* | Require autoconf-2.69. | Ralf Corsépius | 2012-07-19 | 12 | -12/+12 |
* | psxtests/psxchroot01: Typo | Sebastian Huber | 2012-07-17 | 1 | -1/+1 |
* | psxtests/psxpipe01: Use greedy allocation API | Sebastian Huber | 2012-07-17 | 1 | -3/+4 |
* | libtests/termios01: Use greedy allocation API | Sebastian Huber | 2012-07-17 | 2 | -36/+22 |
* | score: Change greedy allocation API | Sebastian Huber | 2012-07-17 | 10 | -25/+34 |
* | libtests/mghttpd01: New test | Christian Mauderer | 2012-07-12 | 9 | -0/+470 |
* | libblock: Fix read-ahead trigger and next update | Sebastian Huber | 2012-07-02 | 1 | -5/+5 |
| | | | | | The previous version was sub-optimal for read-ahead transfer counts of one. | ||||
* | libblock: Fix read-ahead trigger and next update | Sebastian Huber | 2012-07-02 | 2 | -40/+52 |
* | libblock: Fix continuous blocks write request | Sebastian Huber | 2012-07-02 | 6 | -0/+230 |
* | libtests/block06: Increase stack size | Sebastian Huber | 2012-07-02 | 1 | -0/+2 |
* | fstests/fsfseeko01: New test | Sebastian Huber | 2012-06-19 | 6 | -0/+119 |
* | score: New structure TOD_Control | Sebastian Huber | 2012-06-14 | 1 | -2/+2 |
| | | | | | Group the global TOD variables (_TOD_Now, _TOD_Uptime, and _TOD_Is_set) in a structure to reduce address loads in _TOD_Tickle_ticks(). | ||||
* | libblock: Add block device statistics | Sebastian Huber | 2012-06-12 | 6 | -0/+275 |
* | libtests/block13: Add const qualifier | Sebastian Huber | 2012-06-04 | 1 | -1/+1 |
* | libtests/block05: Fix warnings | Sebastian Huber | 2012-06-04 | 1 | -2/+2 |
* | libblock: Add read-ahead task | Sebastian Huber | 2012-06-04 | 6 | -0/+275 |
| | | | | | | | | | | | Read-ahead requests were previously executed in the context of the reading task. This blocks the reading task until the complete read with read-ahead transfer is finished. A read-ahead task is introduced to off-load the read-ahead transfer. This allows the reading task to work with the requested block more quickly. The read-ahead is triggered after two misses of ascending consecutive blocks or a read hit of a block read by the most-recent read-ahead transfer. The read-ahead feature is configurable and can be disabled. | ||||
* | Fix C files which had two semi-colons at EOL | Joel Sherrill | 2012-05-31 | 5 | -8/+7 |
* | samples - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-31 | 13 | -124/+65 |
* | sptests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-31 | 71 | -106/+388 |
* | Revert "Revert "libtests/complex: Avoid generated files"" | Ralf Corsépius | 2012-05-31 | 7 | -437/+145 |
| | | | | This reverts commit 0c2d8ec48a116cadb86564bc1226e308e197d4c1. | ||||
* | Revert "Revert "libtests/math*: Avoid generated files"" | Ralf Corsépius | 2012-05-31 | 8 | -1116/+316 |
| | | | | This reverts commit 87c8d8aba6a9582ca5eeacd332b5b107e26ea50f. | ||||
* | Revert "libtests/math*: Avoid generated files" | Ralf Corsépius | 2012-05-31 | 8 | -316/+1116 |
| | | | | This reverts commit 6a5bd1c65c005457455db344f2ee831d7a5cf99b. | ||||
* | Revert "libtests/complex: Avoid generated files" | Ralf Corsépius | 2012-05-31 | 7 | -145/+437 |
| | | | | This reverts commit a80a108d447d596e476611108cd468ec993be4a6. | ||||
* | libblock: Simplify disk management | Sebastian Huber | 2012-05-31 | 1 | -1/+1 |
| | | | | | Add block_count and media_blocks_per_block to rtems_disk_device. Add and use rtems_disk_init_phys() and rtems_disk_init_log(). | ||||
