tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am,
tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am,
tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am,
tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am,
tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am,
tmoverhd/Makefile.am: Remove SRC, PRINT_SRC.
mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Remove SRC,
PRINT_SRC.
psx13/Makefile.am, psxcancel/Makefile.am, psxchroot01/Makefile.am,
psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am,
psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am,
psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am:
* itrontests.am: Add $(PGM): ${ARCH}/$(dirstamp).
* itronhello/Makefile.am, itronmbf01/Makefile.am,
itronmbox01/Makefile.am, itronsem01/Makefile.am,
itrontask01/Makefile.am, itrontask02/Makefile.am,
itrontask03/Makefile.am, itrontask04/Makefile.am,
itrontime01/Makefile.am:
Partial conversion to automake.
putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am,
stackchk/Makefile.am, termios/Makefile.am: Remove SRC, PRINT_SRC.
sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am,
spfatal/Makefile.am, spsize/Makefile.am: Remove SRC, PRINT_SRC.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, cdtest/Makefile.am, fileio/Makefile.am,
hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am,
minimum/Makefile.am, paranoia/Makefile.am, pppd/Makefile.am
ticker/Makefile.am, unlimited/Makefile.am:
Remove SRCS, PRINT_SRCS.
* automake/compile.am: Take contents of amcompile.am.
* automake/amcompile.am: Remove.
* Makefile.am: Cleanup.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am: Cleanup.
* tmitrontests.am: Add $(PGM): ${ARCH}/$(dirstamp).
* tmitronsem01/Makefile.am:
* mptests.: Add $(PGM): ${ARCH}/$(dirstamp).
* mp01/node1/Makefile.am, mp01/node2/Makefile.am,
* tmtests.am: Add $(PGM): ${ARCH}/$(dirstamp).
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am,
* psxtests.am: Add $(PGM): ${ARCH}/$(dirstamp).
* sptests.am: Add $(PGM): ${ARCH}/$(dirstamp).
* automake/amcompile.am: New.
* libtests.am: Add $(PGM): ${ARCH}/$(dirstamp).
* cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
* sample.am: Add $(PGM): ${ARCH}/$(dirstamp).
minimum/Makefile.am, paranoia/Makefile.am, pppd/Makefile.am,
* pppd/Makefile.am: Reflect libpppd having been split out.
* pppd/init.c, pppd/pppdapp.c: include rtems/rtemspppd.h instead of
rtemspppd.h.
* aclocal/version.m4: Updated to rtems-4.6.99.2.
PR 628/rtems
* psx04/init.c, psx04/psx04.scn: Update tests to reflect a signal of 0
being an error.
* loopback/init.c: socklen_t.
* psxreaddir/test.c: Eliminate warnings.
* sp13/task1.c: Removed warnings.
* aclocal/prog-cxx.m4: Re-add am__fastdepCXX conditional.
* aclocal/rtems-flags.m4: Remove (Unused).
