PR 1743/cpu
* Makefile.am, configure.ac, spsize/size.c: Add Simple Priority
Scheduler as complement to existing Deterministic Priority Scheduler.
This scheduler serves both as an example and as a lighter weight
implementation for smaller systems.
* spsimplesched01/.cvsignore, spsimplesched01/Makefile.am,
spsimplesched01/init.c, spsimplesched01/spsimplesched01.doc,
spsimplesched01/spsimplesched01.scn, spsimplesched02/.cvsignore,
spsimplesched02/Makefile.am, spsimplesched02/init.c,
spsimplesched02/spsimplesched02.doc,
spsimplesched02/spsimplesched02.scn, spsimplesched03/.cvsignore,
spsimplesched03/Makefile.am, spsimplesched03/init.c,
spsimplesched03/spsimplesched03.doc,
spsimplesched03/spsimplesched03.scn: New files.
* tm26/task1.c: Update for API change.
* Makefile.am, configure.ac: Add test for Mouse Parser Engine
(Microsoft Mouse paths) and Serial Mouse Driver.
* mouse01/.cvsignore, mouse01/Makefile.am, mouse01/init.c,
mouse01/mouse01.doc, mouse01/mouse01.scn, mouse01/msmouse.c,
mouse01/serial_mouse_config.c: New files.
* sp58/init.c, sp58/sp58.scn: Account for case where left hand side
seconds field is less than.
* sp08/sp08.scn: Convert to UNIX CR/LF.
* sp08/Makefile.am, sp08/init.c, sp08/sp08.scn, sp09/screen07.c,
sp09/sp09.scn: Improve coverage. Change mode while system not up and
broadcast a message that is too large.
* sp08/system.h, sp08/task1.c: Removed.
* Makefile.am, configure.ac: Add sp73. This is a new test designed
to improve coverage of the thread yield logic.
* sp73/.cvsignore, sp73/Makefile.am, sp73/init.c, sp73/sp73.doc,
sp73/sp73.scn: New files.
* sp07/init.c: Improve coverage.
* heapwalk/init.c: Improve coverage.
* heapwalk/heapwalk.scn: Update.
* spwkspace/init.c: Adjust test to account for recent heap change on
NULL.
* psx04/init.c, psx04/psx04.scn: Remove test case made obsolete by
PR1759.
* devfs04/devfs04.scn, devfs04/init.c: Increase configuration so this
passes on sis.
* sp43/init.c, sp43/sp43.scn: Improve coverage of _Thread_Get.
* malloctest/init.c: Improve coverage.
* malloctest/malloctest.scn: Update.
* spchain/init.c: Improve coverage testing.
PR 1759/cpukit
* Makefile.am, configure.ac: Add test to use some pthread calls with
Classic Tasks.
* psxclassic01/.cvsignore, psxclassic01/Makefile.am,
psxclassic01/init.c, psxclassic01/psxclassic01.doc,
psxclassic01/psxclassic01.scn: New files.
* aclocal/env-rtemsbsp.m4, aclocal/rtems-top.m4, aclocal/version.m4:
Rename RTEMS_API into _RTEMS_API.
* aclocal/canonical-target-name.m4:
Stop pretending no_cpu* was buildable.
Derive RTEMS_CPU from "$host_cpu".
Error out if "$host" doesn't match "*-*-rtems*".
* configure.ac: Add AC_CONFIG_HEADER(config.h).
* support/src/tmtests_support.c:
loop_overhead and end_time are uint32_t's.
* support/src/spin.c, support/src/test_support.c,
support/src/tmtests_empty_function.c, support/src/tmtests_support.c:
Add HAVE_CONFIG_H.
* psxtmmutex02/init.c, psxtmthread01/init.c, psxtmthread03/init.c:
Add HAVE_CONFIG_H.
* base_mp/apptask.c, base_mp/init.c, base_sp/apptask.c, base_sp/init.c,
capture/init.c, capture/test1.c, cdtest/init.c, fileio/init.c,
hello/init.c, loopback/init.c, minimum/init.c, nsecs/empty.c,
nsecs/init.c, paranoia/init.c, paranoia/paranoia.c, pppd/init.c,
pppd/pppdapp.c, ticker/init.c, ticker/tasks.c, unlimited/init.c,
unlimited/test1.c, unlimited/test2.c, unlimited/test3.c: Add
HAVE_CONFIG_H.