* | libblock: Remove const qualifier from bdbuf API | Sebastian Huber | 2012-05-31 | 12 | -19/+19 |
| | | | | This allows addtion of per disk statistics for example. | ||||
* | libblock: Add task stack size bdbuf configuration | Sebastian Huber | 2012-05-31 | 11 | -17/+17 |
| | | | | | | The task stack size for the swap-out and worker tasks is now configurable. The bdbuf task resources are now included in the work space size estimate. | ||||
* | Filesystem: Wait for unmount() to finish | Sebastian Huber | 2012-05-29 | 3 | -43/+64 |
* | Add config.h.in. | Ralf Corsépius | 2012-05-24 | 8 | -0/+523 |
* | Revert "Revert "libtests/complex: Avoid generated files"" | Ralf Corsépius | 2012-05-24 | 7 | -437/+145 |
* | Revert "Revert "libtests/math*: Avoid generated files"" | Ralf Corsépius | 2012-05-24 | 8 | -1116/+316 |
* | Revert "libtests/math*: Avoid generated files" | Ralf Corsépius | 2012-05-23 | 8 | -316/+1116 |
* | Revert "libtests/complex: Avoid generated files" | Ralf Corsépius | 2012-05-23 | 7 | -145/+437 |
* | libtests/math*: Avoid generated files | Sebastian Huber | 2012-05-22 | 8 | -1116/+316 |
| | | | | Use C pre-processor instead of shell commands. | ||||
* | libtests/complex: Avoid generated files | Sebastian Huber | 2012-05-22 | 7 | -437/+145 |
* | Add missing ) | Ralf Corsépius | 2012-05-18 | 1 | -1/+1 |
* | Remove references to configure.in. | Ralf Corsépius | 2012-05-18 | 1 | -1/+1 |
* | Remove obsolete reference to posix bsp. | Ralf Corsépius | 2012-05-18 | 1 | -1/+0 |
* | Remove stray dnl. | Ralf Corsépius | 2012-05-18 | 1 | -2/+0 |
* | libcsupport: Adjust malloc_walk() prototype | Sebastian Huber | 2012-05-16 | 2 | -10/+10 |
| | | | | | | | | The header file <rtems/malloc.h> provides now also the malloc_walk() prototype. The malloc_walk() prototype reflects now the _Protected_heap_Walk() API. The return status helps to print only in case of an error. | ||||
* | Filesystem: Move operations to mount table entry | Sebastian Huber | 2012-05-15 | 1 | -1/+0 |
| | | | | | | | | | | | The scope of the file system operations is the file system instance. The scope of the file system node handlers is the file location. The benefit of moving the operations to the mount table entry is a size reduction of the file location (rtems_filesystem_location_info_t). The code size is slightly increased due to additional load instructions. Restructure rtems_filesystem_mount_table_entry_t to improve cache efficiency. | ||||
* | Filesystem: Use ioctl_command_t | Sebastian Huber | 2012-05-15 | 1 | -3/+1 |
* | libblock: Fix purge device tree traversal | Sebastian Huber | 2012-05-14 | 6 | -1/+187 |
* | psxtests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-11 | 71 | -201/+556 |
* | libtmtests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-11 | 46 | -64/+341 |
* | tmoverhd - Eliminate warnings | Joel Sherrill | 2012-05-11 | 1 | -11/+11 |
* | psxtmtests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-11 | 31 | -32/+167 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1761 | -4805/+0 |
* | fstests/fsrdwr: Add block read/write test case | Sebastian Huber | 2012-05-11 | 1 | -0/+194 |
* | fstests/fsrdwr: Add truncate to zero test case | Sebastian Huber | 2012-05-11 | 1 | -0/+32 |
* | fstests/fsrdwr: Fix assertions | Sebastian Huber | 2012-05-11 | 1 | -8/+8 |
