* | Add RTEMS linker sets | Sebastian Huber | 2015-12-08 | 9 | -0/+290 |
| | | | | Update #2408. | ||||
* | score: Statically initialize API extensions | Sebastian Huber | 2015-12-08 | 1 | -2/+0 |
* | Remove <rtems/debug.h> | Sebastian Huber | 2015-12-07 | 8 | -130/+1 |
| | | | | Close #2477. | ||||
* | psxtmtests_plan.csv: Fix typo | Joel Sherrill | 2015-12-01 | 1 | -1/+1 |
* | libtests/termios04: Avoid use of freed memory | Sebastian Huber | 2015-11-12 | 1 | -7/+35 |
* | sapi: Add rtems_chain_get_first_unprotected() | Sebastian Huber | 2015-11-05 | 1 | -0/+7 |
| | | | | Close #2459. | ||||
* | sptests/spsimplesched02: Fix warning | Sebastian Huber | 2015-11-04 | 1 | -1/+1 |
| | | | | Close #2455. | ||||
* | libblock: Print block sizes and count | Sebastian Huber | 2015-11-02 | 2 | -2/+5 |
* | CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK was undocumented and not error checked | Joel Sherrill | 2015-10-27 | 1 | -2/+2 |
| | | | | closes #2431. | ||||
* | basdefs.h: Add and use RTEMS_UNUSED | Sebastian Huber | 2015-10-26 | 6 | -43/+43 |
* | Fail gracefully if pax is not found | Ben Gras | 2015-10-22 | 1 | -1/+5 |
| | | | | | The $(PAX) variable is used unconditionally so it shouldn't be left empty if not found at configure time. Fixes #2437. | ||||
* | libfdt: Merge into librtemscpu | Sebastian Huber | 2015-10-19 | 1 | -2/+1 |
| | | | | This allows BSPs to use this library. | ||||
* | libfdt: Initial import | Sebastian Huber | 2015-10-16 | 9 | -0/+310 |
| | | | | | | | | | | | | | | Import from: git://git.kernel.org/pub/scm/utils/dtc/dtc.git Commit: 604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e Date: 2015-09-29T09:09:08Z | ||||
* | Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM | Sebastian Huber | 2015-10-15 | 4 | -8/+0 |
| | | | | This define accidentally re-appeared. | ||||
* | libstdthreads: Add C11 threads | Sebastian Huber | 2015-10-14 | 6 | -0/+501 |
* | SMP: Fix and optimize thread dispatching | Sebastian Huber | 2015-09-28 | 1 | -1/+2 |
| | | | | | | | | According to the C11 and C++11 memory models only a read-modify-write operation guarantees that we read the last value written in modification order. Avoid the sequential consistent thread fence and instead use the inter-processor interrupt to set the thread dispatch necessary indicator. | ||||
* | score: Use uintptr_t for atomic pointer operations | Sebastian Huber | 2015-09-26 | 4 | -64/+120 |
| | | | | Do not obfuscate the standard API. | ||||
* | score: Fix atomic compare exchange | Sebastian Huber | 2015-09-25 | 1 | -16/+49 |
* | score: Fix resource count for self-contained mutex | Sebastian Huber | 2015-09-14 | 1 | -3/+32 |
* | rbheap: Fix rtems_rbheap_free() | Sebastian Huber | 2015-09-11 | 1 | -0/+5 |
| | | | | | | | Remove unused descriptor of merged free chunks from the free chain and add them to the spare descriptors. Close #2417. | ||||
* | libtests/rbheap01: Simplify | Sebastian Huber | 2015-09-11 | 1 | -172/+95 |
| | | | | Update #2417. | ||||
* | Upgrade to 4.11.99.0 | Sebastian Huber | 2015-09-11 | 1 | -2/+2 |
* | score: Implement priority boosting | Sebastian Huber | 2015-09-04 | 1 | -5/+56 |
* | score: Implement SMP-specific priority queue | Sebastian Huber | 2015-09-04 | 6 | -0/+363 |
* | rbtree: Replace implementation | Sebastian Huber | 2015-09-03 | 1 | -431/+422 |
| | | | | | Use the BSD <sys/tree.h> implementation since it is faster, more flexible and uses less storage. See https://github.com/sebhub/rb-bench. | ||||
* | posix: glibc compatibility | Sebastian Huber | 2015-09-02 | 2 | -7/+7 |
* | psxtests/psxcancel: Check return status | Sebastian Huber | 2015-09-01 | 1 | -10/+24 |
| | | | | Update #2402. | ||||
* | score: Fix return status of mutex try acquire | Sebastian Huber | 2015-09-01 | 1 | -18/+18 |
| | | | | This fixes a copy and paste error (from libbsd). | ||||
* | rbtree: Delete rtems_rbtree_find_control() | Sebastian Huber | 2015-09-01 | 1 | -7/+0 |
| | | | | | This function is hard to support in alternative implementations. It has no internal use case. | ||||
* | rbheap: Drop direction from _RBTree_Iterate() | Sebastian Huber | 2015-08-31 | 2 | -6/+3 |
