path: root/testsuites (follow)
* 2002-04-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-179-0/+19
| | | | | | | | | | | * base_sp/apptask.c: Include <stdlib.h>. * hello/init.c: Ditto. * paranoia/init.c: Ditto. * ticker/tasks.c: Ditto. * unlimited/init.c: Ditto. * unlimited/test1.c: Ditto. * unlimited/test2.c: Ditto. * unlimited/test3.c: Ditto.
* 2002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-1618-15/+36
| | | | * configure.ac: Remove ENABLE_GCC28.
* 2001-04-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-042-4/+5
| | | | | * spsize/size.c: Reflect SPARC modifcation to get rid of NO_TABLE_MOVE and references to _CPU_Trap_Table_area.
* 2001-03-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-293-5/+78
| | | | | | | * Per PR147 addressed problems when reseting and inserting a timer into a timer chain that did not honor time passage since the last time the timer server was scheduled and the new insertion. * sp31/sp31.scn, sp31/task1.c: Added test code to detect this case.
* 2001-03-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-283-5/+6
| | | | | * Side-effect of PR132. * sp21/system.h: Now must explicitly request NULL driver.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-289-9/+27
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2835-35/+41
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * tm01/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm02/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm03/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm04/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm05/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm06/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm07/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm08/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm09/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm10/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm11/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm12/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm13/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm14/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm15/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm16/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm17/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm18/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm19/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm20/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm21/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm22/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm23/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm24/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm25/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm26/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm27/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm28/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm29/Makefile.am: Remove AUTOMAKE_OPTIONS. * tmck/Makefile.am: Remove AUTOMAKE_OPTIONS. * tmoverhd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-285-5/+11
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * tmitronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-283-3/+10
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2834-34/+40
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * sp01/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp02/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * sp03/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp04/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp05/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp06/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp07/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp08/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp09/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp11/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp12/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp13/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp14/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp15/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp16/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp17/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp19/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp20/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp21/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp22/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp23/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp24/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp25/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp26/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp27/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp28/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp29/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp30/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp31/Makefile.am: Remove AUTOMAKE_OPTIONS. * spfatal/Makefile.am: Remove AUTOMAKE_OPTIONS. * spsize/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2813-13/+19
| | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS. * base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS. * cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS. * hello/Makefile.am: Remove AUTOMAKE_OPTIONS. * minimum/Makefile.am: Remove AUTOMAKE_OPTIONS. * paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS. * ticker/Makefile.am: Remove AUTOMAKE_OPTIONS. * unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2828-28/+34
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx02/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx03/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx04/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx05/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx06/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx07/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx08/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx09/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx10/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx11/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx12/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx13/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxcancel/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxchroot01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxfile01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxhdrs/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxmount/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxmsgq01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxreaddir/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxsem01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxstat/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxtime/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxtimer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2845-45/+51
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * mp01/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp01/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp01/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2811-11/+17
| | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * cpuuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * malloctest/Makefile.am: Remove AUTOMAKE_OPTIONS. * monitor/Makefile.am: Remove AUTOMAKE_OPTIONS. * putenvtest/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems++/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtmonuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * stackchk/Makefile.am: Remove AUTOMAKE_OPTIONS. * termios/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2812-12/+18
| | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * itronhello/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * itronmbf01/Makefile.am: Remove AUTOMAKE_OPTIONS. * itronmbox01/Makefile.am: Remove AUTOMAKE_OPTIONS. * itronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS. * itrontask01/Makefile.am: Remove AUTOMAKE_OPTIONS. * itrontask02/Makefile.am: Remove AUTOMAKE_OPTIONS. * itrontask03/Makefile.am: Remove AUTOMAKE_OPTIONS. * itrontask04/Makefile.am: Remove AUTOMAKE_OPTIONS. * itrontime01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill2002-03-203-2/+9
| | | | | | | * PR145. * sp04/task1.c, sp04/tswitch.c: Test fails if other tasks present in system (e.g. driver tasks). Also exit on minimum number of switches not precise number.
