* | spcpucounter01: Enable floating-point output | Sebastian Huber | 2018-05-14 | 1 | -0/+1 |
* | ftpfs: Always build FTP client | Sebastian Huber | 2018-05-02 | 1 | -1/+1 |
| | | | | | | Move FTP client filesystem to separate library libftpfs.a. Update #3419. | ||||
* | libdebugger: Move to separate library | Sebastian Huber | 2018-05-02 | 1 | -0/+1 |
| | | | | | | | | | | Always build remote TCP support since it depends only on the POSIX socket API. It works with the legacy network stack and libbsd. Move it to a separate libdebugger.a library to allow an easy use with libbsd via "-ldebugger -lbsd" otherwise we would have a cyclic dependency between libbsd.a and librtemscpu.a. Update #3419. | ||||
* | tests: Move rtems-test-check.py | Sebastian Huber | 2018-05-02 | 2 | -1/+161 |
| | | | | Remove shell script variant. | ||||
* | tests: Remove difftest and sorttimes tools | Sebastian Huber | 2018-05-02 | 6 | -358/+0 |
| | | | | Close #3418. | ||||
* | tests: Remove configure feature checks | Sebastian Huber | 2018-05-02 | 23 | -334/+11 |
| | | | | Update #3409. | ||||
* | Drop executable permissions on .[ch] files | Joel Sherrill | 2018-04-30 | 1 | -0/+0 |
* | smptests/smpschededf02: Add test case | Sebastian Huber | 2018-04-27 | 1 | -3/+8 |
* | bsps: Move make/custom/* files to bsps | Sebastian Huber | 2018-04-23 | 1 | -1/+1 |
| | | | | | | | | | Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | smptests/smpschedaffinity02: Fix configuration | Sebastian Huber | 2018-04-23 | 1 | -0/+2 |
* | sptests/sp36: Remove obsolete test program | Sebastian Huber | 2018-04-22 | 5 | -212/+0 |
| | | | | | | | | It tests the (never really working) strict order mutex option. That option does not exist any more. Mutexes by other good means (spmutex01, spsem*). Update #3406. | ||||
* | build: Remove subdir-objects from Ada tests | Sebastian Huber | 2018-04-20 | 1 | -1/+1 |
| | | | | | | | | | | | Somehow it does not work. With this Automake option you get: gmake[6]: Entering directory '/build/sparc-rtems5/c/erc32/testsuites/ada/sptests' Making all-am in sp01 gmake[7]: Entering directory '/build/sparc-rtems5/c/erc32/testsuites/ada/sptests/sp01' gmake[7]: *** No rule to make target 'init.o', needed by 'ada_sp01.exe'. Stop. Update #3387. | ||||
* | bsps: Move startup files to bsps | Sebastian Huber | 2018-04-20 | 2 | -3/+3 |
| | | | | | | | | Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | Multiple BSP tcfg: Disable iconv files. | Joel Sherrill | 2018-04-17 | 1 | -0/+7 |
* | libdl: Fix the tests loading the correct files | Chris Johns | 2018-04-12 | 6 | -18/+18 |
* | testsuites/dl06: Add a test for RAP format. | Chris Johns | 2018-04-12 | 10 | -26/+428 |
| | | | | | | | This test loads a RAP format file that contains calls that are not in the kernel and linked from libm. It uses and test rtems-ld. Update #2769 | ||||
* | build: Add support for automake's silent build support. | Chris Johns | 2018-04-12 | 1 | -61/+61 |
* | build: Fix make clean. | Chris Johns | 2018-04-11 | 1 | -1/+2 |
| | | | | Update #3254. | ||||
* | configure: Add subdir-objects to all automake flags. | Chris Johns | 2018-04-11 | 15 | -15/+15 |
| | | | | | | | | | | | This option silences warning with automake-1.16.1 allowing us to upgrade to that version. This change has been tested with automake-1.12.6 and automake-1.16.1. It seems version 1.16.1 configures slower than 1.12.6 for the same source and BSP. The newer versions is 6 second slower. Close #3387. | ||||
* | Generate an error if a BSP in the --enable-rtemsbsp list is not valid | Chris Johns | 2018-04-11 | 1 | -14/+0 |
| | | | | | | | Also generate an error if the architecure does not match the --target architecture given to configure's command line. Close #2641. | ||||
* | fstest/fsrfsbitmap01: Update RFS bitmap tests to test fixes. | Chris Johns | 2018-04-11 | 1 | -0/+19 |