* mp01/init.c, mp01/task1.c, mp02/init.c, mp02/task1.c, mp03/delay.c,
mp03/init.c, mp03/task1.c, mp04/init.c, mp04/task1.c, mp05/asr.c,
mp05/init.c, mp05/task1.c, mp06/init.c, mp06/task1.c, mp07/init.c,
mp07/task1.c, mp08/init.c, mp08/task1.c, mp09/init.c, mp09/recvmsg.c,
mp09/sendmsg.c, mp09/task1.c, mp10/init.c, mp10/task1.c, mp10/task2.c,
mp10/task3.c, mp11/init.c, mp12/init.c, mp13/init.c, mp13/task1.c,
mp13/task2.c, mp14/delay.c, mp14/evtask1.c, mp14/evtmtask.c,
mp14/exit.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c,
mp14/smtask1.c: Add HAVE_CONFIG_H.
* tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c,
tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c,
tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c,
tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c,
tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tm30/init.c,
tmck/task1.c, tmoverhd/empty.c, tmoverhd/testtask.c: Add HAVE_CONFIG_H.
* psx01/init.c, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c,
psx03/task.c, psx04/init.c, psx04/task1.c, psx04/task2.c, psx04/task3.c,
psx05/init.c, psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c,
psx06/task.c, psx06/task2.c, psx07/init.c, psx07/task.c, psx08/init.c,
psx08/task1.c, psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c,
psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c,
psx12/init.c, psx12/task.c, psx13/main.c, psx13/test.c, psx14/init.c,
psx15/init.c, psxaio01/init.c, psxaio02/init.c, psxaio03/init.c,
psxalarm01/init.c, psxautoinit01/init.c, psxautoinit02/init.c,
psxbarrier01/main.c, psxbarrier01/test.c, psxcancel/init.c,
psxcancel01/init.c, psxchroot01/main.c, psxchroot01/test.c,
psxcleanup/psxcleanup.c, psxcleanup01/init.c, psxclock/init.c,
psxcond01/init.c, psxenosys/init.c, psxfatal_support/init.c,
psxfchx01/init.c, psxfile01/main.c, psxfile01/test.c,
psxfile01/test_cat.c, psxfile01/test_extend.c, psxfile01/test_write.c,
psxfile02/init.c, psxfilelock01/init.c, psxgetrusage01/init.c,
psxhdrs/clock01.c, psxhdrs/clock02.c, psxhdrs/clock03.c,
psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c,
psxhdrs/cond01.c, psxhdrs/cond02.c, psxhdrs/cond03.c, psxhdrs/cond04.c,
psxhdrs/cond05.c, psxhdrs/cond06.c, psxhdrs/cond07.c, psxhdrs/cond08.c,
psxhdrs/cond09.c, psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c,
psxhdrs/key03.c, psxhdrs/key04.c, psxhdrs/mutex01.c, psxhdrs/mutex02.c,
psxhdrs/mutex03.c, psxhdrs/mutex04.c, psxhdrs/mutex05.c,
psxhdrs/mutex06.c, psxhdrs/mutex07.c, psxhdrs/mutex08.c,
psxhdrs/mutex09.c, psxhdrs/mutex10.c, psxhdrs/mutex11.c,
psxhdrs/mutex12.c, psxhdrs/mutex13.c, psxhdrs/mutex14.c,
psxhdrs/mutex15.c, psxhdrs/mutex16.c, psxhdrs/proc01.c,
psxhdrs/proc02.c, psxhdrs/proc03.c, psxhdrs/proc04.c, psxhdrs/proc05.c,
psxhdrs/proc06.c, psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c,
psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c, psxhdrs/proc13.c,
psxhdrs/proc14.c, psxhdrs/pthread01.c, psxhdrs/pthread02.c,
psxhdrs/pthread03.c, psxhdrs/pthread04.c, psxhdrs/pthread05.c,
psxhdrs/pthread06.c, psxhdrs/pthread07.c, psxhdrs/pthread08.c,
psxhdrs/pthread09.c, psxhdrs/pthread10.c, psxhdrs/pthread11.c,
psxhdrs/pthread12.c, psxhdrs/pthread13.c, psxhdrs/pthread14.c,
psxhdrs/pthread15.c, psxhdrs/pthread16.c, psxhdrs/pthread17.c,
psxhdrs/pthread18.c, psxhdrs/pthread19.c, psxhdrs/pthread20.c,
psxhdrs/pthread21.c, psxhdrs/pthread22.c, psxhdrs/pthread23.c,
psxhdrs/pthread24.c, psxhdrs/pthread25.c, psxhdrs/pthread26.c,
psxhdrs/pthread27.c, psxhdrs/pthread28.c, psxhdrs/pthread29.c,
psxhdrs/pthread30.c, psxhdrs/pthread31.c, psxhdrs/pthread32.c,
psxhdrs/pthread33.c, psxhdrs/pthread34.c, psxhdrs/pthread35.c,
psxhdrs/pthread36.c, psxhdrs/pthread37.c, psxhdrs/pthread38.c,
psxhdrs/pthread39.c, psxhdrs/pthread40.c, psxhdrs/sched01.c,
psxhdrs/sched02.c, psxhdrs/sched03.c, psxhdrs/sched04.c,
psxhdrs/sched05.c, psxhdrs/sched06.c, psxhdrs/sched07.c,
psxhdrs/sched08.c, psxhdrs/signal01.c, psxhdrs/signal02.c,
psxhdrs/signal03.c, psxhdrs/signal04.c, psxhdrs/signal05.c,
psxhdrs/signal06.c, psxhdrs/signal07.c, psxhdrs/signal08.c,
psxhdrs/signal09.c, psxhdrs/signal10.c, psxhdrs/signal11.c,
psxhdrs/signal12.c, psxhdrs/signal13.c, psxhdrs/signal14.c,
psxhdrs/signal15.c, psxhdrs/signal16.c, psxhdrs/signal17.c,
psxhdrs/signal18.c, psxhdrs/signal19.c, psxhdrs/signal20.c,
psxhdrs/signal21.c, psxhdrs/signal22.c, psxhdrs/signal23.c,
psxhdrs/sync01.c, psxhdrs/sync02.c, psxhdrs/sync03.c, psxhdrs/time01.c,
psxhdrs/time02.c, psxhdrs/time03.c, psxhdrs/time04.c, psxhdrs/time05.c,
psxhdrs/time06.c, psxhdrs/time07.c, psxhdrs/time08.c, psxhdrs/time09.c,
psxhdrs/time10.c, psxhdrs/time11.c, psxhdrs/time12.c, psxhdrs/time13.c,
psxhdrs/timer01.c, psxhdrs/timer02.c, psxhdrs/timer03.c,
psxhdrs/timer04.c, psxhdrs/timer05.c, psxhdrs/timer06.c,
psxhdrs/timer07.c, psxid01/init.c, psximfs01/init.c, psximfs02/init.c,
psxintrcritical01/init.c, psxitimer/init.c, psxkey01/init.c,
psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/main.c,
psxmount/test.c, psxmsgq01/init.c, psxmsgq02/init.c, psxmsgq03/init.c,
psxmsgq04/init.c, psxmutexattr01/init.c, psxobj01/init.c,
psxpasswd01/init.c, psxpasswd02/init.c, psxpipe01/init.c,
psxrdwrv/main.c, psxrdwrv/test.c, psxreaddir/main.c, psxreaddir/test.c,
psxrwlock01/main.c, psxrwlock01/test.c, psxsem01/init.c,
psxsignal01/init.c, psxsignal01/task1.c, psxsignal02/init.c,
psxsignal03/init.c, psxsignal05/init.c, psxsignal06/init.c,
psxspin01/main.c, psxspin01/test.c, psxspin02/main.c, psxspin02/test.c,
psxstack01/init.c, psxstack02/init.c, psxstat/main.c, psxstat/test.c,
psxsysconf/init.c, psxtime/main.c, psxtime/test.c,
psxtimer01/psxtimer.c, psxtimer02/psxtimer.c, psxtimes01/init.c,
psxualarm/init.c, psxusleep/init.c: Add HAVE_CONFIG_H.
