Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Add RTEMS_FATAL_SOURCE_SPURIOUS_INTERRUPT as the fatal source for
spurious interrupts. Use the interrupt vector number of the spurious
interrupt for the fatal code.
Update #3269.
Prefer RTEMS_FATAL_SOURCE_EXCEPTION over
INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT since the fatal code
(rtems_exception_frame) provides more context.
This program contained an optional test case. It was enabled by the
RTEMS_COVERAGE define. The functions under test are not implemented by RTEMS.
Update smpstrongapa01 to account for task shifting.
Use BSP_INTERRUPT_VECTOR_COUNT instead of BSP_INTERRUPT_VECTOR_MAX.
Update #3269.
This define represents the last valid interrupt vector number.
Update #3269.
Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector
numbers start with zero.
The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit
and building all BSPs.
Update #3269.
This adds the possibility to open an I2C bus with O_NONBLOCK (or set it
later via fcntl) to get non-blocking transmissions. This means that if
the bus is busy, a read, write or transfer ioctl will return with a
EAGAIN errno.
Make the initialization of the per-CPU data optional.
Change license to BSD-2-Clause according to file history and
re-licensing agreement.
Update #3053.
Make sure that the linker sets work if placed in a library (this is how
they are used in RTEMS).
GCC originally needed this 20 years ago. No longer needed, so it
is being removed.
Closes #4391
The addition of the entire *utime*() family of functions resulted
in this call returning ENOENT not ENXIO. This is better aligned
with the POSIX definition of the methods.
Improved tests for utime() and utimes() and update license.
Close #4399
This adds a rtems_mutex_try_lock and a rtems_recursive_mutex_try_lock.
Update #4440.
Close #4413.
telnetd01 test cannot be run without a network stack, so this test is being
moved to the rtems-net-legacy repository.
Close #4410.
Add a library for support functions used by validation tests. Rename
tc-support.* to tx-support.* since this file does not contain test
cases.
Add a parameter to _TOD_Validate() to disable the validation of the
ticks member.
There are two reasons for this change. Firstly, in
rtems_task_wake_when() was a double check for time_buffer == NULL (one
in rtems_task_wake_when() and one in _TOD_Validate()). Secondly, the
ticks member is ignored by rtems_task_wake_when(). This was done with a
write of zero to the ticks member and thus a modification of the
user-provided structure. Now the structure is no longer modified.
Using a mask parameter is quite efficient. You just have to load an
immediate value and there are no additional branches in _TOD_Validate().
Close #4406.
This patch fixes bug #4403. Directives
* rtems_timer_fire_when()
* rtems_timer_server_fire_when()
* rtems_task_wake_when()
are documented to return RTEMS_INVALID_ADDRESS when their time-of-day
argument is NULL. But actually they return RTEMS_INVALID_CLOCK. To fix
the issue this patch changes _TOD_Validate() to return a
status code instead of just true/false.
Close #4403
In the action requirements, some pre-conditions are not applicable
depending on the state of other pre-conditions. There is no particular
order in the pre-conditions, so we have to check the N/A status
individually.
In POSIX, zero size memory allocations are implementation-defined
behaviour. The implementation has two options:
https://pubs.opengroup.org/onlinepubs/9699919799/functions/malloc.html
https://pubs.opengroup.org/onlinepubs/9699919799/functions/posix_memalign.html
Linux and FreeBSD return a unique pointer for zero size memory
allocations. Return NULL on RTEMS to more likely catch the use of a
zero size memory area by erroneous applications.
Update #4390.
In case the processor set is not large enough to contain the processor
set owned by the scheduler return RTEMS_INVALID_SIZE instead of
RTEMS_INVALID_NUMBER. This is more in line with other directives since
the issue is related to the size of an object.
Close #4401.
Added conditionals to ensure that long double function tests were only
built when newlib has long double math functions.
The zero size allocations had no consistent behaviour in RTEMS. For
example, malloc( 0 ) returned NULL and posix_memalign( &p, align, 0 )
returned in p a unique pointer (or NULL if no memory is available). In
allocations. Use this approach for RTEMS as well throughout the memory
allocation directives
Close #4390.
Flexible array members must not appear in the middle of a structure.
Close #3866.
Changed the way the tests were structured, added rtems_test_assert()'s,
updated psx13.scn and the license.
Update #3899
affinity set of the task return RTEMS_INVALID_SIZE instead of
Close #4393.
Since there are already excessive NULL pointer checks in the Classic
API, do this also in rtems_task_construct().
Update #3959.
API, do this also in rtems_message_queue_construct().
Update #4007.
This patch fixes issue #4338 by changing _TOD_Validate()
to only accept years till 2105. This requires another patch
to change the documentation of rtems_clock_set() and other
affected API functions (indicating the end date is 2105 not 2514).
I tried to support till year 2514 but it turned out that
this needs changing the Timer Manager too. That in turn
would mean to change _TOD_Seconds_since_epoch( void )
from 32 to 64 bit. Sebastian pointed out that a naive extension
leads to trouble with 32 bit processors. He deemed a safe
re-implementation too costly performance wise considering
that year 2106 is far away and current binaries using RTEMS
Classic API are unlikely to be in use by 2106.
The constant TOD_SECONDS_AT_2100_03_01_00_00 in
cpukit/rtems/src/clocktodtoseconds.c happens to be wrong by
1 hour. When setting the date 2100-Feb-28 23:59:59 and then
reading the date again you will find yourself in 2100-Feb-27.
Update #4338
The multiplication to calculate the length of the memory area to
allocate may overflow. Return NULL in case of an overflow.
Close #4389.
* On some SMP platforms, all cpus are started by the
boot-loader. We need to block the secondary cpus or they
will clobber the test output.
This reverts commit 3299dda2454a8847c670a732f6c12ef1f2cc5dd0.
Update #3850
