* | Fixed verificaiton checks to call correct macro if dispatch is disabled. | Jennifer Averett | 1999-11-15 | 1 | -7/+12 |
* | + Added check that a task could be sent to a dormant state | Jennifer Averett | 1999-11-15 | 4 | -12/+94 |
| | | | | | | | | then sta_tsk used to restart the task to its initial state. + Added calls to ref_tsk to yellow paths for suspended and ready but not running tasks. + Fixed output file to correctly state test name + Added priority of preempt to the header file. Allows ref_tsk verification. | ||||
* | + Changed preempt routine into two dummy tasks one that is in dormant | Jennifer Averett | 1999-11-15 | 3 | -14/+94 |
| | | | | | | | | state and one that is in non-dormant state. + Increased the priority of the Init task to force the dummy tasks to run first. + Added calls to ref_tsk to verify the state of the dummy tasks and test ref_tsk. | ||||
* | + Modified calls to use TSK_SLF for calls to self. | Joel Sherrill | 1999-11-12 | 1 | -25/+24 |
| | | | | + Modified calls to use the task id macro for calls to the PREEMPT task. | ||||
* | + Added comments on paths tested. | Joel Sherrill | 1999-11-12 | 2 | -1/+14 |
* | + Added check for priority over 256. | Joel Sherrill | 1999-11-12 | 1 | -1/+4 |
| | | | | + Modified output to correctly state the error. | ||||
* | Added comments for path's tested. | Joel Sherrill | 1999-11-12 | 1 | -0/+3 |
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 6 | -8/+9 |
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 2 | -6/+11 |
| | | | | Changed output to reflect what was actually being tested. | ||||
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 4 | -5/+9 |
| | | | | Increased stack space. | ||||
* | Enabled after merging message buffer code. | Joel Sherrill | 1999-11-12 | 1 | -6/+2 |
* | Added comment block and removed include of deleted file. | Joel Sherrill | 1999-11-12 | 1 | -1/+4 |
* | Screen updated. | Joel Sherrill | 1999-11-11 | 1 | -0/+2 |
* | Added new test sp28 to test the task variable directives. | Joel Sherrill | 1999-11-11 | 4 | -1/+98 |
* | General cleanup. Test documentation improved. The message buffer test | Joel Sherrill | 1999-11-10 | 15 | -22/+81 |
| | | | | | prints a message instead of actually testing since the message buffer implementation is not in yet. | ||||
* | rtems_semaphore_flush test from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-10 | 4 | -1/+104 |
* | Combination of committing some new files which had been overlooked | Joel Sherrill | 1999-11-10 | 5 | -1/+95 |
| | | | | and adding code which installed screens for itron tests. | ||||
* | Added support for ITRON tests. | Joel Sherrill | 1999-11-10 | 1 | -0/+2 |
* | Added more tasking tests. | Joel Sherrill | 1999-11-09 | 1 | -1/+2 |
* | Merged tests from Task group. | Joel Sherrill | 1999-11-09 | 30 | -38/+1553 |
* | Added nesting count for suspend/resume. | Joel Sherrill | 1999-11-09 | 1 | -1/+1 |
* | Changed B, H, and W variables to BVar, HVar, and WVar to avoid conflicts | Joel Sherrill | 1999-11-09 | 1 | -35/+35 |
| | | | | | with ITRON 3.0 data types regardless of how dumb it is to name types with a simple letter. | ||||
* | Renamed classes to avoid single letter class names. | Joel Sherrill | 1999-11-09 | 1 | -10/+10 |
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 17 | -0/+1249 |
| | | | | for RTEMS. | ||||
* | New test for POSIX Message Queues added. | Joel Sherrill | 1999-11-09 | 4 | -1/+88 |
* | New files. | Joel Sherrill | 1999-11-09 | 3 | -0/+222 |
* | This is another pass at making sure that nothing outside the BSP | Joel Sherrill | 1999-11-05 | 7 | -20/+9 |
| | | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | ||||
* | The files in libcpu should not be directly dependent on any BSP. In | Joel Sherrill | 1999-11-04 | 2 | -0/+4 |
| | | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated. | ||||
* | Minor changes to make the screen match a bit better. | Joel Sherrill | 1999-11-02 | 2 | -4/+4 |
* | Minor fixes to make screen match a bit better. | Joel Sherrill | 1999-11-02 | 2 | -11/+15 |
* | Added more proper checking of F_GETFL and F_SETFL. | Joel Sherrill | 1999-11-02 | 1 | -5/+17 |
| | | | | | | Disabled test of F_DUPFD since it does not work. Added comment to indicate that seekdir(NULL) was being called. | ||||
* | Backed out change that increased the minimum stack size since it | Joel Sherrill | 1999-11-02 | 31 | -31/+0 |
| | | | | | was unnecessary. The real fix was an alignment error in the object extend memory allocation scheme. | ||||
* | Modified to use minimum stack size and reserve the necessary amount | Joel Sherrill | 1999-11-02 | 5 | -7/+13 |
| | | | | of space in the workspace. | ||||
* | Increased stack space for all initialization tasks in tmtests. | Joel Sherrill | 1999-11-01 | 31 | -0/+31 |
* | Increased stack space of a task. | Joel Sherrill | 1999-11-01 | 2 | -3/+5 |
* | Increased stack space of task 2. | Joel Sherrill | 1999-11-01 | 2 | -2/+2 |
* | Increased stack space for a task. | Joel Sherrill | 1999-11-01 | 2 | -1/+3 |
* | Increased stack space for task 1. | Joel Sherrill | 1999-11-01 | 2 | -2/+2 |
* | New test added - psxcancel. This is just a shell for now. | Joel Sherrill | 1999-10-28 | 3 | -1/+32 |
* | Added sp26 which tests the rtems_task_is_suspended directive. | Joel Sherrill | 1999-10-25 | 6 | -1/+250 |
* | Modified to ease comparison of screen to target output. | Joel Sherrill | 1999-10-25 | 4 | -1092/+1092 |
* | Modified to reflect test change where reinitialize mutex test case was | Joel Sherrill | 1999-10-25 | 1 | -1/+1 |
| | | | | removed. | ||||
* | Removed reinitialize mutex test case to reflect earlier code change in | Joel Sherrill | 1999-10-25 | 1 | -1/+8 |
| | | | | the executive. | ||||
* | Increased stack size of initialization thread. | Joel Sherrill | 1999-10-21 | 1 | -0/+2 |
* | Removed ifdef on go32. | Joel Sherrill | 1999-10-05 | 1 | -1/+1 |
* | Modifications necessary to support testing of exitting a pthread from | Joel Sherrill | 1999-10-04 | 6 | -41/+156 |
| | | | | Charles-Antione Gauthier <charles.gauthier@iit.nrc.ca>. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bug | Joel Sherrill | 1999-10-04 | 11 | -36/+36 |
| | | | | where wrapup left pieces out of the librtemsall.a. | ||||
* | New test for getenv/putenv added by Joel. | Joel Sherrill | 1999-10-04 | 2 | -1/+60 |
* | Reran and replaced screen after report from Gerwin Pfab <pb@schenk.isar.de>. | Joel Sherrill | 1999-08-18 | 1 | -7/+9 |
* | New configuration files added by patch from | Joel Sherrill | 1999-08-10 | 10 | -0/+161 |
| | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de>". |
