Update #3325.
Do not use fprintf() in non-fp tasks.
Close #3320.
Update #3319.
The SPTEST.RUN_COUNT must be volatile since it is changed outside of the
procedure scope by the thread switch extension.
Update #1971.
The tmpfile() uses sprintf().
Update #1971.
Update #2843.
Update #2843.
Close #1971.
Update #2843.
Update #2840.
Update #2843.
Rename PER_CPU_WATCHDOG_MONOTONIC to PER_CPU_WATCHDOG_TICKS. Add new
PER_CPU_WATCHDOG_MONOTONIC which is based on the system uptime (measured
by timecounter).
Close #3264.
Avoid unnecessary lock acquire/release operations. Get realtime via
timecounter only if necessary.
Update #3264.
Due to structure internal padding the use of memcmp() may lead to
sporadic test failures.
Update #3082.
There were two issues:
1. The buffer size must be divisible by 8 on 64-bit targets
2. It must be large enough to service the begin of start message.
Update #3082.
The rtems_test_busy() is not accurate enough and may lead to sporadic
test failures.
Some time ago the Classic API object size related parameters were
changed to use size_t. Reflect this in the Ada bindings.
Update #3082.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Free deferred locations before the greedy memory allocation. This test
fails on powerpc/qoriq_e6500_64 otherwise.
Update #2843.
This test uses sprintf().
This test uses fprintf().
The fstests use snprintf().
This avoids blocking output and the use of the floating-point unit.
Update #3109.
Updates #3000.
Updates #3000.
If there is already a file with a long file name it isn't possible to
create a second file which has a name that ends on the first files name
(for example ets.beam and sets.beam). This patch fixes that.
Update #3258.
Update test documentation to include more cases.
Updates #3000.