* 2001-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-294-6/+88
| | | | | | | | | * Fixed bug where resetting a timer that was not at the head of one of the task timer chains resulted in the Timer Server task waking up too far in the future. * Added rtems_timer_get_information() directive to support testing. * sp31/init.c, sp31/system.h, sp31/task1.c: Modified to test for above condition.
* 2001-01-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-225-1/+19
| | | | | * sp09/screen14.c, sp09/sp09.scn, sp30/init.c, sp31/init.c: Modified because priority added as argument to rtems_timer_initiate_server().
* 2001-01-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-1622-2/+878
| | | | | | | | | | | | | * Added tests for task-based timers. This included the new tests sp30 and sp31. * Makefile.am, configure.ac: Modified to reflect new tests and files. * sp09/screen14.c, sp09/sp09.scn: Modified to add error checks for task-based timer services. * sp30/.cvsignore, sp30/Makefile.am, sp30/init.c, sp30/resume.c, sp30/sp30.doc, sp30/sp30.scn, sp30/system.h, sp30/task1.c, sp31/.cvsignore, sp31/Makefile.am, sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/sp31.doc, sp31/sp31.scn, sp31/system.h, sp31/task1.c: New files.
* 2001-11-26 Ralf CorsepiusJoel Sherrill2001-11-262-1/+4
| | | | * cdtest/main.cc: Remove RTEMS_TEST_IO_STREAM.
* 2001-11-08 Jiri Gaisler <jiri@gaisler.com>Joel Sherrill2001-11-082-7/+21
| | | | | | | This fix is response to test results reported by Jerry Needell <jerry.needell@unh.edu> for the SPARC/ERC32 and tracked as PR80. * tm27/task1.c: Account for overhead in starting and stopping the timer.
* 2001-11-07 Jennifer Averett <jennifer@OARcorp.com>Joel Sherrill2001-11-072-1/+12
| | | | | | | | Reported by Ibragimov Ilya <ibr@oktet.ru> and tracked as PR63. * psxstat/test.c: Fix test ENOTDIR to correspond to chdir() change. Since we check permissions before evaluating enough to see if it a regular file or directory, this hack is needed to make the regular file executable.
* 2001-11-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-071-2/+7
| | | | | | Tracked as PR72 but related to the object id problem (PR36) reported by Todor.Todorov@barco.com. * include/tmacros.h: Added fatal_directive_check_status_only().
* 2001-11-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-071-0/+6
| | | | | | | Tracked as PR72 but related to the object id problem (PR36) reported by Todor.Todorov@barco.com. but discovered independently. * include/tmacros.h: Added fatal_directive_check_status_only().
* 2001-11-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-074-3/+12
| | | | | | | | Tracked as PR72 but related to the object id problem (PR36) reported by Todor.Todorov@barco.com. * mp03/delay.c: Dispatch disable level is actually 1 not 0. * mp13/system.h: Configure enough tasks (CONFIGURE_MAXIMUM_TASKS=3). * mp14/delay.c: Dispatch disable level may be arbitrarily > 0.
* 2001-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-012-0/+7
| | | | | | * sp26/system.h: Properly account for stack memory used by this test. Reported by Jerry Needell <jerry.needell@unh.edu> and processed as PR78.
* 2001-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-012-1/+8
| | | | | | * rtems++/Makefile.am: Make sure debug variant of librtems++ is linked against. Reported by Jerry Needell <jerry.needell@unh.edu> and processed as PR78.
* 2001-10-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-252-1/+5
| | | | * rtems++/Makefile.am: Pick up -lrtems++ even when debug.
* 2001-10-25 Eric Norum <eric.norum@usask.ca>Joel Sherrill2001-10-252-0/+6
| | | | | * cdtest/system.h: Configure 1 semaphore. This probably covers up not defining one for the GCC C++ Run-Time Libraries.
