* psxtmsleep01/Makefile.in: Removed.
* Makefile.am, configure.ac, psxtmtests_plan.csv: Add psxtmsleep01.
* psxtmsleep01/.cvsignore, psxtmsleep01/Makefile.am,
psxtmsleep01/Makefile.in, psxtmsleep01/init.c,
psxtmsleep01/psxtmsleep01.doc: New files.
* sp01/init.c, sp01/sp01.doc, sp01/system.h, sp01/task1.c, sp02/init.c,
sp02/preempt.c, sp02/sp02.doc, sp02/system.h, sp02/task1.c,
sp02/task2.c, sp02/task3.c, sp03/init.c, sp03/sp03.doc,
sp03/system.h, sp03/task1.c, sp03/task2.c: Clean up. Update.
* sp09/screen02.c, sp09/screen13.c, sp09/sp09.scn, sp29/init.c,
sp30/sp30.scn, sp32/init.c, spclockget/init.c: Avoid use of
deprecated rtems_clock_get() except in spclockget().
* fileio/init.c: Avoid use of deprecated rtems_clock_get() except in
spclockget().
* psxtmtests_plan.csv: Add sleep and nanosleep cases.
* spintrcritical01/init.c: Fixed warning fix.
* mouse01/serial_mouse_config.c: Avoid output due to execution context.
* termios08/init.c: Fixed parameter to avoid test failure.
* rtems++/Init.cc, rtems++/Task1.cc, rtems++/Task2.cc,
rtems++/Task3.cc: Added HAVE_CONFIG_H.
* psxclock/init.c (Init):
Use CLOCK_PROCESS_CPUTIME_ID and CLOCK_THREAD_CPUTIME_ID.
* psxclock/psxclock.scn: Regenerate.
* sp21/init.c, sp21/sp21.doc sp21/sp21.scn: New test cases.
* tm26/system.h, tm27/system.h: Ensure these tests use the correct
scheduler.
* sp39/init.c: Fix tests broken in warning pass.
* psxfile01/test.c, psxmsgq01/init.c, psxreaddir/test.c: Fix tests
* malloc04/init.c: Fix tests broken in warning pass.
* ftp01/.cvsignore, ftp01/Makefile.am, ftp01/ftp01.doc,
ftp01/ftp01.scn, ftp01/init.c: New files.
* Makefile.am, configure.ac: Reflect changes above.
* spnsext01/.cvsignore, spnsext01/Makefile.am, spnsext01/init.c,
spnsext01/spnsext01.doc, spnsext01/spnsext01.scn: New files.
* fileio/Makefile.am, ticker/Makefile.am: Missed part of previous
patch.
* tm01/task1.c, tm02/task1.c, tm03/task1.c, tm15/task1.c: Remove
warnings.
* sp09/screen12.c, sp09/sp09.scn, sp21/Makefile.am, sp35/priinv.c,
sp39/init.c, sp50/init.c, sp57/init.c, sp72/init.c, sp73/init.c,
spintrcritical01/init.c, spprivenv01/init.c, spsimplesched01/init.c,
spsimplesched02/init.c: Remove warnings.
* psx04/task3.c, psxfile01/test.c, psxhdrs/Makefile.am,
psxmsgq01/init.c, psxreaddir/test.c, psxsignal01/init.c,
psxtimes01/init.c, psxualarm/init.c: Remove warnings.
* devnullfatal01/testcase.h, malloc02/init.c, malloc04/init.c,
malloctest/init.c, termios03/termios_testdriver_polled.c,
termios04/termios_testdriver_intr.c: Remove warnings.
* base_sp/apptask.c, base_sp/init.c, fileio/init.c, fileio/system.h,
nsecs/init.c, ticker/init.c, ticker/system.h, ticker/tasks.c: Remove
warnings.
PR 1784
* sptests/spsize/size.c: Split bspsmp.h into two files smp.h and
bspsmp.h
PR 1777/cpukit
* support/include/tmacros.h, tmtests/tm26/task1.c,
tmtests/tm27/task1.c: Consolidated access to
_Thread_Dispatch_disable_level.
* configure.ac: Add fstests.
Add initial test to File System Test Suite.
