path: root/testsuites (follow)
* 2004-03-30 David Querbach <querbach@realtime.bc.ca>Joel Sherrill2004-03-3027-51/+55
| | | | | | | | | | | | | | | PR 597/tests * tm02/system.h, tm03/system.h, tm04/system.h, tm05/system.h, tm06/system.h, tm07/system.h, tm08/system.h, tm10/system.h, tm11/system.h, tm12/system.h, tm13/system.h, tm14/system.h, tm15/system.h, tm16/system.h, tm17/system.h, tm18/system.h, tm19/system.h, tm21/system.h, tm22/system.h, tm23/system.h, tm24/system.h, tm25/system.h, tm26/system.h, tm27/system.h, tm27/task1.c, tm29/system.h: The actual workspace needed by the tmtests depends on OPERATION_COUNT, but the definitions of CONFIGURE_MAXIMIM_xxx in the their system.h files do not reflect this. This results in unnecessary memory exhaustion on small-memory systems such as the SS555.
* 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-3023-39/+49
| | | | | | | | | | * mp02/task1.c, mp03/system.h, mp03/task1.c, mp04/task1.c, mp05/system.h, mp06/task1.c, mp07/task1.c, mp08/task1.c, mp09/recvmsg.c, mp09/sendmsg.c, mp09/task1.c, mp10/task1.c, mp11/init.c, mp12/init.c, mp13/task1.c, mp14/evtask1.c, mp14/evtmtask.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c, mp14/system.h: Convert to using c99 fixed size types.
* 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-302-2/+6
| | | | * include/timesys.h: Convert to using c99 fixed size types.
* 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-305-8/+13
| | | | | * psx06/init.c, psx06/system.h, psx06/task.c, psx06/task2.c: Convert to using c99 fixed size types.
* 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-3039-80/+92
| | | | | | | | | | | | | | * sp02/task1.c, sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp05/task1.c, sp06/task1.c, sp09/screen01.c, sp09/screen07.c, sp09/screen12.c, sp09/system.h, sp09/task3.c, sp11/task1.c, sp12/pridrv.c, sp12/pritask.c, sp12/system.h, sp13/task1.c, sp13/task2.c, sp13/task3.c, sp14/system.h, sp15/system.h, sp16/system.h, sp17/system.h, sp19/first.c, sp19/fptask.c, sp19/inttest.h, sp19/system.h, sp19/task1.c, sp20/init.c, sp20/system.h, sp20/task1.c, sp23/system.h, sp24/init.c, sp25/system.h, sp30/init.c, spfatal/fatal.c, spfatal/puterr.c, spfatal/system.h, spsize/size.c: Convert to using c99 fixed size types.
* 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-3014-31/+39
| | | | | | | | * cpuuse/system.h, cpuuse/task1.c, cpuuse/tswitch.c, monitor/init.c, monitor/system.h, rtems++/System.h, rtems++/Task1.cc, rtems++/Task2.cc, rtems++/Task3.cc, rtmonuse/init.c, rtmonuse/system.h, rtmonuse/task1.c, stackchk/blow.c: Convert to using c99 fixed size types.
* 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-309-22/+28
| | | | | | * fileio/init.c, fileio/system.h, ticker/system.h, ticker/tasks.c, unlimited/init.c, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c: Convert to using c99 fixed size types.
* 2004-03-28 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-282-1/+5
| | | | * aclocal/rtems-top.m4: s/RTEMS_RTEMS/RTEMS_ROOT (typo).
* 2004-03-28 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-2832-123/+135
| | | | | | | | | | | | * include/timesys.h, tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c, tm20/task1.c, tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Convert to using c99 fixed size types.
* 2004-03-26 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-269-23/+11
| | | | | | * include/Makefile.am: Remove. * Makefile.am: Merge-in include/Makefile.am. * configure.ac: Reflect changes above.
* 2004-03-26 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-262-1/+5
| | | | * Makefile.am: Remove include from SUBDIRS.
* 2004-03-26 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-265-14/+8
* 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-252-1/+5
| | | | * aclocal/check-custom-bsp.m4: Fix minor typo.
