This completes the initial creation of rtems/inttypes.h based on all
existing PRIxxx definitions contained in RTEMS Project owned code.
closes #2983.
The include file handling was broken.
Add a test configuration data README.
Closes #2981.
On some systems, the instruction cache invalidation is not allowed by
the MMU.
Close #2977.
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
The ARM C++ exception ABI uses an address ordered index table to
locate the correct frame data and this requires the EXIDX sections are
loaded in the order the order the matching text is loaded.
The EXIDX sections set the SHF_LINK_ORDER flag and link field. This patch
adds support to load those flagged sections in the linked-to section
order.
Updates #2955.
Closes #2959
Update #2958.
Import whetstone sources from:
http://www.netlib.org/benchmark/whetstone.c
Update #2958.
Close #2958.
Import linpack sources from:
http://www.netlib.org/benchmark/linpack-pc.c
Update #2958.
Update #2958.
Import dhrystone sources from:
http://www.netlib.org/benchmark/dhry-c
Update #2958.
Update #2958.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
Do not use our long file name entry count to optimize the file name
search. The Unicode comparison must be taken into account.
Update #2939.
Remove forced overwrite which leads to file data corruption. The logic
to determine a forced overwrite was fundamentally broken. For simplity,
disable this feature.
Update #2622.
It is all right in case the result uses the full destination buffer.
Without this fix the handling of a maximum 8.3 short file name is
broken.
Update #2928.
Perform a context-dependent deferred location release to avoid a
deadlock on the file system instance locks, for example during a
chdir().
Update #2936.
BSD sed does not support '\t' and treated '[ \t]' as 3 characters. This patch
uses a standard method of supporting blank spaces.
Currently only blocking read/write operations are implemented. A
blocking write must transfer at least one character. It should not wait
for the device for the second character and so on.
Close #2917.
Call rtems_termios_puts() only once. Adjust column in one place.
In canonical mode, the raw input buffer or the canonical buffer may
overflow without an end of line. Avoid an infinite loop in this case.
Close #2915.
Call the receive callback in case a read will succeed without to block.
This enables the use of the receive callback for a poll() and select()
support. Increase raw input buffer size to allow buffering of one line.
Close #2916.
In case carriage return characters should be ignored in the input
(IGNCR), then drop them early before they reach the raw input buffer.
This makes it easier to calculate the content size of the raw input
buffer.
Update #2692.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
For a filename match the entry must match without anything remaining.
Close #2908.
Close #2895.
Only register ask for help requests in the scheduler unblock and yield
operations. The actual ask for help operation is carried out during
_Thread_Do_dispatch() on a processor related to the thread. This yields
a better separation of scheduler instances. A thread of one scheduler
instance should not be forced to carry out too much work for threads on
other scheduler instances.
Update #2556.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Instead of using the target time and console driver, both tests now use
assertions and rtems_rate_monotonic_get_status() to verify the count of
postponed jobs. The setting of spedfsched04 is slightly changed.
Close #2795.
Prepare a precondition to prevent the potential integer overflow.
Remove one redundant parameter in _Rate_monotonic_Renew_deadline().
sptests/sprmsched02: Create
A test case for checking the overflow condition of postponed_jobs
in rtems_rate_monotonic_period_status.
Update #2885.
Use forward and reverse order for initial and dynamic extensions. This
is the behaviour documented in the C Users Guide. Change thread
terminate order to backward to be in line with the thread delete order.
Change fatal error order to forward to ensure that initial extensions
are called first due the peculiar execution context of fatal error
extensions, see _Terminate() documentation.
Update #2692.
