/psxsignal06.scn: New files.
* psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c,
psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c,
psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c,
psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c,
psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c,
psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c,
psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c,
psxcancel01/init.c, psxchroot01/test.c, psxitimer/init.c,
psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c,
psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c,
psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c,
psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c,
psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c,
psxstack01/init.c, psxstack02/init.c, psxualarm/init.c: Eliminate
double space after parenthesis on rtems_test_assert().
* psx07/init.c: Add HAVE_DECL_PTHREAD_ATTR_SETGUARDSIZE guard around
guardsize.
guardsize.
* psxhdrs/pthread37.c, psxhdrs/pthread38.c, psxhdrs/pthread39.c,
psxhdrs/pthread40.c: New files.