* 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-252-3/+7
| | | | * include/tmacros.h: Convert to using c99 fixed size types.
* 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-253-5/+13
| | | | | * aclocal/rtems-top.m4: Add rtems_rootdir. * aclocal/check-custom-bsp.m4: Check for $RTEMS_BSP.cfg in $rtems_rootdir.
* 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-252-14/+25
| | | | | | * aclocal/rtems-top.m4: Add 2nd arg to RTEMS_TOP. Rework with_project_root/PROJECT_ROOT and with_project_top/PROJECT_TOPdir. Add --enable-rtems-root. Rework RTEMS_ROOT.
* 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-2510-15/+18
| | | | | | | | * aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-tests.m4, aclocal/multilib.m4, aclocal/rtems-test-no-pause.m4: Autoupdate to autoconf-2.59.
* 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-2522-11/+59
| | | | * configure.ac: Add 2nd arg to RTEMS_TOP.
* Unused.Ralf Corsepius2004-03-091-2/+0
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-052-2/+6
| | | | * sp07/buffered_io.c: Remove warning.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-055-3/+10
| | | | | * psxfile01/test.c, psxmsgq01/init.c, psxstat/test.c, psxtimer/psxtimer.c: Eliminate warnings and typos.
* 2004-03-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-032-1/+5
| | | | * include/buffer_test_io.h: Correct typo.
* 2004-02-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-263-0/+17
| | | | | | PR 583/tests * tm26/task1.c, tm27/task1.c: Correctly reset _Thread_Dispatch_disable_level so printing is safe.
* 2004-02-26 Sébastien Barré <sbarre@sdelcc.com>Joel Sherrill2004-02-263-28/+19
| | | | | | PR 582/core * psxmsgq01/init.c, psxmsgq01/psxmsgq01.scn: Fix the POSIX message queue test so more of it runs now.
* 2004-02-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-196-32/+36
| | | | | | | | * configure.ac: AC_CONFIG_SRCDIR([PROBLEMS]). * aclocal/check-custom-bsp.m4: Sync with c/src/aclocal. * aclocal/project-root.m4: Remove obsolete comments. * aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT. * aclocal/rtems-top.m4: Rework.
* 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-142-1/+4
| | | | * configure.ac: Remove subdir tools.
* 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-146-33/+20
| | | | | * configure.ac: Rework. Make package a host compiled package. * Makefile.am: Ditto.
* 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-142-138/+4
| | | | * aclocal/target.m4: Remove (Unused).
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-122-1/+5
| | | | * aclocal/version.m4: 4.6.99.0.
* 2004-02-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-042-0/+8
| | | | | * include/buffer_test_io.h: Do not use iprintf() if in ANSI compiler mode.
* 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-212-1/+6
| | | | | * configure.ac: Remove -Wall -ansi to work-around non-portability of with cdtest.
* 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-212-1/+7
| | | | * Makefile.am: Add PREINSTALL_DIRS.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-1432-0/+97
