Update #2408.
Make sure PER_CPU_DATA_OFFSET() is tested also in uniprocessor
configurations.
Use the user provided now handler of the test configuration to get the
time in T_now().
Use CONFIGURE_MAXIMUM_PROCESSORS to configure the EDF SMP scheduler
context. This avoids hard to debug configuration errors resulting in
memory corruptions.
Close #3815.
Update #3845.
Update #3753.
This function is unused.
Update #3735.
Replace the user MPCI configuration table with a system provided
_MPCI_Configuration.
Update #3735.
Update #3841.
Obsolete undocumented configuration options CONFIGURE_MAXIMUM_FIFOS and
CONFIGURE_MAXIMUM_PIPES. Replace these options with the new
CONFIGURE_IMFS_ENABLE_MKFIFO configuration option.
Update #3840.
Update #3818.
Two use cases were envisioned for this.
1) a BSP or application which desires to update a real-time clock
when the RTEMS TOD is set.
2) a paravirtualized BSP can use this to propagate setting the time
in an RTEMS application to the hosting environment. This enables
the entire set of applications in the virtualized environments
to have a single consistent TOD.
Use self-contained condition variables instead of Classic API barriers.
This simplifies the implementation and configuration.
Update #3840.
The MrsP semaphore implementation predates the addition of
self-contained synchronization objects. At this time, the potential
memory reduction was justified considering the more complex
configuration and additional use of the workspace. With the
availability of self-contained synchronization options, e.g. POSIX
mutexes, this is no longer justified. Memory constrained applications
should use the self-contained synchronization objects. Remove the
CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option. This has only an
impact on applications which use SMP and a large number of scheduler
instances.
Update #3833.
Use a system initialization handler instead of a legacy IO driver.
Update #3834.
Use separator character '_' for all test states.
The rtems_test_pause() and rtems_test_pause_and_screen_number() macros
had different implementations depending on the RTEMS_TEST_NO_PAUSE
define. This define was defined to 1 by default. The user was able to
change this via the undocumented --disable-test-no-pause configure
command line option.
Pausing tests and waiting for user input contradicts the goal of having
automated test runs. Remove this feature.
Update #3818.
This allows to use header includes in "config.h" to reduce the build
configuration checks.
Update #3818.
Update #3818.
Provide an init.c for each Ada test instead of the #include <config.h>
magic which works only due to hand crafted include paths.
Update #3818.
Close #3823.
Rename source files to use a %.c -> %.o and %.cc -> %.o pattern. Use
*.cc for C++ source files instead of *.cpp to be in line with other C++
source files.
Update #3818.
Use rtems_tarfs_load() instead of Untar_FromMemory() to reduce the
memory demands of the tests.
The functions expect a valid string as input according to POSIX. On
systems with a NULL pointer protection the test cases ended up in
exceptions.
Use uniform pattern for all TAR file names. Use the dl* tests as a
template.
Update #3818.
Add the static files to the repository. This simplifies the build.
Update #3818.
This simplifies the build process. Do not generate the archive content
through the build system. Let the version control system deal with
symbolic links.
Update #3818.
Both need POSIX support
Update #3818.
Use the test state configuration instead.
Update #3818.
Support for targets compiled with -fno-pic and -mno-relax
Fix all warnings.
Update #3818.
Update #3818.
Move system.h to shared init.c.
Update #3818.
Update #3818.
Update #3818.
This avoids an extra include path.
Update #3818.
Update #3818.
Update #3818.
If there is a real need, it can be made a configuration option again.
Update #3818.
Update #3818.
This include is superfluous.
Update #3818.
Update #3818.
This driver is no longer used by a test program.
Update #3818.
The "TRrc" semaphore was removed in commit
2c12262f9a8fe7975556729f0574fab8d5a792f5.
Update #3818.
Update #3818.