* 2001-10-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-172-1/+5
| | | | * paranoia/Makefile.am: Use LD_LIBS = -lm to make automake-1.5 happy.
* 2001-10-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-173-4/+7
| | | | | * configure.ac: Apply RTEMS_CPU_SUBDIRS for potential CPU-subdirs. * Makefile.am: Require automake-1.5.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-127-6/+6
| | | | | | * unlimited/init.c, unlimited/system.h, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc: Fixed typo.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1212-0/+665
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1124-0/+84
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-1/+5
| | | | * Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-1/+3
| | | | | * libtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy. * rtems++/Makefile.am: LD_FLAGS = -lrtems++.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-242-1/+5
| | | | * tmtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
| | | | * tmitrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
| | | | * sptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-241-2/+0
| | | | | | * minimum/Makefile.am: Fix comments to make automake-1.5 happy. * sample.am: Use TMPINSTALL_FILES = to make automake-1.5 happy. * cdtest/Makefile.am: Remove LD_LIBS.
| | | | * psxtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
| | | | * mptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-243-3/+6
| | | | | * libtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy. * rtems++/Makefile: Remove LD_LIBS.
| | | | * itrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-243-2/+8
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-1932-31/+65
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tm27/Makefile.am: include leaf.am instead of leaf.cfg. * tm26/Makefile.am: include leaf.am instead of leaf.cfg. * tm24/Makefile.am: include leaf.am instead of leaf.cfg. * tm16/Makefile.am: include leaf.am instead of leaf.cfg. * tm18/Makefile.am: include leaf.am instead of leaf.cfg. * tm02/Makefile.am: include leaf.am instead of leaf.cfg. * tm10/Makefile.am: include leaf.am instead of leaf.cfg. * tm11/Makefile.am: include leaf.am instead of leaf.cfg. * tm15/Makefile.am: include leaf.am instead of leaf.cfg. * tm19/Makefile.am: include leaf.am instead of leaf.cfg. * tm04/Makefile.am: include leaf.am instead of leaf.cfg. * tm17/Makefile.am: include leaf.am instead of leaf.cfg. * tm28/Makefile.am: include leaf.am instead of leaf.cfg. * tmck/Makefile.am: include leaf.am instead of leaf.cfg. * tm08/Makefile.am: include leaf.am instead of leaf.cfg. * tm12/Makefile.am: include leaf.am instead of leaf.cfg. * tm03/Makefile.am: include leaf.am instead of leaf.cfg. * tm13/Makefile.am: include leaf.am instead of leaf.cfg. * tm29/Makefile.am: include leaf.am instead of leaf.cfg. * tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg. * tm20/Makefile.am: include leaf.am instead of leaf.cfg. * tm09/Makefile.am: include leaf.am instead of leaf.cfg. * tm01/Makefile.am: include leaf.am instead of leaf.cfg. * tm21/Makefile.am: include leaf.am instead of leaf.cfg. * tm07/Makefile.am: include leaf.am instead of leaf.cfg. * tm25/Makefile.am: include leaf.am instead of leaf.cfg. * tm22/Makefile.am: include leaf.am instead of leaf.cfg. * tm06/Makefile.am: include leaf.am instead of leaf.cfg. * tm05/Makefile.am: include leaf.am instead of leaf.cfg. * tm14/Makefile.am: include leaf.am instead of leaf.cfg. * tm23/Makefile.am: include leaf.am instead of leaf.cfg.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-192-1/+5
| | | | * tmitronsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-1930-29/+61