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tm01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * tm02/Makefile.am: Ditto. * tm03/Makefile.am: Ditto. * tm04/Makefile.am: Ditto. * tm05/Makefile.am: Ditto. * tm06/Makefile.am: Ditto. * tm07/Makefile.am: Ditto. * tm08/Makefile.am: Ditto. * tm09/Makefile.am: Ditto. * tm10/Makefile.am: Ditto. * tm11/Makefile.am: Ditto. * tm12/Makefile.am: Ditto. * tm13/Makefile.am: Ditto. * tm14/Makefile.am: Ditto. * tm15/Makefile.am: Ditto. * tm16/Makefile.am: Ditto. * tm17/Makefile.am: Ditto. * tm18/Makefile.am: Ditto. * tm19/Makefile.am: Ditto. * tm20/Makefile.am: Ditto. * tm21/Makefile.am: Ditto. * tm22/Makefile.am: Ditto. * tm23/Makefile.am: Ditto. * tm24/Makefile.am: Ditto. * tm25/Makefile.am: Ditto. * tm26/Makefile.am: Ditto. * tm27/Makefile.am: Ditto. * tm28/Makefile.am: Ditto. * tm29/Makefile.am: Ditto. * tmck/Makefile.am: Ditto. * tmoverhd/Makefile.am: Ditto.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-142-0/+7
| | | | | * tmitronsem01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-144-0/+16
| | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-1433-0/+100
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * sp02/Makefile.am: Ditto. * sp03/Makefile.am: Ditto. * sp04/Makefile.am: Ditto. * sp05/Makefile.am: Ditto. * sp06/Makefile.am: Ditto. * sp07/Makefile.am: Ditto. * sp08/Makefile.am: Ditto. * sp09/Makefile.am: Ditto. * sp11/Makefile.am: Ditto. * sp12/Makefile.am: Ditto. * sp13/Makefile.am: Ditto. * sp14/Makefile.am: Ditto. * sp15/Makefile.am: Ditto. * sp16/Makefile.am: Ditto. * sp17/Makefile.am: Ditto. * sp19/Makefile.am: Ditto. * sp20/Makefile.am: Ditto. * sp21/Makefile.am: Ditto. * sp22/Makefile.am: Ditto. * sp23/Makefile.am: Ditto. * sp24/Makefile.am: Ditto. * sp25/Makefile.am: Ditto. * sp26/Makefile.am: Ditto. * sp27/Makefile.am: Ditto. * sp28/Makefile.am: Ditto. * sp29/Makefile.am: Ditto. * sp30/Makefile.am: Ditto. * sp31/Makefile.am: Ditto. * sp32/Makefile.am: Ditto. * spfatal/Makefile.am: Ditto. * spsize/Makefile.am: Ditto.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-1413-0/+40
| | | | | | | | | | | | | | | | * base_mp/node1/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * base_mp/node2/Makefile.am: Ditto. * base_sp/Makefile.am: Ditto. * cdtest/Makefile.am: Ditto. * fileio/Makefile.am: Ditto. * hello/Makefile.am: Ditto. * loopback/Makefile.am: Ditto. * minimum/Makefile.am: Ditto. * paranoia/Makefile.am: Ditto. * pppd/Makefile.am: Ditto. * ticker/Makefile.am: Ditto. * unlimited/Makefile.am: Ditto.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-1424-0/+73
| | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * psx02/Makefile.am: Ditto. * psx03/Makefile.am: Ditto. * psx04/Makefile.am: Ditto. * psx05/Makefile.am: Ditto. * psx06/Makefile.am: Ditto. * psx07/Makefile.am: Ditto. * psx08/Makefile.am: Ditto. * psx09/Makefile.am: Ditto. * psx10/Makefile.am: Ditto. * psx11/Makefile.am: Ditto. * psx12/Makefile.am: Ditto. * psx13/Makefile.am: Ditto. * psxcancel/Makefile.am: Ditto. * psxchroot01/Makefile.am: Ditto. * psxfile01/Makefile.am: Ditto. * psxmount/Makefile.am: Ditto. * psxmsgq01/Makefile.am: Ditto. * psxreaddir/Makefile.am: Ditto. * psxsem01/Makefile.am: Ditto. * psxstat/Makefile.am: Ditto. * psxtime/Makefile.am: Ditto. * psxtimer/Makefile.am: Ditto.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-1429-0/+88
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * mp01/node2/Makefile.am: Ditto. * mp02/node1/Makefile.am: Ditto. * mp02/node2/Makefile.am: Ditto. * mp03/node1/Makefile.am: Ditto. * mp03/node2/Makefile.am: Ditto. * mp04/node1/Makefile.am: Ditto. * mp04/node2/Makefile.am: Ditto. * mp05/node1/Makefile.am: Ditto. * mp05/node2/Makefile.am: Ditto. * mp06/node1/Makefile.am: Ditto. * mp06/node2/Makefile.am: Ditto. * mp07/node1/Makefile.am: Ditto. * mp07/node2/Makefile.am: Ditto. * mp08/node1/Makefile.am: Ditto. * mp08/node2/Makefile.am: Ditto. * mp09/node1/Makefile.am: Ditto. * mp09/node2/Makefile.am: Ditto. * mp10/node1/Makefile.am: Ditto. * mp10/node2/Makefile.am: Ditto. * mp11/node1/Makefile.am: Ditto. * mp11/node2/Makefile.am: Ditto. * mp12/node1/Makefile.am: Ditto. * mp12/node2/Makefile.am: Ditto. * mp13/node1/Makefile.am: Ditto. * mp13/node2/Makefile.am: Ditto. * mp14/node1/Makefile.am: Ditto. * mp14/node2/Makefile.am: Ditto.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-149-0/+28
