* sp46/sp46.scn: Add screen missed earlier.
PR 1348/cpukit
* Makefile.am, configure.ac: Add test of special case of resetting cpu
usage information while a period is running.
* sp46/.cvsignore, sp46/Makefile.am, sp46/init.c, sp46/sp46.doc,
sp46/sp46.scn: New files.
* sp45/init.c: New file.
PR 1347/cpukit
* Makefile.am, configure.ac, sp30/resume.c, sp30/task1.c, sp31/delay.c:
Rework Timer Server to ensure that the context allows for blocking,
allocating memory, and acquiring semaphores and mutexes.
* sp45/.cvsignore, sp45/Makefile.am, sp45/sp45.doc, sp45/sp45.scn:
New files.
* sp25/system.h: Add warning and temporary m32c conditional until size
type addressed.
* paranoia/paranoia.c: Add missing prototypes.
* tm22/system.h, tm22/task1.c: Account for message buffers used.
* malloctest/init.c: Do not generate alignment factors larger that will
not fit in a native integer.
* sp09/screen07.c: Use INT_MAX as number of messages so always
properly sized and no overflow on constant.
* sp09/screen10.c: Delay so on targets with simulator idle clock
tick driver this will work.
* sp09/screen11.c, sp09/system.h: Move badly aligned objects to odd
byte boundaries rather than two byte boundaries.
* sp09/screen03.c, sp09/screen14.c: Skip tests which try to
allocate more memory than size_t holds on m32c.
* unlimited/system.h: Tighten configuration for stack space.
* fileio/init.c: When USE_SHELL not defined, do not attempt to
configure shell.
* unlimited/system.h: 10000 task ids is too many for some targets.
* include/timesys.h: Use inttypes.h.
* tmck/task1.c: Use uint32_t for count.
* sp09/screen01.c, sp09/screen12.c, sp25/system.h, sp25/task1.c,
sp28/init.c, sp39/init.c, sp41/init.c, spfatal01/testcase.h,
spfatal08/testcase.h: Change size_t to ssize_t on all Heap, Workspace
and Region calls. On 16-bit architectures, size_t can be 16-bits
which would limit sizes to 64K. Also address constants which
overflowed on 16-bit integer targets.
* psx01/psx01.scn: Bump version to 4.9.99.0
* sp43/sp43.scn: Bump version to 4.9.99.0
* aclocal/version.m4: Bump RTEMS_API to 4.10.
Bump _RTEMS_VERSION to 4.9.99.0.
* unlimited/system.h: Support up to 10K tasks in loop. With 64MB on
pc386 and configured for unified workspace, you can get close to
this.
* include/timesys.h: Rename STACK_CHECKER_ON to more appropriate
CONFIGURE_STACK_CHECKER_ENABLED.
* fileio/system.h: Rename STACK_CHECKER_ON to more appropriate
* stackchk/system.h: Rename STACK_CHECKER_ON to more appropriate
* minimum/init.c, unlimited/system.h: Add support for optionally having
a unified work area. In other words, the RTEMS Workspace and C
Program Heap are the same pool of memory.
* hello/system.h, minimum/Makefile.am, minimum/init.c: Merge GSOC
project code to add simple device only filesystem (devfs), optionally
completely drop out filesystem, and to clean up disabling newlib
reentrancy support. This dropped 17K from the minimum.exe for
sparc/sis and arm/rtl22xx_t now has a 15K code space.
* tm09/system.h, tm09/task1.c: Account for message buffer memory.
* mp09/recvmsg.c, mp09/task1.c, mp10/task1.c, mp13/task1.c,
mp14/msgtask1.c: Correct types to eliminate warnings.
* sp34/sp34.scn, sp35/sp35.scn: Convert to UNIX CR/LF style.
* support/src/test_support.c: Convert to "bool".
* malloctest/init.c: Convert to "bool".
* psxcleanup/psxcleanup.c, psxfatal_support/init.c,
psxfatal_support/system.h: Convert to "bool".
* capture/system.h, capture/test1.c, fileio/init.c,
unlimited/init.c, unlimited/system.h, unlimited/test1.c:
Convert to "bool".