* sp01/init.c,
sp01/task1.c,
sp02/init.c,
sp02/preempt.c,
sp02/task1.c,
sp02/task2.c,
sp02/task3.c,
sp03/init.c,
sp03/task1.c,
sp03/task2.c,
sp04/init.c,
sp04/task1.c,
sp04/task2.c,
sp04/task3.c,
sp04/tswitch.c,
sp05/init.c,
sp05/task1.c,
sp05/task2.c,
sp05/task3.c,
sp06/init.c,
sp06/task1.c,
sp06/task2.c,
sp06/task3.c,
sp07/buffered_io.c,
sp07/init.c,
sp07/task1.c,
sp07/task2.c,
sp07/task3.c,
sp07/task4.c,
sp07/taskexit.c,
sp07/tcreate.c,
sp07/tdelete.c,
sp07/trestart.c,
sp07/tstart.c,
sp08/init.c,
sp08/task1.c,
sp09/delay.c,
sp09/init.c,
sp09/isr.c,
sp09/screen01.c,
sp09/screen02.c,
sp09/screen03.c,
sp09/screen04.c,
sp09/screen05.c,
sp09/screen06.c,
sp09/screen07.c,
sp09/screen08.c,
sp09/screen09.c,
sp09/screen10.c,
sp09/screen11.c,
sp09/screen12.c,
sp09/screen13.c,
sp09/screen14.c,
sp09/task1.c,
sp09/task2.c,
sp09/task3.c,
sp09/task4.c,
sp10/init.c,
sp11/init.c,
sp11/task1.c,
sp11/task2.c,
sp11/timer.c,
sp12/init.c,
sp12/pridrv.c,
sp12/pritask.c,
sp12/task1.c,
sp12/task2.c,
sp12/task3.c,
sp12/task4.c,
sp12/task5.c,
sp13/fillbuff.c,
sp13/init.c,
sp13/putbuff.c,
sp13/task1.c,
sp13/task2.c,
sp13/task3.c,
sp14/asr.c,
sp14/init.c,
sp14/task1.c,
sp14/task2.c,
sp15/init.c,
sp15/task1.c,
sp16/init.c,
sp16/task1.c,
sp16/task2.c,
sp16/task3.c,
sp16/task4.c,
sp16/task5.c,
sp17/asr.c,
sp17/init.c,
sp17/task1.c,
sp17/task2.c,
sp18/init.c,
sp19/first.c,
sp19/fptask.c,
sp19/init.c,
sp19/task1.c,
sp20/getall.c,
sp20/init.c,
sp20/task1.c,
sp21/init.c,
sp22/delay.c,
sp22/init.c,
sp22/prtime.c,
sp22/task1.c,
sp23/init.c,
sp23/task1.c,
sp24/init.c,
sp24/resume.c,
sp24/task1.c,
sp25/init.c,
sp25/task1.c,
sp26/init.c,
sp26/task1.c,
sp27/init.c,
sp28/init.c,
sp29/init.c,
sp30/init.c,
sp30/resume.c,
sp30/task1.c,
sp31/delay.c,
sp31/init.c,
sp31/prtime.c,
sp31/task1.c,
sp32/init.c,
sp33/init.c,
sp34/changepri.c,
sp35/priinv.c,
sp36/strict_order_mut.c,
sp37/init.c,
sp38/init.c,
sp39/init.c,
sp40/init.c,
sp41/init.c,
sp42/init.c,
sp43/init.c,
sp44/init.c,
sp45/init.c,
sp46/init.c,
sp47/init.c,
sp48/init.c,
sp49/init.c,
sp50/init.c,
sp51/init.c,
sp52/init.c,
sp54/init.c,
sp55/init.c,
sp56/init.c,
sp57/init.c,
sp58/init.c,
sp59/init.c,
sp60/init.c,
sp62/init.c,
sp63/init.c,
sp64/init.c,
sp65/init.c,
sp66/init.c,
sp67/init.c,
sp68/init.c,
sp69/init.c,
sp70/init.c,
sp71/init.c,
sp72/init.c,
spassoc01/init.c,
spchain/init.c,
spclockget/init.c,
spcoverage/init.c,
sperror01/init.c,
sperror02/init.c,
sperror03/init.c,
spfatal_support/consume_sems.c,
spfatal_support/init.c,
spfifo01/init.c,
spfifo02/init.c,
spfifo03/init.c,
spfifo04/init.c,
spfifo05/init.c,
spheapprot/init.c,
spintrcritical01/init.c,
spintrcritical06/init.c,
spintrcritical08/init.c,
spintrcritical09/init.c,
spintrcritical10/init.c,
spintrcritical11/init.c,
spintrcritical13/init.c,
spintrcritical15/init.c,
spintrcritical16/init.c,
spintrcritical17/init.c,
spintrcritical_support/intrcritical.c,
spmkdir/init.c,
spmountmgr01/init.c,
spnotepad01/init.c,
spobjgetnext/init.c,
spprintk/init.c,
spprivenv01/init.c,
spsize/getint.c,
spsize/init.c,
spsize/size.c,
spstkalloc/init.c,
spthreadq01/init.c,
spwatchdog/delay.c,
spwatchdog/init.c,
spwatchdog/prtime.c,
spwatchdog/task1.c,
spwkspace/init.c: Add HAVE_CONFIG_H.
