2013-03-08 | RTEMS: Delete ChangeLog files. | Gedare Bloom | 12 | -12394/+0 | |
This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | |||||
2013-02-21 | libblock: Do resource allocation in one place | Sebastian Huber | 2 | -33/+0 | |
All resource allocations take place in rtems_bdbuf_init() now. After rtems_bdbuf_init() no fatal errors can happen due to configuration errors or resource limits. This makes it easier to detect configuration errors for users. | |||||
2013-02-20 | fstests/fsrdwr: Add test case | Sebastian Huber | 3 | -1/+59 | |
2013-02-20 | fstests/fsrdwr: Fix warning | Sebastian Huber | 1 | -1/+1 | |
2013-02-15 | fstests: Prevent compiler optimizations | Sebastian Huber | 1 | -1/+4 | |
2013-02-14 | Introduce AM_CONDITIONAL ATOMIC. | Ralf Corsépius | 7 | -14/+28 | |
2013-02-14 | Introduce AM_CONDITIONAL ATOMIC, cpuopt RTEMS_ATOMIC. | Ralf Corsépius | 1 | -0/+4 | |
2013-02-12 | sptests/spfatal11: Update due to API changes | Sebastian Huber | 2 | -5/+22 | |
2013-02-12 | score: Add and use rtems_assert_context | Sebastian Huber | 2 | -5/+31 | |
2013-02-07 | tests: atomic support for RTEMS. SMP tests for atomic operations. | WeiY | 42 | -0/+1991 | |
2013-02-07 | tests: atomic support for RTEMS. Uniprocessor tests for atomic ops. | WeiY | 42 | -0/+2563 | |
2013-02-07 | score: atomic support for RTEMS automake and autoconf changes | WeiY | 4 | -1/+24 | |
2013-01-30 | fstests/fsrdwr: Free allocated memory | Sebastian Huber | 1 | -0/+4 | |
2013-01-30 | fstests: Check resources used by FAT file system | Sebastian Huber | 1 | -0/+6 | |
2013-01-30 | fstests: Use global environment and clean up | Sebastian Huber | 1 | -3/+14 | |
This releases all resources acquired by the chroot(). | |||||
2013-01-30 | fstests: Initialize swapout task | Sebastian Huber | 1 | -0/+19 | |
2013-01-30 | fstests: Perform a quick format | Sebastian Huber | 1 | -1/+1 | |
2013-01-30 | fstests: Use designated initializers | Sebastian Huber | 1 | -10/+10 | |
2013-01-28 | ftpfs: Fix SIZE command handling | Sebastian Huber | 2 | -4/+26 | |
It is invalid to issue a SIZE command once a data transfer is in progress. For reads we issue the SIZE command before the RETR command and get a snapshot of the file size. For writes the file size is initialized to zero and incremented for each write chunk. | |||||
2013-01-27 | testsuites: Fix prototypes | Sebastian Huber | 6 | -16/+22 | |
2013-01-27 | testsuites: Use rtems_fatal_source_description() | Sebastian Huber | 4 | -27/+6 | |
2013-01-15 | fstests: Generating .scn (Screen Shots) #4 | Alex Ivanov | 6 | -0/+192 | |
2013-01-15 | psxtmtests: Generating .scn (Screen Shots) #8 | Alex Ivanov | 7 | -0/+30 | |
2013-01-14 | Create POSIX Timing Test psxtmthread02 | Christopher Kerl | 5 | -0/+120 | |
Minor modifications were made to the student version to clearify methods and to clean up test output. | |||||
2013-01-14 | Generating .scn (Screen Shots) #7 | Alex Ivanov | 6 | -0/+32 | |
2013-01-11 | Create POSIX Timing Test psxtmcond09 | Christopher Kerl | 9 | -0/+290 | |
Modifications were made to this submission allow the same init.c file to be ran by three tests that were very similar using posix pthread_cond_timedwait and pthread_cond_wait. | |||||
2013-01-11 | Create POSIX Timing Test psxtmcond03 | Christopher Kerl | 5 | -0/+144 | |
2013-01-11 | Added more condition variable timing tests. | Jennifer Averett | 1 | -2/+4 | |
2013-01-09 | Create POSIX Timing Test psxtmcond05 | Christopher Kerl | 5 | -0/+111 | |
2013-01-09 | Create POSIX Timing Test psxtmcond02 | Christopher Kerl | 5 | -0/+113 | |
2013-01-09 | GCI: Create POSIX Timing Test psxtmcond01 | Christopher Kerl | 5 | -0/+130 | |
2013-01-07 | sapi: Add rtems_fatal_source_description() | Sebastian Huber | 2 | -2/+32 | |
2013-01-07 | rtems: Critical fix for events | Sebastian Huber | 2 | -23/+289 | |
Commit 4b45c1393ce4ee3e1c2762ef3145d2bd6b5b38da marked a test in _Event_Timeout() as debug only. This test is required also in non-debug configurations since otherwise state corruption can happen. A revised test sptests/spintrcritical10 checks the relevant sequences. | |||||
2013-01-06 | tmoverhd.doc | Cynthia Rempel | 1 | -0/+75 | |
Hi, Adding test documentation... | |||||
2013-01-02 | IMFS: Generating .scn (Screen Shots) #2 | Christopher Kerl | 6 | -0/+276 | |
2013-01-02 | sptests/spintrcritical16: Fix NULL pointer access | Sebastian Huber | 1 | -1/+4 | |
2012-12-22 | libtests/rbheap01: Add test cases | Sebastian Huber | 1 | -0/+42 | |
2012-12-22 | sptests/speventsystem01: Add test cases | Sebastian Huber | 1 | -0/+34 | |
2012-12-22 | libtests/malloctest: Add test case | Sebastian Huber | 1 | -0/+25 | |
2012-12-22 | libtests/malloctest: Add test case | Sebastian Huber | 1 | -0/+24 | |
2012-12-21 | libblock: Use rtems_blkdev_create_partition() | Sebastian Huber | 1 | -2/+26 | |
Use rtems_blkdev_create_partition() instead of rtems_disk_create_log() to avoid problems with the huge IMFS_GENERIC_DEVICE_MAJOR_NUMBER. | |||||
2012-12-21 | IMFS: Fix resource leak in IMFS_allocate_node() | Sebastian Huber | 1 | -7/+58 | |
2012-12-21 | libcsupport: Add rtems_resource_snapshot_take() | Sebastian Huber | 2 | -5/+101 | |
Add rtems_resource_rtems_api, rtems_resource_posix_api, rtems_resource_snapshot, rtems_resource_snapshot_equal(), and rtems_resource_snapshot_check(). | |||||
2012-12-21 | score: Add _Objects_Active_count() | Sebastian Huber | 3 | -1/+10 | |
2012-12-21 | score: Add rtems_chain_node_count_unprotected() | Sebastian Huber | 3 | -1/+23 | |
2012-12-16 | libtests/md501: Use test cases of RFC 2202 | Sebastian Huber | 2 | -160/+200 | |
2012-12-16 | libtests/md501: New test | Sebastian Huber | 6 | -0/+251 | |
2012-12-13 | dosfs: Add sync_device option for msdos_format() | Sebastian Huber | 1 | -1/+6 | |
2012-12-13 | dosfs: Bugfix for disks of for example 100MB size | Ralf Kirchner | 1 | -11/+60 | |
2012-12-13 | termios: Implement tcflush() | Sebastian Huber | 2 | -13/+15 | |
New IO control RTEMS_IO_TCFLUSH. |
