The Classic binary semaphores without a locking protocol
(RTEMS_BINARY_SEMAPHORE) could be released by everyone, e.g. in contrast
to the POSIX mutexes (all variants) or the Classic binary semphores with
priority inheritance or ceiling, there was no owner check in the release
path.
This behaviour was a bit unexpected and not documented. Add an owner
check to the release path. Update sptests/sp42 accordingly.
This change has nothing to do with the simple binary semaphores
(RTEMS_SIMPLE_BINARY_SEMAPHORE) which have no owner at all.
Update #2725
Support creating directories for files with a path depth greater than 1. Some
tar files can have files with a path depth greater than 1 and no directory
entry in the tar file to create a directory.
Support overwriting existing files and directories failing in a similar
way to tar on common hosts. If a file is replaced with a file delete the
file and create a new file. If a directory replaces a file remove the file
and create the directory. If a file replaces a directory remove the directory,
and if the directory is not empty and cannot be removed report an error. If a
directory alreday exists do nothing leaving the contents untouched.
The untar code now shares the common header parsing and initial processing
with the actual writes still separate. No changes to the IMFS have been made.
Updates #2415.
Closes #2207.
Demonstrate that a read-modify-write atomic operation may be necessary
on some archtitectures to observe the latest value written.
Remove superfluous support for simple binary semaphores. With this we
can get rid of the CORE_MUTEX_NESTING_BLOCKS variant.
Move the safety check performed by
_CORE_mutex_Check_dispatch_for_seize() out of the performance critical
path and generalize it. Blocking on a thread queue with an unexpected
thread dispatch disabled level is illegal in all system states.
Add the expected thread dispatch disable level (which may be 1 or 2
depending on the operation) to Thread_queue_Context and use it in
_Thread_queue_Enqueue_critical().
Add _Thread_queue_Context_set_MP_callout() to simplify
_Thread_queue_Context_initialize(). This makes it possible to more
easily add additional fields to Thread_queue_Context.
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Close #2721.
Close #2720.
Close #2719.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
of this patch set.
Close #2718.
Uniformly use *_Get() to get an object by identifier with a lock
context.
Use _Objects_Get_local() for _Semaphore_Get_interrupt_disable() to get
rid of the location parameter. Move remote object handling to semaphore
MPCI support.
Update #2555.
This is a preparation to remove the Giant lock.
Update #2555.
Rename _ISR_Disable() into _ISR_Local_disable(). Rename _ISR_Enable()
into _ISR_Local_enable(). Remove _Debug_Is_owner_of_giant().
Update #2555.
Rename _ISR_Disable_without_giant() into _ISR_Local_disable(). Rename
_ISR_Enable_without_giant() into _ISR_Local_enable().
Update #2555.
Replace _Thread_Disable_dispatch() with _Thread_Dispatch_disable().
Replace _Thread_Enable_dispatch() with _Thread_Dispatch_enable().
Update #2555.
Replace _Thread_Get() with _Thread_Get_interrupt_disable() to avoid the
Giant lock.
Update #2555.
Use _Semaphore_Get_interrupt_disable() instead.
Update #2555.
Update #2555.
Add _Thread_Change_life_locked() as a general function to alter the
thread life state. Use it to implement _Thread_Set_life_protection() as
a first step.
Update #2555.
Update #2626.
Update #2714.
Added only for evaluation purposes. We have to compare the performance
against the ticket lock on the interesting platforms via
smptests/smplock01.
The following GCC shortcoming affects the MCS lock:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=66867
Avoid output in signal handler to not disturb the timings which are
checked in this test. Use asserts to ensure proper signal handler
invocations.
POSIX mandates that an error code is returned and not -1 plus errno.
Close #2715.
Update #2714.
POSIX recommends ESRCH in case no thread exists for the specified
identifier.
Close #2713.
Fix overall clock tick count. Change introduced by
90d8567d34a6d80da04b1cb37b667a3173f584c4.
Update #2554.
In addition protect scheduler of thread by thread state lock. Enables
use of scheduler per-instance locks.
Update #2555.
The priority inheritance and ceiling CORE mutexes wrongly used the FIFO
queueing discipline. Delete misleading _CORE_mutex_Is_priority(). Bug
introduced by 1e1a91ed11458ddbb27b94d0001d8f0fc2ef7a97.
Add test sptests/spmutex01, since no existing uni-processor test covered
the thread priority queueing discipline for CORE mutexes.
The _Objects_Information_table is statically initialized. So, we can
make it read-only.
Update #2494.
Update #2555.
Account for the terminating null character. Use _POSIX_PATH_MAX instead
of NAME_MAX according to _POSIX_Semaphore_Manager_initialization() and
_POSIX_Message_queue_Manager_initialization().
Start with a copy of the Priority SMP scheduler implementation.
Update #2510.
Remove support for strict order mutexes.
Close #2124.
