* spsize/size.c: i960 obsoleted and all references removed.
* aclocal/rtems-cpu-subdirs.m4: Remove (unused).
* * configure.ac: Remove RTEMS_CPU_SUBDIRS.
* aclocal/version.m4: Updated to rtems-4.6.99.1.
* configure.ac: Add CXX-checks. New conditionals CXXTESTS, MPTESTS,
NETTESTS. Add iostream/.
* Makefile.am, base_mp/node1/Makefile.am, base_mp/node2/Makefile.am
cdtest/Makefile.am, loopback/Makefile.am, pppd/Makefile.am:
Reflect changes above.
* cdtest/main.cc: Adaptation to new C++ standards.
* iostream/Makefile.am, iostream/init.cc, iostream/iostream.doc,
iostream/iostream.scn, iostream/system.h:
New (C++ variant of hello).
PR 610/bsps
* tm27/task1.c: Use _RTEMS_RMTEST27 instead of RTEMS_TM27.
Unconditionally include <tm27.h>.
PR 613/bsps
* configure.ac: Add AC_ARG_VAR([MAX_LONG_TEST_DURATION],...).
* mp14/node1/Makefile.am, mp14/node2/Makefile.am: Add AM_CPPFLAGS +=
-DMAX_LONG_TEST_DURATION=$(MAX_LONG_TEST_DURATION).
PR 611/bsps
* tm27/task1.c: Follow conventions for tm27 and do not add another
macro definition.
* aclocal/rtems-top.m4: Add project_top/with_project_top processing.
* tm02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm15/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm16/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm17/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm18/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm19/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm20/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm21/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm22/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm23/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm24/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm25/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm26/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm27/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm28/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm29/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tmck/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tmoverhd/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp15/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp16/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp17/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp19/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp20/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp21/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp22/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp23/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp24/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp25/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp26/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp27/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp28/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp29/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp30/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp31/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp32/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* spfatal/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* spsize/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* base_sp/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* cdtest/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* fileio/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* hello/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* loopback/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* minimum/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* paranoia/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* pppd/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* ticker/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* unlimited/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx13/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxcancel/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxchroot01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxfile01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxmount/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxmsgq01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxreaddir/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxstat/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxtime/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxtimer/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* malloctest/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* monitor/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* putenvtest/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* rtems++/System.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* rtmonuse/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* stackchk/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* termios/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itronmbf01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itronmbox01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itronsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontask01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontask02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontask03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontask04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* itrontime01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tmitronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* sp07/buffered_io.c: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
* fileio/init.c: Include <rtems/dosfs.h> instead of <dosfs.h>.
* psxcancel/init.c: Include <rtems/console.h> instead of <console.h>.
* psxmount/test.c: Include <rtems/imfs.h> instead of <imfs.h>.
* psxreaddir/test.c: Include <rtems/imfs.h> instead of <imfs.h>.
* psxstat/test.c: Include <rtems/imfs.h> instead of <imfs.h>.
* itronhello/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itronmbf01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itronmbox01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontask01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontask02/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontask03/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontask04/system.h: Include <rtems/itron.h> instead of <itron.h>.
* itrontime01/system.h: Include <rtems/itron.h> instead of <itron.h>.
PR 595/tests
* sp13/fillbuff.c, sp13/init.c, sp13/putbuff.c, sp13/system.h,
sp13/task1.c, sp13/task2.c: Fill_buffer() in fillbuff.c overruns the
supplied buffer due to confusion in the definition of MESSAGE_SIZE.
Some files in the sp13 test treat MESSAGE_SIZE as a count of bytes,
others treat it as a count of longs.
PR 596/tests
* sp32/init.c: A missing definition of TEST_INIT before including
<tmacros.h> means that buffered output will not work even if selected
in buffer_test_io.h.
PR 597/tests
* tm02/system.h, tm03/system.h, tm04/system.h, tm05/system.h,
tm06/system.h, tm07/system.h, tm08/system.h, tm10/system.h,
tm11/system.h, tm12/system.h, tm13/system.h, tm14/system.h,
tm15/system.h, tm16/system.h, tm17/system.h, tm18/system.h,
tm19/system.h, tm21/system.h, tm22/system.h, tm23/system.h,
tm24/system.h, tm25/system.h, tm26/system.h, tm27/system.h,
tm27/task1.c, tm29/system.h: The actual workspace needed by the
tmtests depends on OPERATION_COUNT, but the definitions of
CONFIGURE_MAXIMIM_xxx in the their system.h files do not reflect
this. This results in unnecessary memory exhaustion on small-memory
systems such as the SS555.
* mp02/task1.c, mp03/system.h, mp03/task1.c, mp04/task1.c,
mp05/system.h, mp06/task1.c, mp07/task1.c, mp08/task1.c,
mp09/recvmsg.c, mp09/sendmsg.c, mp09/task1.c, mp10/task1.c,
mp11/init.c, mp12/init.c, mp13/task1.c, mp14/evtask1.c,
mp14/evtmtask.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c,
mp14/smtask1.c, mp14/system.h: Convert to using c99 fixed size
types.
* include/timesys.h: Convert to using c99 fixed size types.
* psx06/init.c, psx06/system.h, psx06/task.c, psx06/task2.c: Convert
* sp02/task1.c, sp04/system.h, sp04/task1.c, sp04/tswitch.c,
sp05/task1.c, sp06/task1.c, sp09/screen01.c, sp09/screen07.c,
sp09/screen12.c, sp09/system.h, sp09/task3.c, sp11/task1.c,
sp12/pridrv.c, sp12/pritask.c, sp12/system.h, sp13/task1.c,
sp13/task2.c, sp13/task3.c, sp14/system.h, sp15/system.h,
sp16/system.h, sp17/system.h, sp19/first.c, sp19/fptask.c,
sp19/inttest.h, sp19/system.h, sp19/task1.c, sp20/init.c,
sp20/system.h, sp20/task1.c, sp23/system.h, sp24/init.c,
sp25/system.h, sp30/init.c, spfatal/fatal.c, spfatal/puterr.c,
spfatal/system.h, spsize/size.c: Convert to using c99 fixed size
types.
* cpuuse/system.h, cpuuse/task1.c, cpuuse/tswitch.c, monitor/init.c,
monitor/system.h, rtems++/System.h, rtems++/Task1.cc,
rtems++/Task2.cc, rtems++/Task3.cc, rtmonuse/init.c,
rtmonuse/system.h, rtmonuse/task1.c, stackchk/blow.c: Convert to
* fileio/init.c, fileio/system.h, ticker/system.h, ticker/tasks.c,
unlimited/init.c, unlimited/test1.c, unlimited/test2.c,
unlimited/test3.c: Convert to using c99 fixed size types.
* aclocal/rtems-top.m4: s/RTEMS_RTEMS/RTEMS_ROOT (typo).
* include/timesys.h, tm01/task1.c, tm02/task1.c, tm03/task1.c,
tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c,
tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c,
tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm20/task1.c,
tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c,
tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c,
tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Convert to using
* Makefile.am: Remove include from SUBDIRS.
* aclocal/check-custom-bsp.m4: Fix minor typo.
* include/tmacros.h: Convert to using c99 fixed size types.
* aclocal/rtems-top.m4: Add rtems_rootdir.
* aclocal/check-custom-bsp.m4: Check for $RTEMS_BSP.cfg in $rtems_rootdir.
* aclocal/rtems-top.m4: Add 2nd arg to RTEMS_TOP.
Rework with_project_root/PROJECT_ROOT and with_project_top/PROJECT_TOPdir.
Add --enable-rtems-root. Rework RTEMS_ROOT.
