1996-05-29 | simple version of test which shows pthread_create, pthread_exit, and exit | Joel Sherrill | 3 | -4/+19 | |
are basically working. This test will be enhanced further. | |||||
1996-05-29 | Gutted test of rtems api calls and added comments to indicate what the test | Joel Sherrill | 3 | -77/+31 | |
should do in their place. It now compiles and links. | |||||
1996-05-28 | added initial posix configuration support | Joel Sherrill | 1 | -1/+2 | |
1996-05-24 | new file | Joel Sherrill | 14 | -0/+337 | |
1996-05-24 | new file | Joel Sherrill | 1 | -0/+50 | |
1996-05-24 | updates from Tony Bennett to correct calling sequences. | Joel Sherrill | 2 | -0/+2 | |
1996-05-24 | new files | Joel Sherrill | 3 | -4/+111 | |
1996-05-24 | new file | Mark Johannes | 1 | -0/+22 | |
1996-05-24 | added use of sporadic server scheduling parameters | Joel Sherrill | 7 | -0/+58 | |
1996-05-24 | new files | Joel Sherrill | 3 | -0/+96 | |
1996-05-23 | clean up on DELAYTIMER_MAX | Joel Sherrill | 3 | -12/+0 | |
1996-05-23 | new files | Joel Sherrill | 6 | -0/+204 | |
1996-05-23 | unused variable | Joel Sherrill | 1 | -1/+0 | |
1996-05-23 | new files | Joel Sherrill | 8 | -0/+208 | |
1996-05-23 | new files | Joel Sherrill | 7 | -0/+184 | |
1996-05-23 | new files | Joel Sherrill | 3 | -0/+75 | |
1996-05-23 | new files | Joel Sherrill | 5 | -0/+144 | |
1996-05-23 | new files | Joel Sherrill | 4 | -0/+110 | |
1996-05-23 | cleanup | Joel Sherrill | 8 | -12/+12 | |
1996-05-23 | new files | Joel Sherrill | 8 | -0/+254 | |
1996-05-23 | cleanup status vs. result | Joel Sherrill | 29 | -48/+48 | |
1996-05-23 | new files | Joel Sherrill | 5 | -0/+152 | |
1996-05-23 | new files | Joel Sherrill | 4 | -0/+134 | |
1996-05-23 | new files | Joel Sherrill | 2 | -0/+60 | |
1996-05-23 | new files | Joel Sherrill | 6 | -0/+200 | |
1996-05-23 | new files | Joel Sherrill | 9 | -0/+288 | |
1996-05-23 | updated to reflect more constants and feature macros | Joel Sherrill | 34 | -5/+160 | |
1996-05-23 | updates from Tony Bennett | Joel Sherrill | 2 | -1/+16 | |
1996-05-22 | created posix test suite with test of header files | Joel Sherrill | 51 | -0/+1379 | |
1996-05-10 | added posix test directory | Joel Sherrill | 1 | -3/+8 | |
1996-04-22 | Lowered number of messages created to reduce burden on workspace. | Joel Sherrill | 1 | -1/+1 | |
1996-04-22 | updates from Tony Bennett | Joel Sherrill | 3 | -3/+5 | |
1996-04-22 | addition of optional user provided stack allocator means that we can not | Joel Sherrill | 1 | -14/+27 | |
reliably produce the "insufficient memory for stack space" error if this extension is configured. | |||||
1996-03-06 | As part of reducing visibility into rtems and hiding the .inl files | Joel Sherrill | 1 | -0/+1 | |
from the application code, this file required more visibility than is given by default to application code. | |||||
1996-02-22 | The name of the test support routine pause was changed to rtems_test_pause | Joel Sherrill | 13 | -42/+38 | |
to avoid conflict with the standard POSIX routine pause(2). | |||||
1996-02-21 | Dispersal of internal thread handler resulted in removal of some | Joel Sherrill | 1 | -16/+11 | |
variables and renaming of others. | |||||
1996-02-13 | removed post switch extension | Joel Sherrill | 3 | -3/+0 | |
1996-02-09 | As part of implementing the new isr synchronization algorithm using a | Joel Sherrill | 1 | -1/+1 | |
single enumerated set of states the set of event manager variables changed. | |||||
1996-01-19 | Added RTEMS API control structure to per task memory usage macro. | Joel Sherrill | 1 | -1/+2 | |
1996-01-19 | Increased stack size. | Joel Sherrill | 3 | -3/+5 | |
1996-01-17 | increased stack space | Joel Sherrill | 2 | -2/+2 | |
1996-01-15 | Init task was not defined as being floating point. | Joel Sherrill | 1 | -0/+2 | |
1996-01-15 | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 3 | -10/+15 | |
1995-12-20 | changes remerged after lost in disk crash -- recovered from snapshot, ↵ | Joel Sherrill | 28 | -110/+159 | |
partially recovered working tree, etc | |||||
1995-12-19 | changes remerged after disk crash -- history lost | Joel Sherrill | 1 | -53/+0 | |
1995-10-31 | typos fixed | Joel Sherrill | 1 | -0/+5 | |
1995-10-30 | SPARC port passes all tests | Joel Sherrill | 12 | -30/+84 | |
1995-10-11 | reordered test cases from simple to complex | Joel Sherrill | 1 | -13/+25 | |
1995-10-06 | fixed missing CVS IDs | Joel Sherrill | 6 | -5/+7 | |
1995-09-29 | all targets compile .. tony's patches in place | Joel Sherrill | 2 | -5/+1 | |