* | sptests/sprbtree01: Avoid internal API | Sebastian Huber | 2015-08-31 | 1 | -939/+951 |
* | sptests/sprbtree01: Fix random ops test case | Sebastian Huber | 2015-08-31 | 1 | -3/+3 |
* | score: Add self-contained condition implementation | Sebastian Huber | 2015-07-30 | 2 | -0/+113 |
* | score: Add scheduler <sys/lock.h> support | Sebastian Huber | 2015-07-30 | 2 | -0/+22 |
* | score: Add self-contained futex implementation | Sebastian Huber | 2015-07-30 | 2 | -0/+79 |
* | score: Add self-contained semaphore implementation | Sebastian Huber | 2015-07-30 | 2 | -0/+65 |
* | score: Add self-contained mutex implementation | Sebastian Huber | 2015-07-30 | 6 | -0/+486 |
| | | | | | | | This mutex implementation uses a thread priority queue with a simple priority inheritance mechanism (similar to the object based mutexes). The storage space must be supplied by the user (16 bytes on 32-bit targets). | ||||
* | i2c: Fix return status of i2c dev read/write | Sebastian Huber | 2015-07-23 | 1 | -2/+21 |
* | score: Introduce Thread_queue_Heads | Sebastian Huber | 2015-07-23 | 3 | -4/+4 |
| | | | | | | | | | | | | | Move the storage for the thread queue heads to the threads. Each thread provides a set of thread queue heads allocated from a dedicated memory pool. In case a thread blocks on a queue, then it lends its heads to the queue. In case the thread unblocks, then it takes a free set of threads from the queue. Since a thread can block on at most one queue this works. This mechanism is used in FreeBSD. The motivation for this change is to reduce the memory demands of the synchronization objects. On a 32-bit uni-processor configuration the Thread_queue_Control size is now 8 bytes, compared to 64 bytes in RTEMS 4.10 (other changes reduced the size as well). | ||||
* | score: Introduce Thread_queue_Queue | Sebastian Huber | 2015-07-23 | 1 | -2/+2 |
| | | | | | | Separate the thread queue heads and lock from the operations. This enables the support for light weight objects which only support one queuing discipline. | ||||
* | score: Typo | Sebastian Huber | 2015-07-13 | 1 | -1/+1 |
* | score: Accept NULL pointer in _Freechain_Put() | Sebastian Huber | 2015-07-01 | 1 | -0/+2 |
| | | | | With this a _Freechain_Put( _Freechain_Get() ) works always. | ||||
* | score: Freechain handler API changes | Sebastian Huber | 2015-07-01 | 2 | -152/+19 |
| | | | | | Replace the extend function with an allocator since this fits better to the current use case. | ||||
* | score: Hide SMP lock profiling impl if disabled | Sebastian Huber | 2015-06-26 | 1 | -2/+2 |
| | | | | The problem is that empty structures have a different size in C and C++. | ||||
* | libmisc: Simplify <rtems/stackchk.h> | Sebastian Huber | 2015-06-26 | 1 | -0/+1 |
| | | | | | Drop the <rtems/score/percpu.h> include since this file exposes a lot of implementation details. | ||||
* | rtems: Add rtems_interrupt_local_disable|enable() | Sebastian Huber | 2015-06-22 | 6 | -81/+101 |
| | | | | | | | | Add rtems_interrupt_local_disable|enable() as suggested by Pavel Pisa to emphasize that interrupts are only disabled on the current processor. Do not define the rtems_interrupt_disable|enable|flash() macros and functions on SMP configurations since they don't ensure system wide mutual exclusion. | ||||
* | tmtests/tm27: Use scheduler lock | Sebastian Huber | 2015-06-19 | 1 | -10/+5 |
* | sptests/sp37: Fix type and simplify | Sebastian Huber | 2015-06-19 | 1 | -15/+7 |
* | Remove use ticks for statistics configure option. | Joel Sherrill | 2015-06-15 | 1 | -42/+22 |
| | | | | | | | | | | This was obsolete and broken based upon recent time keeping changes. Thie build option was previously enabled by adding USE_TICKS_FOR_STATISTICS=1 to the configure command line. This propagated into the code as preprocessor conditionals using the __RTEMS_USE_TICKS_FOR_STATISTICS__ conditional. | ||||
* | score: Add _Watchdog_Preinitialize() | Sebastian Huber | 2015-06-13 | 1 | -4/+4 |
| | | | | | | Add an assert to ensure that the watchdog is the proper state for a _Watchdog_Initialize(). This helps to detect invalid initializations which may lead to a corrupt watchdog chain. |
