* | New shell of a test for ITRON Mailbox Manager. | Joel Sherrill | 1999-11-17 | 5 | -1/+70 | |
* | Fixed screen. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 | |
* | Added proper nesting level for dispatch disable check. | Joel Sherrill | 1999-11-16 | 3 | -3/+3 | |
* | Added code so if dispatching level is specified to be -1, then no | Joel Sherrill | 1999-11-16 | 1 | -1/+1 | |
| | | | | | check is performed. This is needed in some timer service routines since they are called from multiple disable levels. | |||||
* | Corrected nesting level on dispatching verification. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 | |
* | Corrected disable dispatch nesting count checks. | Joel Sherrill | 1999-11-16 | 1 | -7/+7 | |
* | Fixed typo. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 | |
* | Inserted output from the erc32 run into the output file. | Jennifer Averett | 1999-11-16 | 1 | -3/+71 | |
* | Use miniIMFS like hello from samples. | Joel Sherrill | 1999-11-16 | 1 | -0/+2 | |
* | Increased stack space because message buffers are on the stack. | Joel Sherrill | 1999-11-16 | 1 | -0/+1 | |
* | Removed leading space from output. | Jennifer Averett | 1999-11-16 | 2 | -4/+4 | |
* | Added comment indicating that dup is known to be broken. | Jennifer Averett | 1999-11-16 | 1 | -1/+1 | |
* | Added data to the log file so it matches the real output. | Jennifer Averett | 1999-11-16 | 1 | -3/+61 | |
* | Added comment to log file indicating that task order is not | Jennifer Averett | 1999-11-16 | 1 | -1/+3 | |
| | | | | critical. | |||||
* | Added test case of rsm_tsk and frsm_tsk on a task not suspended. | Jennifer Averett | 1999-11-16 | 2 | -3/+14 | |
| | | | | This should result in nothing happening, but an E_OK result. | |||||
* | Added BSP_MAXIMUM_OPERATION_COUNT and BSP_ITERATION_COUNT | Joel Sherrill | 1999-11-16 | 1 | -2/+27 | |
| | | | | | | | | | which allow the BSP to override the default number of objects that will be created in the timing tests. This is useful for reducing memory consumption on small targets. The BSP_ITERATION_COUNT can be used to reduce the number of repititions in some of the tests. This is useful for extremely slow targets (we haven't seen any slow enough to justify modifying this one yet though. :) | |||||
* | Added code to the macros which checked directive status to also | Joel Sherrill | 1999-11-16 | 1 | -20/+44 | |
| | | | | | | | check that the _Thread_Dispatch_disable_level is set to the proper value (0 99% of the time). This automatic check significantly reduces the chance of mismatching disable/enable dispatch pairs while doing internal RTEMS work. | |||||
* | Use the miniIMFS to reduce code space. | Joel Sherrill | 1999-11-16 | 1 | -0/+2 | |
* | Added test cases for uname(). | Joel Sherrill | 1999-11-16 | 2 | -0/+25 | |
* | Modified file to match seen output. | Jennifer Averett | 1999-11-16 | 1 | -92/+161 | |
* | Modified output file to match seen output. Added comment to all ino | Jennifer Averett | 1999-11-16 | 1 | -306/+282 | |
| | | | | values that they may change slightly on a processor basis. | |||||
* | Removed compiler warning. | Jennifer Averett | 1999-11-16 | 1 | -1/+1 | |
* | Changed asserts to tmmacros. | Jennifer Averett | 1999-11-16 | 2 | -8/+7 | |
* | Updated scn file to match new output. Left out unemplemented | Jennifer Averett | 1999-11-16 | 1 | -17/+12 | |
| | | | | parts as a reminder to fix when these routines became implemented. | |||||
* | + Changed ID to 1. ( Compilation error introduced by modifications. ) | Jennifer Averett | 1999-11-16 | 1 | -1/+1 | |
* | Modified scan file to match. | Jennifer Averett | 1999-11-16 | 1 | -2/+2 | |
* | Added itron tests. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 | |
* | Changed to call tmmacros instead of assert. | Jennifer Averett | 1999-11-16 | 1 | -141/+153 | |
* | Fixed verificaiton checks to call correct macro if dispatch is disabled. | Jennifer Averett | 1999-11-15 | 1 | -7/+12 | |
* | + Added check that a task could be sent to a dormant state | Jennifer Averett | 1999-11-15 | 4 | -12/+94 | |
| | | | | | | | | then sta_tsk used to restart the task to its initial state. + Added calls to ref_tsk to yellow paths for suspended and ready but not running tasks. + Fixed output file to correctly state test name + Added priority of preempt to the header file. Allows ref_tsk verification. | |||||
* | + Changed preempt routine into two dummy tasks one that is in dormant | Jennifer Averett | 1999-11-15 | 3 | -14/+94 | |
| | | | | | | | | state and one that is in non-dormant state. + Increased the priority of the Init task to force the dummy tasks to run first. + Added calls to ref_tsk to verify the state of the dummy tasks and test ref_tsk. | |||||
* | + Modified calls to use TSK_SLF for calls to self. | Joel Sherrill | 1999-11-12 | 1 | -25/+24 | |
| | | | | + Modified calls to use the task id macro for calls to the PREEMPT task. | |||||
* | + Added comments on paths tested. | Joel Sherrill | 1999-11-12 | 2 | -1/+14 | |
* | + Added check for priority over 256. | Joel Sherrill | 1999-11-12 | 1 | -1/+4 | |
| | | | | + Modified output to correctly state the error. | |||||
* | Added comments for path's tested. | Joel Sherrill | 1999-11-12 | 1 | -0/+3 | |
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 6 | -8/+9 | |
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 2 | -6/+11 | |
| | | | | Changed output to reflect what was actually being tested. | |||||
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 4 | -5/+9 | |
| | | | | Increased stack space. | |||||
* | Enabled after merging message buffer code. | Joel Sherrill | 1999-11-12 | 1 | -6/+2 | |
* | Added comment block and removed include of deleted file. | Joel Sherrill | 1999-11-12 | 1 | -1/+4 | |
* | Screen updated. | Joel Sherrill | 1999-11-11 | 1 | -0/+2 | |
* | Added new test sp28 to test the task variable directives. | Joel Sherrill | 1999-11-11 | 4 | -1/+98 | |
* | General cleanup. Test documentation improved. The message buffer test | Joel Sherrill | 1999-11-10 | 15 | -22/+81 | |
| | | | | | prints a message instead of actually testing since the message buffer implementation is not in yet. | |||||
* | rtems_semaphore_flush test from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-10 | 4 | -1/+104 | |
* | Combination of committing some new files which had been overlooked | Joel Sherrill | 1999-11-10 | 5 | -1/+95 | |
| | | | | and adding code which installed screens for itron tests. | |||||
* | Added support for ITRON tests. | Joel Sherrill | 1999-11-10 | 1 | -0/+2 | |
* | Added more tasking tests. | Joel Sherrill | 1999-11-09 | 1 | -1/+2 | |
* | Merged tests from Task group. | Joel Sherrill | 1999-11-09 | 30 | -38/+1553 | |
* | Added nesting count for suspend/resume. | Joel Sherrill | 1999-11-09 | 1 | -1/+1 | |
* | Changed B, H, and W variables to BVar, HVar, and WVar to avoid conflicts | Joel Sherrill | 1999-11-09 | 1 | -35/+35 | |
| | | | | | with ITRON 3.0 data types regardless of how dumb it is to name types with a simple letter. |
