path: root/testsuites (follow)
* Turned stack checker on.Joel Sherrill1998-07-171-0/+2
* Patch from Eric Norum to avoid printing from context switch user extension.Joel Sherrill1998-06-123-7/+37
| | | | The array is too long and needs to be shortened.
* Fixed comment block at the beginning of the file for a copyright dateJoel Sherrill1998-06-09135-271/+270
| | | | problem and an English problem.
* Fixed prototype of Fatal_Extension.Joel Sherrill1998-05-042-18/+15
| | | | Fixed interface to cofndefs.h for initial extension set.
* Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirementsJoel Sherrill1998-04-2724-3/+49
| | | | more accurate.
* Fixed screen to match actual output.Joel Sherrill1998-04-271-3/+2
* Reset the pthread attributes structure so the proper error would beJoel Sherrill1998-04-271-1/+5
| | | | generated.
* Initial sets of user extensions now have memory allocated on the flyJoel Sherrill1998-04-151-2/+1
| | | | for them.
* Increased stack size so test would run in debug mode.Joel Sherrill1998-04-065-5/+6
* Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros forJoel Sherrill1998-03-242-9/+7
| | | | the CPU family name constants.
* Corrected typo in copyright notice.Joel Sherrill1998-03-211-1/+1
* Corrected to indicate test cases which were skipped.Joel Sherrill1998-03-031-2/+2
* Modified to reflect new restrictions on mutex being released.Joel Sherrill1998-02-201-1/+1
* Removed extra line.Joel Sherrill1998-02-201-1/+0
* Increased stack space to let test run to completion.Joel Sherrill1998-02-201-4/+4
* Increased stack space of tasks.Joel Sherrill1998-02-191-1/+1
* Increased stack size of initialization task.Joel Sherrill1998-02-191-0/+1
* Restructured so all times are placed in variables and printed in batchJoel Sherrill1998-02-191-163/+193
| | | | | mode at the end of the test. This eliminates the possibility of IO blocking a task unexpectedly and messing up the test.
* updated copyright to 1998Joel Sherrill1998-02-17569-569/+569
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-232-0/+5
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-1611-10/+12
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* Removed warning.Joel Sherrill1997-11-181-1/+1
* New file.Joel Sherrill1997-11-181-0/+45
* Added new test for termios style consoles from Eric Norum.Joel Sherrill1997-10-231-0/+141
* Added test case for rtems_interrupt_catch checking that the pointerJoel Sherrill1997-10-212-1/+11
| | | | for the returned old_isr_handler was non-NULL.
* Fixed some spacing.Joel Sherrill1997-10-092-4/+4
* Fix from Eric Norum so FPSP is installed before any FP code is actuallyJoel Sherrill1997-10-081-0/+9
| | | | exercise.
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-08571-1142/+1142
* Fixed some weird line duplications. Thanks to Chris Johns.Joel Sherrill1997-10-061-18/+9
* Added Monitor test.Joel Sherrill1997-09-212-0/+131
* Patches from Chris Johns to clean up test.Joel Sherrill1997-08-265-19/+52
* Merged very large and much appreciated patch from Chris JohnsJoel Sherrill1997-07-317-0/+1208
| | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test.
* Merged very large and much appreciated patch from Chris JohnsJoel Sherrill1997-07-311-0/+6
* Added support for rtems_message_queue_get_number_pending.Joel Sherrill1997-07-314-0/+21
* Used macro instead of hard coded number.Joel Sherrill1997-07-091-1/+1
* updated with new license information per Tony Bennett.Joel Sherrill1997-04-221-13/+5
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-22563-2815/+2815
* Modified to reflect change from 255 posix priority levels to 254.Joel Sherrill1997-04-183-6/+6
* enabled floating point and fixed confdef reference to initializationJoel Sherrill1997-04-094-5/+9
| | | | tasks table.
* new testJoel Sherrill1997-04-0912-0/+742
* corrected printf specifications and added casts as necessary to eliminateJoel Sherrill1997-04-077-72/+79
| | | | warnings.
* added ifdef to avoid warning for unused variable.Joel Sherrill1997-04-071-2/+6
* corrected integer only definitions of "FP CHECK" routines to eliminateJoel Sherrill1997-04-071-3/+10
| | | | warnings.
* corrected printf format to avoid warningJoel Sherrill1997-04-027-11/+11
* initialized variables or removed unused variables to remove warningsJoel Sherrill1997-04-023-4/+3
* Made stopping for the pause an option which can be configured in theJoel Sherrill1997-01-291-0/+12
| | | | targopts.h file.
* _CPU_Trap_Table_area is now conditional based on whether or notJoel Sherrill1997-01-081-2/+5
| | | | the application requires rtems to allocate a trap table
* new filesJoel Sherrill1996-09-183-0/+205
* added castJoel Sherrill1996-09-181-1/+1