* sp35/priinv.c, sp37/init.c, sp38/init.c, sp39/init.c, sp41/init.c,
sp42/init.c, sp43/init.c, spfatal/fatal.c, spfatal/system.h,
spfatal_support/init.c, spfatal_support/system.h:
Convert to "bool".
* mp14/delay.c, mp14/evtmtask.c: Pass task Id to TSR.
* mp14/system.h: Semaphore_task_id and Semaphore_task_name arrays
were one entry too short.
* spsize/size.c: Must extern _MPCI_Semaphore because it is no longer
declared in a public place.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am: Updating and
fixing while running mptests on psim.
* mp03/delay.c, mp06/task1.c, mp06/node2/mp06-node2.scn, mp07/task1.c:
Updating and fixing while running them on psim.
* sp07/system.h, sp07/tcreate.c: Convert to bool type.
* mp05/system.h, mp05/task1.c, mp06/system.h, mp06/task1.c,
mp07/system.h, mp07/task1.c, mp14/evtask1.c, mp14/evtmtask.c,
mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c,
mp14/system.h: Convert to bool type.
* support/src/tmtests_empty_function.c: New file.
* tmitronsem01/Makefile.am, tmitronsem01/init.c: Eliminate empty
function from every benchmark timer driver. Fix spelling.
* tm01/Makefile.am, tm01/task1.c, tm02/Makefile.am, tm02/task1.c,
tm03/Makefile.am, tm03/task1.c, tm04/Makefile.am, tm04/task1.c,
tm05/Makefile.am, tm05/task1.c, tm06/Makefile.am, tm06/task1.c,
tm07/Makefile.am, tm07/task1.c, tm08/Makefile.am, tm08/task1.c,
tm09/Makefile.am, tm09/task1.c, tm10/Makefile.am, tm10/task1.c,
tm11/Makefile.am, tm11/task1.c, tm12/Makefile.am, tm12/task1.c,
tm13/Makefile.am, tm13/task1.c, tm14/Makefile.am, tm14/task1.c,
tm15/Makefile.am, tm15/task1.c, tm16/Makefile.am, tm16/task1.c,
tm17/Makefile.am, tm17/task1.c, tm18/Makefile.am, tm18/task1.c,
tm19/Makefile.am, tm19/task1.c, tm20/Makefile.am, tm20/task1.c,
tm21/Makefile.am, tm21/task1.c, tm22/Makefile.am, tm22/task1.c,
tm23/Makefile.am, tm23/task1.c, tm24/Makefile.am, tm24/task1.c,
tm25/Makefile.am, tm25/task1.c, tm26/Makefile.am, tm26/task1.c,
tm27/Makefile.am, tm27/task1.c, tm28/Makefile.am, tm28/task1.c,
tm29/Makefile.am, tm29/task1.c, tmck/Makefile.am, tmck/task1.c,
tmoverhd/Makefile.am, tmoverhd/testtask.c: Eliminate empty function
* tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c,
tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c,
tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c,
tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c,
tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c,
tmoverhd/testtask.c: Rename timer driver methods to follow RTEMS
programming conventions.
PR 1296/cpukit.
* psxtimer01/psxtimer.c, psxtimer01/psxtimer01.scn: POSIX timers use
incorrect repeat interval. This patch fixes the following problems in
the test.
(1) Adds test for value of it_interval.tv_nsec.
(2) Corrects test for absolute timer in past.
(3) Modifies test to use different initial and repeat periods.
(4) Updates psxtimer01.scn to match results.
* sp43/init.c: Fix derefence of uninitialized pointer.
PR 1297/cpukit
* psxrwlock01/psxrwlock01.scn, psxrwlock01/test.c: Fix NULL attribute
pointer handling.
* spsize/size.c: Make _System_state_Is_multiprocessing unused when
multiprocessing is not enabled. Saves one more variable from single
processor configuration.
PR 1212/cpukit
* Makefile.am, configure.ac: Time slicing will not happen if the task
mode is changed from a non-timeslicing mode to timeslicing mode if it
is done by the executing thread (e.g. in its task body). This change
includes sp44 to demonstrate the problem and verify the correction.
* sp44/.cvsignore, sp44/Makefile.am, sp44/init.c, sp44/sp44.scn: New files.
* psxsem01/init.c: Spacing.
