1998-08-03 | Under allcoated task stacks. | Joel Sherrill | 1 | -1/+1 | |
1998-07-17 | Turned stack checker on. | Joel Sherrill | 1 | -0/+2 | |
1998-06-12 | Patch from Eric Norum to avoid printing from context switch user extension. | Joel Sherrill | 3 | -7/+37 | |
The array is too long and needs to be shortened. | |||||
1998-06-09 | Fixed comment block at the beginning of the file for a copyright date | Joel Sherrill | 135 | -271/+270 | |
problem and an English problem. | |||||
1998-05-04 | Fixed prototype of Fatal_Extension. | Joel Sherrill | 2 | -18/+15 | |
Fixed interface to cofndefs.h for initial extension set. | |||||
1998-04-27 | Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirements | Joel Sherrill | 24 | -3/+49 | |
more accurate. | |||||
1998-04-27 | Fixed screen to match actual output. | Joel Sherrill | 1 | -3/+2 | |
1998-04-27 | Reset the pthread attributes structure so the proper error would be | Joel Sherrill | 1 | -1/+5 | |
generated. | |||||
1998-04-15 | Initial sets of user extensions now have memory allocated on the fly | Joel Sherrill | 1 | -2/+1 | |
for them. | |||||
1998-04-06 | Increased stack size so test would run in debug mode. | Joel Sherrill | 5 | -5/+6 | |
1998-03-24 | Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for | Joel Sherrill | 2 | -9/+7 | |
the CPU family name constants. | |||||
1998-03-21 | Corrected typo in copyright notice. | Joel Sherrill | 1 | -1/+1 | |
1998-03-03 | Corrected to indicate test cases which were skipped. | Joel Sherrill | 1 | -2/+2 | |
1998-02-20 | Modified to reflect new restrictions on mutex being released. | Joel Sherrill | 1 | -1/+1 | |
1998-02-20 | Removed extra line. | Joel Sherrill | 1 | -1/+0 | |
1998-02-20 | Increased stack space to let test run to completion. | Joel Sherrill | 1 | -4/+4 | |
1998-02-19 | Increased stack space of tasks. | Joel Sherrill | 1 | -1/+1 | |
1998-02-19 | Increased stack size of initialization task. | Joel Sherrill | 1 | -0/+1 | |
1998-02-19 | Restructured so all times are placed in variables and printed in batch | Joel Sherrill | 1 | -163/+193 | |
mode at the end of the test. This eliminates the possibility of IO blocking a task unexpectedly and messing up the test. | |||||
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 569 | -569/+569 | |
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 1 | -1/+1 | |
1998-01-23 | Solaris port updates from Chris Johns | Joel Sherrill | 2 | -0/+5 | |
1998-01-16 | Ralf Corsepius reported a number of missing CVS Id's: | Joel Sherrill | 11 | -10/+12 | |
> RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose. | |||||
1997-11-18 | Removed warning. | Joel Sherrill | 1 | -1/+1 | |
1997-11-18 | New file. | Joel Sherrill | 1 | -0/+45 | |
1997-10-23 | Added new test for termios style consoles from Eric Norum. | Joel Sherrill | 1 | -0/+141 | |
1997-10-21 | Added test case for rtems_interrupt_catch checking that the pointer | Joel Sherrill | 2 | -1/+11 | |
for the returned old_isr_handler was non-NULL. | |||||
1997-10-09 | Fixed some spacing. | Joel Sherrill | 2 | -4/+4 | |
1997-10-08 | Fix from Eric Norum so FPSP is installed before any FP code is actually | Joel Sherrill | 1 | -0/+9 | |
exercise. | |||||
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 571 | -1142/+1142 | |
1997-10-06 | Fixed some weird line duplications. Thanks to Chris Johns. | Joel Sherrill | 1 | -18/+9 | |
1997-09-21 | Added Monitor test. | Joel Sherrill | 2 | -0/+131 | |
1997-08-26 | Patches from Chris Johns to clean up test. | Joel Sherrill | 5 | -19/+52 | |
1997-07-31 | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 7 | -0/+1208 | |
<cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | |||||
1997-07-31 | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1 | -0/+6 | |
1997-07-31 | Added support for rtems_message_queue_get_number_pending. | Joel Sherrill | 4 | -0/+21 | |
1997-07-09 | Used macro instead of hard coded number. | Joel Sherrill | 1 | -1/+1 | |
1997-04-22 | updated with new license information per Tony Bennett. | Joel Sherrill | 1 | -13/+5 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 563 | -2815/+2815 | |
of switching to the modified GNU GPL. | |||||
1997-04-18 | Modified to reflect change from 255 posix priority levels to 254. | Joel Sherrill | 3 | -6/+6 | |
1997-04-09 | enabled floating point and fixed confdef reference to initialization | Joel Sherrill | 4 | -5/+9 | |
tasks table. | |||||
1997-04-09 | new test | Joel Sherrill | 12 | -0/+742 | |
1997-04-07 | corrected printf specifications and added casts as necessary to eliminate | Joel Sherrill | 7 | -72/+79 | |
warnings. | |||||
1997-04-07 | added ifdef to avoid warning for unused variable. | Joel Sherrill | 1 | -2/+6 | |
1997-04-07 | corrected integer only definitions of "FP CHECK" routines to eliminate | Joel Sherrill | 1 | -3/+10 | |
warnings. | |||||
1997-04-02 | corrected printf format to avoid warning | Joel Sherrill | 7 | -11/+11 | |
1997-04-02 | initialized variables or removed unused variables to remove warnings | Joel Sherrill | 3 | -4/+3 | |
1997-01-29 | Made stopping for the pause an option which can be configured in the | Joel Sherrill | 1 | -0/+12 | |
targopts.h file. | |||||
1997-01-08 | _CPU_Trap_Table_area is now conditional based on whether or not | Joel Sherrill | 1 | -2/+5 | |
the application requires rtems to allocate a trap table | |||||
1996-09-18 | new files | Joel Sherrill | 3 | -0/+205 | |