| | | | | | | | | | | | * cpuuse/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * malloctest/Makefile.am: Ditto. * monitor/Makefile.am: Ditto. * putenvtest/Makefile.am: Ditto. * rtems++/Makefile.am: Ditto. * rtmonuse/Makefile.am: Ditto. * stackchk/Makefile.am: Ditto. * termios/Makefile.am: Ditto.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-1410-0/+31
| | | | | | | | | | | | | * itronhello/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * itronmbf01/Makefile.am: Ditto. * itronmbox01/Makefile.am: Ditto. * itronsem01/Makefile.am: Ditto. * itrontask01/Makefile.am: Ditto. * itrontask02/Makefile.am: Ditto. * itrontask03/Makefile.am: Ditto. * itrontask04/Makefile.am: Ditto. * itrontime01/Makefile.am: Ditto.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-072-1/+5
| | | | | * aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port more completely covers the MIPS family.
* 2003-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-192-2/+6
| | | | * samples.am: Fix yet another stupid typo in yesterday's patch.
* 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-182-2/+5
| | | | * mptests.am: Fix typos in previous patch.
* 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-182-4/+8
| | | | * tmtests.am: Add dirstamp support.
| | | | * tmitrontests.am: Add dirstamp support.
* 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-1830-130/+183
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mptests.am: Add dirstamp support. * mptests/mp01/node1/Makefile.am: Eliminate VPATH. * mptests/mp01/node2/Makefile.am: Eliminate VPATH. * mptests/mp02/node1/Makefile.am: Eliminate VPATH. * mptests/mp02/node2/Makefile.am: Eliminate VPATH. * mptests/mp03/node1/Makefile.am: Eliminate VPATH. * mptests/mp03/node2/Makefile.am: Eliminate VPATH. * mptests/mp04/node1/Makefile.am: Eliminate VPATH. * mptests/mp04/node2/Makefile.am: Eliminate VPATH. * mptests/mp05/node1/Makefile.am: Eliminate VPATH. * mptests/mp05/node2/Makefile.am: Eliminate VPATH. * mptests/mp06/node1/Makefile.am: Eliminate VPATH. * mptests/mp06/node2/Makefile.am: Eliminate VPATH. * mptests/mp07/node1/Makefile.am: Eliminate VPATH. * mptests/mp07/node2/Makefile.am: Eliminate VPATH. * mptests/mp08/node1/Makefile.am: Eliminate VPATH. * mptests/mp08/node2/Makefile.am: Eliminate VPATH. * mptests/mp09/node1/Makefile.am: Eliminate VPATH. * mptests/mp09/node2/Makefile.am: Eliminate VPATH. * mptests/mp10/node1/Makefile.am: Eliminate VPATH. * mptests/mp10/node2/Makefile.am: Eliminate VPATH. * mptests/mp11/node1/Makefile.am: Eliminate VPATH. * mptests/mp11/node2/Makefile.am: Eliminate VPATH. * mptests/mp12/node1/Makefile.am: Eliminate VPATH. * mptests/mp12/node2/Makefile.am: Eliminate VPATH. * mptests/mp13/node1/Makefile.am: Eliminate VPATH. * mptests/mp13/node2/Makefile.am: Eliminate VPATH. * mptests/mp14/node1/Makefile.am: Eliminate VPATH. * mptests/mp14/node2/Makefile.am: Eliminate VPATH.
* 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-182-12/+12
| | | | * itrontests.am: Add dirstamp support.
| | | | * sptests.am: Add dirstamp support.
* 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-182-8/+12
| | | | * samples.am: Add dirstamp support.