| | | | | | | Add tests to check the patches for this ticket exist and are fixed. Close #3089 | ||||
* | sptests: Fix AM_CONDITIONAL | Sebastian Huber | 2018-04-10 | 1 | -2/+2 |
| | | | | Update #3382. | ||||
* | testsuites: Remove the test check from the subdir support. | Chris Johns | 2018-04-10 | 1 | -23/+3 |
| | | | | | | Leave the parallel support so each test group builds in parallel. Update #3382 | ||||
* | testsuite/tmtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 43 | -1043/+437 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | testsuite/sptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 219 | -5001/+2257 |
* | testsuite/smptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 57 | -1191/+691 |
* | testsuite/samples: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 22 | -372/+168 |
* | testsuite/irhealstone: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 8 | -155/+78 |
* | testsuite/psxtmtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 51 | -1370/+711 |
* | testsuite/psxtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 105 | -2686/+1294 |
* | testsuite/mptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 80 | -633/+262 |
* | testsuite/fstests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 97 | -1730/+702 |
* | testsuite/libtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 100 | -2480/+1401 |
* | testsuite/benchmarks: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 5 | -73/+51 |
* | testsuite: Autoconf test check support. | Chris Johns | 2018-04-10 | 1 | -0/+31 |
| | | | | | | | | | The autoconf function checks the state of a test for the BSP and controls the building of the test. This change is part of the testsuite Makefile.am reorganisation. Update #3382 | ||||
* | build: Remove DISTCLEANFILES | Sebastian Huber | 2018-04-09 | 1 | -1/+0 |
| | | | | | A "make distclean" is not supported. So, it makes no sense to have pure "make distclean" related stuff in the Makefile.am. | ||||
* | build: Remove EXTRA_DIST | Sebastian Huber | 2018-04-04 | 7 | -30/+0 |
| | | | | | A "make dist" is not supported. So, it makes no sense to have pure "make dist" related stuff in the Makefile.am. | ||||
* | config: Use new scheduler configuration defines | Sebastian Huber | 2018-03-12 | 19 | -308/+308 |
| | | | | Update #3325. | ||||
* | sptests/sp19: Fix test output methods | Sebastian Huber | 2018-03-08 | 2 | -2/+14 |
| | | | | Do not use fprintf() in non-fp tasks. | ||||
* | libtests/capture01: Fix configuration | Sebastian Huber | 2018-03-07 | 1 | -0/+1 |
* | smptests: Fix obsolete FIXME comments/code | Sebastian Huber | 2018-03-07 | 2 | -4/+2 |
* | Add a simple task console driver | Sebastian Huber | 2018-03-06 | 4 | -20/+6 |
| | | | | Close #3320. | ||||
* | spglobalcon02: New test | Sebastian Huber | 2018-03-06 | 6 | -0/+152 |
| | | | | Update #3319. | ||||
* | ada/sp04: Fix test failure due to compiler opti | Sebastian Huber | 2018-02-22 | 1 | -0/+1 |
| | | | | | The SPTEST.RUN_COUNT must be volatile since it is changed outside of the procedure scope by the thread switch extension. | ||||
* | fsclose01: Fix task mode, use attribute | Sebastian Huber | 2018-02-09 | 1 | -1/+2 |
| | | | | Update #1971. | ||||
* | fsclose01: Use floating-point task | Sebastian Huber | 2018-02-09 | 1 | -1/+1 |
| | | | | | | The tmpfile() uses sprintf(). Update #1971. | ||||
* | tests: Support %g print format specifier | Sebastian Huber | 2018-02-09 | 2 | -0/+2 |
* | libdl: Use self-contained recursive mutex | Sebastian Huber | 2018-02-07 | 1 | -1/+1 |
| | | | | Update #2843. | ||||
* | termios: Remove obsolete configuration options | Sebastian Huber | 2018-02-05 | 10 | -33/+0 |
* | fsclose01: Add tmpfile() test case | Sebastian Huber | 2018-02-05 | 2 | -3/+28 |
| | | | | Close #1971. |