* .cvsignore, ChangeLog, Makefile.am, configure.ac, fs01/fs91.doc,
fs01/init.c, imfs_fs01/.cvsignore, imfs_fs01/Makefile.am,
imfs_fs01/imfs_fs01.scn, imfs_support/fs_config.h,
imfs_support/fs_support.c, mimfs_fs01/.cvsignore,
mimfs_fs01/Makefile.am, mimfs_fs01/mimfs_fs01.scn,
mimfs_support/fs_config.h, mimfs_support/fs_support.c: New files.
* README, psxtmtests_plan.csv: Add more possible test cases.
* psxstat/test.c: Check status codes.
* sp09/screen02.c: Use integer value that fits into one character.
* psxstat/test.c: Fixed integer type.
* tar01/init.c: Fixed integer types.
PR 1641/cpukit
* Makefile.am, configure.ac: Create testcase for red black tree.
* sprbtree01/init.c, sprbtree01/Makefile.am, sprbtree01/sprbtree01.doc,
sprbtree01/sprbtree01.scn: New files.
PR 1729/cpukit
* spsize/size.c: Add next step in SMP support. This adds an allocated
array of the Per_CPU structures to support multiple cpus vs a single
instance of the structure which is still used if SMP support is
disabled. Configuration support is also added to explicitly enable or
disable SMP. But SMP can only be enabled for the CPUs which will
support it initially -- SPARC and i386. With the stub BSP support, a
BSP can be run as a single core SMP system from an RTEMS data
structure standpoint.
* spfifo05/init.c: Console interrupts perturb test.
PR 1743/cpu
* tm26/task1.c, tm27/task1.c: Add Simple Priority Scheduler as
complement to existing Deterministic Priority Scheduler. Modify these
tests to verify the scheduler they are designed to work with is the
default scheduler.
PR 1743/cpu
* Makefile.am, configure.ac, spsize/size.c: Add Simple Priority
Scheduler as complement to existing Deterministic Priority Scheduler.
This scheduler serves both as an example and as a lighter weight
implementation for smaller systems.
* spsimplesched01/.cvsignore, spsimplesched01/Makefile.am,
spsimplesched01/init.c, spsimplesched01/spsimplesched01.doc,
spsimplesched01/spsimplesched01.scn, spsimplesched02/.cvsignore,
spsimplesched02/Makefile.am, spsimplesched02/init.c,
spsimplesched02/spsimplesched02.doc,
spsimplesched02/spsimplesched02.scn, spsimplesched03/.cvsignore,
spsimplesched03/Makefile.am, spsimplesched03/init.c,
spsimplesched03/spsimplesched03.doc,
spsimplesched03/spsimplesched03.scn: New files.
* tm26/task1.c: Update for API change.
* Makefile.am, configure.ac: Add test for Mouse Parser Engine
(Microsoft Mouse paths) and Serial Mouse Driver.
* mouse01/.cvsignore, mouse01/Makefile.am, mouse01/init.c,
mouse01/mouse01.doc, mouse01/mouse01.scn, mouse01/msmouse.c,
mouse01/serial_mouse_config.c: New files.
* sp58/init.c, sp58/sp58.scn: Account for case where left hand side
seconds field is less than.
* sp08/sp08.scn: Convert to UNIX CR/LF.
* sp08/Makefile.am, sp08/init.c, sp08/sp08.scn, sp09/screen07.c,
sp09/sp09.scn: Improve coverage. Change mode while system not up and
broadcast a message that is too large.
* sp08/system.h, sp08/task1.c: Removed.
* Makefile.am, configure.ac: Add sp73. This is a new test designed
to improve coverage of the thread yield logic.
* sp73/.cvsignore, sp73/Makefile.am, sp73/init.c, sp73/sp73.doc,
sp73/sp73.scn: New files.
* sp07/init.c: Improve coverage.
* heapwalk/init.c: Improve coverage.
* heapwalk/heapwalk.scn: Update.
* spwkspace/init.c: Adjust test to account for recent heap change on
NULL.
* psx04/init.c, psx04/psx04.scn: Remove test case made obsolete by
PR1759.
* devfs04/devfs04.scn, devfs04/init.c: Increase configuration so this
passes on sis.
* sp43/init.c, sp43/sp43.scn: Improve coverage of _Thread_Get.