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp20/Makefile.am: include leaf.am instead of leaf.cfg. * sp02/Makefile.am: include leaf.am instead of leaf.cfg. * sp19/Makefile.am: include leaf.am instead of leaf.cfg. * sp11/Makefile.am: include leaf.am instead of leaf.cfg. * sp25/Makefile.am: include leaf.am instead of leaf.cfg. * sp04/Makefile.am: include leaf.am instead of leaf.cfg. * spsize/Makefile.am: include leaf.am instead of leaf.cfg. * sp01/Makefile.am: include leaf.am instead of leaf.cfg. * sp16/Makefile.am: include leaf.am instead of leaf.cfg. * sp05/Makefile.am: include leaf.am instead of leaf.cfg. * sp09/Makefile.am: include leaf.am instead of leaf.cfg. * spfatal/Makefile.am: include leaf.am instead of leaf.cfg. * sp06/Makefile.am: include leaf.am instead of leaf.cfg. * sp23/Makefile.am: include leaf.am instead of leaf.cfg. * sp28/Makefile.am: include leaf.am instead of leaf.cfg. * sp03/Makefile.am: include leaf.am instead of leaf.cfg. * sp29/Makefile.am: include leaf.am instead of leaf.cfg. * sp13/Makefile.am: include leaf.am instead of leaf.cfg. * sp27/Makefile.am: include leaf.am instead of leaf.cfg. * sp14/Makefile.am: include leaf.am instead of leaf.cfg. * sp07/Makefile.am: include leaf.am instead of leaf.cfg. * sp15/Makefile.am: include leaf.am instead of leaf.cfg. * sp17/Makefile.am: include leaf.am instead of leaf.cfg. * sp22/Makefile.am: include leaf.am instead of leaf.cfg. * sp12/Makefile.am: include leaf.am instead of leaf.cfg. * sp26/Makefile.am: include leaf.am instead of leaf.cfg. * sp21/Makefile.am: include leaf.am instead of leaf.cfg. * sp24/Makefile.am: include leaf.am instead of leaf.cfg. * sp08/Makefile.am: include leaf.am instead of leaf.cfg.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-1910-10/+23
| | | | | | | | | | | | | * unlimited/Makefile.am: include leaf.am instead of leaf.cfg. * base_mp/node2/Makefile.am: include leaf.am instead of leaf.cfg. * base_mp/node1/Makefile.am: include leaf.am instead of leaf.cfg. * hello/Makefile.am: include leaf.am instead of leaf.cfg. * base_sp/Makefile.am: include leaf.am instead of leaf.cfg. * paranoia/Makefile.am: include leaf.am instead of leaf.cfg. * cdtest/Makefile.am: include leaf.am instead of leaf.cfg, use make-cxx-exe. * ticker/Makefile.am: include leaf.am instead of leaf.cfg. * minimum/Makefile.am: include leaf.am instead of leaf.cfg.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-1925-24/+51
| | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/Makefile.am: include leaf.am instead of leaf.cfg. * psx11/Makefile.am: include leaf.am instead of leaf.cfg. * psxcancel/Makefile.am: include leaf.am instead of leaf.cfg. * psx02/Makefile.am: include leaf.am instead of leaf.cfg. * psx13/Makefile.am: include leaf.am instead of leaf.cfg. * psxtime/Makefile.am: include leaf.am instead of leaf.cfg. * psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg. * psx07/Makefile.am: include leaf.am instead of leaf.cfg. * psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg. * psxtimer/Makefile.am: include leaf.am instead of leaf.cfg. * psx10/Makefile.am: include leaf.am instead of leaf.cfg. * psx08/Makefile.am: include leaf.am instead of leaf.cfg. * psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg. * psxfile01/Makefile.am: include leaf.am instead of leaf.cfg. * psx05/Makefile.am: include leaf.am instead of leaf.cfg. * psx09/Makefile.am: include leaf.am instead of leaf.cfg. * psxmount/Makefile.am: include leaf.am instead of leaf.cfg. * psxstat/Makefile.am: include leaf.am instead of leaf.cfg. * psx12/Makefile.am: include leaf.am instead of leaf.cfg. * psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg. * psxsem01/Makefile.am: include leaf.am instead of leaf.cfg. * psx03/Makefile.am: include leaf.am instead of leaf.cfg. * psx04/Makefile.am: include leaf.am instead of leaf.cfg. * psx06/Makefile.am: include leaf.am instead of leaf.cfg.
