Update #2747
Handles possible NULL return value
Updates #2747
The configure order effects how it works.
Close #3297
If there is already a file with a long file name it isn't possible to
create a second file which has a name that ends on the first files name
(for example ets.beam and sets.beam). This patch fixes that.
Close #3258.
Take care that a file in the root directory with the same name as the
volume name can be found.
Close #3257.
- Add AM C++ support to the testsuite configure.ac script.
- Fix the dependences in the DL tests.
Closes #3024.
Closes #2956.
Do not use our long file name entry count to optimize the file name
search. The Unicode comparison must be taken into account.
Close #2939.
Remove forced overwrite which leads to file data corruption. The logic
to determine a forced overwrite was fundamentally broken. For simplity,
disable this feature.
Close #2622.
It is all right in case the result uses the full destination buffer.
Without this fix the handling of a maximum 8.3 short file name is
broken.
Close #2928.
Perform a context-dependent deferred location release to avoid a
deadlock on the file system instance locks, for example during a
chdir().
Close #2936.
For a filename match the entry must match without anything remaining.
Update #2908.
Update #2886.
Update #2719.
POSIX mandates that an error code is returned and not -1 plus errno.
Update #2715.
POSIX recommends ESRCH in case no thread exists for the specified
identifier.
Update #2713.
Under certain conditions a new watchdog was inserted with a wrong
and very large delta interval due to a wrong iterator update.
Bug was introduced by 1ccbd052910ed16131c74b0d5595c8a94066942d.
Close #2507.
Under certain conditions a new watchdog was inserted with a wrong and
very large delta interval due to an incomplete iterator update.
Close #2501.
closes #2431.
The $(PAX) variable is used unconditionally so it shouldn't be
left empty if not found at configure time. Fixes #2437.
Remove unused descriptor of merged free chunks from the free chain and
add them to the spare descriptors.
Update #2417.
Update #2417.
This function is hard to support in alternative implementations. It has
no internal use case.
With this a _Freechain_Put( _Freechain_Get() ) works always.
Replace the extend function with an allocator since this fits better
to the current use case.
The problem is that empty structures have a different size in C and C++.
Drop the <rtems/score/percpu.h> include since this file exposes a lot of
implementation details.
Add rtems_interrupt_local_disable|enable() as suggested by Pavel Pisa to
emphasize that interrupts are only disabled on the current processor.
Do not define the rtems_interrupt_disable|enable|flash() macros and
functions on SMP configurations since they don't ensure system wide
mutual exclusion.
This was obsolete and broken based upon recent time keeping changes.
Thie build option was previously enabled by adding
USE_TICKS_FOR_STATISTICS=1 to the configure command line.
This propagated into the code as preprocessor conditionals
using the __RTEMS_USE_TICKS_FOR_STATISTICS__ conditional.
Add an assert to ensure that the watchdog is the proper state for a
_Watchdog_Initialize(). This helps to detect invalid initializations
which may lead to a corrupt watchdog chain.
Update #2365.
Do a volatile clobber in the context switch extension to cover the path
through _Thread_Do_dispatch() invoked after interrupt processing.
It is wrong to restore the floating point context here. The
_Context_Switch() ends up in _Thread_Handler() which will call
_Thread_Restore_fp(). In _Thread_Do_dispatch() the FP restore is after
the context switch.
There is no NULL pointer access. Please note that
_Thread_Get_executing() != executing variable in Low_task().
This reverts commit 5611839a7e2e371dd1f327c336c785095f634e55.
Replace _API_Mutex_Is_locked() with _API_Mutex_Is_owner().
In case the zlib compression was used, then the librtemscpu.a depended
on libz.a. To avoid a GCC patch or complicated link flags move the
JFFS2 support into a separate library to use a simple "-ljffs2 -lz" to
link the executable.