* POSIX/calloc.c, POSIX/clock_gettime.c, POSIX/close.c, POSIX/dup2.c,
POSIX/fcntl.c, POSIX/flockfile.c, POSIX/fork.c, POSIX/free.c,
POSIX/fstat.c, POSIX/ftrylockfile.c, POSIX/funlockfile.c,
POSIX/getdents.c, POSIX/getlogin.c, POSIX/getpwnam.c, POSIX/getpwuid.c,
POSIX/gettimeofday.c, POSIX/getuid.c, POSIX/htonl.c, POSIX/issetugid.c,
POSIX/kill.c, POSIX/longjmp.c, POSIX/lseek.c, POSIX/lstat.c,
POSIX/malloc.c, POSIX/nanosleep.c, POSIX/open.c, POSIX/pipe.c,
POSIX/posix_memalign.c, POSIX/read.c, POSIX/readv.c, POSIX/realloc.c,
POSIX/setjmp.c, POSIX/sigaddset.c, POSIX/sigdelset.c,
POSIX/sigemptyset.c, POSIX/sigfillset.c, POSIX/sigismember.c,
POSIX/sigprocmask.c, POSIX/stat.c, POSIX/unlink.c, POSIX/vfork.c,
POSIX/wait.c, POSIX/waitpid.c, POSIX/write.c, POSIX/writev.c,
block01/init.c, block02/init.c, block03/init.c, block04/init.c,
block05/init.c, block06/init.c, block07/init.c, block08/bdbuf_test1_1.c,
block08/bdbuf_test1_2.c, block08/bdbuf_test1_3.c,
block08/bdbuf_test1_4.c, block08/bdbuf_test1_5.c,
block08/bdbuf_test2_1.c, block08/bdbuf_test2_2.c,
block08/bdbuf_test3_1.c, block08/bdbuf_test3_2.c,
block08/bdbuf_test3_3.c, block08/bdbuf_test4_1.c,
block08/bdbuf_test4_2.c, block08/bdbuf_test4_3.c, block08/bdbuf_tests.c,
block08/init.c, block09/init.c, block10/init.c, bspcmdline01/init.c,
complex/docomplex.c, complex/docomplex.in, complex/docomplexf.c,
complex/docomplexl.c, complex/init.c, cpuuse/init.c, cpuuse/task1.c,
cpuuse/task2.c, cpuuse/task3.c, cpuuse/tswitch.c, devfs01/init.c,
devfs02/init.c, devfs03/init.c, devfs04/init.c, deviceio01/init.c,
dumpbuf01/init.c, gxx01/init.c, heapwalk/init.c, malloc02/init.c,
malloc03/init.c, malloc04/init.c, malloc05/init.c, malloctest/init.c,
malloctest/task1.c, math/domath.c, math/domath.in, math/init.c,
mathf/domathf.c, mathf/init.c, mathl/domathl.c, mathl/init.c,
monitor/init.c, monitor02/init.c, putenvtest/init.c, rtmonuse/getall.c,
rtmonuse/init.c, rtmonuse/task1.c, stackchk/blow.c, stackchk/init.c,
stackchk/task1.c, stackchk01/init.c, stringto01/init.c, tar01/init.c,
tar02/init.c, tar03/init.c, termios/init.c, termios01/init.c,
termios01/termios_testdriver.c, termios02/init.c, termios03/init.c,
termios03/termios_testdriver_polled.c, termios04/init.c,
termios04/termios_testdriver_intr.c, termios05/init.c,
termios05/termios_testdriver_taskdriven.c, termios06/init.c,
termios06/test_pppd.c, termios07/init.c, termios08/init.c,
tztest/init.c: Add HAVE_CONFIG_H.
* tm26/task1.c, tm27/task1.c: Adjust for name changes.
* pppd/system.h: Use confdefs.h to generate device driver table.
* pppd/system.h: Added missing include files.
* psxaio03/init.c, psxaio03/psxaio03.scn: Run in a reasonable amount of
time. Update screen.
* math/init.c, mathf/init.c, mathl/init.c: Now run.
* complex/Makefile.am, complex/init.c: Test now runs.
* monitor/Makefile.am, monitor02/Makefile.am: Switch to all managers
since this is all of them.
* sp09/Makefile.am: Switch to all managers since this is all of them.
* psximfs02/init.c: Disable EPERM test which does not work when POSIX
is disabled.
* stringto01/init.c: Redefine LONG_LONG_MAX and LONG_LONG_MIN
for c99.
* psxtmmutex02/init.c, psxtmthread03/init.c: end_time is a uint32_t.
* sp69/init.c: Use "ld" instead of PRId32 to print
struct timespec->tv_nsec.
* support/include/tmacros.h: Remove PRIxblksize_t, PRIxblkcnt_t.
* include/pmacros.h: Add PRIxblksize_t, PRIxblkcnt_t.
* configure.ac: Add AC_CHECK_SIZEOF([blksize_t]),
AC_CHECK_SIZEOF([blkcnt_t]).
