* stackchk/system.h: Rename STACK_CHECKER_ON to more appropriate
CONFIGURE_STACK_CHECKER_ENABLED.
* minimum/init.c, unlimited/system.h: Add support for optionally having
a unified work area. In other words, the RTEMS Workspace and C
Program Heap are the same pool of memory.
* hello/system.h, minimum/Makefile.am, minimum/init.c: Merge GSOC
project code to add simple device only filesystem (devfs), optionally
completely drop out filesystem, and to clean up disabling newlib
reentrancy support. This dropped 17K from the minimum.exe for
sparc/sis and arm/rtl22xx_t now has a 15K code space.
* tm09/system.h, tm09/task1.c: Account for message buffer memory.
* mp09/recvmsg.c, mp09/task1.c, mp10/task1.c, mp13/task1.c,
mp14/msgtask1.c: Correct types to eliminate warnings.
* sp34/sp34.scn, sp35/sp35.scn: Convert to UNIX CR/LF style.
* support/src/test_support.c: Convert to "bool".
* malloctest/init.c: Convert to "bool".
* psxcleanup/psxcleanup.c, psxfatal_support/init.c,
psxfatal_support/system.h: Convert to "bool".
* capture/system.h, capture/test1.c, fileio/init.c,
unlimited/init.c, unlimited/system.h, unlimited/test1.c:
Convert to "bool".
* sp35/priinv.c, sp37/init.c, sp38/init.c, sp39/init.c, sp41/init.c,
sp42/init.c, sp43/init.c, spfatal/fatal.c, spfatal/system.h,
spfatal_support/init.c, spfatal_support/system.h:
Convert to "bool".
* mp14/delay.c, mp14/evtmtask.c: Pass task Id to TSR.
* mp14/system.h: Semaphore_task_id and Semaphore_task_name arrays
were one entry too short.
* spsize/size.c: Must extern _MPCI_Semaphore because it is no longer
declared in a public place.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am: Updating and
fixing while running mptests on psim.
* mp03/delay.c, mp06/task1.c, mp06/node2/mp06-node2.scn, mp07/task1.c:
Updating and fixing while running them on psim.
* sp07/system.h, sp07/tcreate.c: Convert to bool type.
* mp05/system.h, mp05/task1.c, mp06/system.h, mp06/task1.c,
mp07/system.h, mp07/task1.c, mp14/evtask1.c, mp14/evtmtask.c,
mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c,
mp14/system.h: Convert to bool type.
* support/src/tmtests_empty_function.c: New file.
* tmitronsem01/Makefile.am, tmitronsem01/init.c: Eliminate empty
function from every benchmark timer driver. Fix spelling.
* tm01/Makefile.am, tm01/task1.c, tm02/Makefile.am, tm02/task1.c,
tm03/Makefile.am, tm03/task1.c, tm04/Makefile.am, tm04/task1.c,
tm05/Makefile.am, tm05/task1.c, tm06/Makefile.am, tm06/task1.c,
tm07/Makefile.am, tm07/task1.c, tm08/Makefile.am, tm08/task1.c,
tm09/Makefile.am, tm09/task1.c, tm10/Makefile.am, tm10/task1.c,
tm11/Makefile.am, tm11/task1.c, tm12/Makefile.am, tm12/task1.c,
tm13/Makefile.am, tm13/task1.c, tm14/Makefile.am, tm14/task1.c,
tm15/Makefile.am, tm15/task1.c, tm16/Makefile.am, tm16/task1.c,
tm17/Makefile.am, tm17/task1.c, tm18/Makefile.am, tm18/task1.c,
tm19/Makefile.am, tm19/task1.c, tm20/Makefile.am, tm20/task1.c,
tm21/Makefile.am, tm21/task1.c, tm22/Makefile.am, tm22/task1.c,
tm23/Makefile.am, tm23/task1.c, tm24/Makefile.am, tm24/task1.c,
tm25/Makefile.am, tm25/task1.c, tm26/Makefile.am, tm26/task1.c,
tm27/Makefile.am, tm27/task1.c, tm28/Makefile.am, tm28/task1.c,
tm29/Makefile.am, tm29/task1.c, tmck/Makefile.am, tmck/task1.c,
tmoverhd/Makefile.am, tmoverhd/testtask.c: Eliminate empty function
* tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c,
tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c,
tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c,
tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c,
tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c,
tmoverhd/testtask.c: Rename timer driver methods to follow RTEMS
programming conventions.
PR 1296/cpukit.
* psxtimer01/psxtimer.c, psxtimer01/psxtimer01.scn: POSIX timers use
incorrect repeat interval. This patch fixes the following problems in
the test.
(1) Adds test for value of it_interval.tv_nsec.
(2) Corrects test for absolute timer in past.
(3) Modifies test to use different initial and repeat periods.
(4) Updates psxtimer01.scn to match results.
* sp43/init.c: Fix derefence of uninitialized pointer.
PR 1297/cpukit
* psxrwlock01/psxrwlock01.scn, psxrwlock01/test.c: Fix NULL attribute
pointer handling.
* spsize/size.c: Make _System_state_Is_multiprocessing unused when
multiprocessing is not enabled. Saves one more variable from single
processor configuration.
PR 1212/cpukit
* Makefile.am, configure.ac: Time slicing will not happen if the task
mode is changed from a non-timeslicing mode to timeslicing mode if it
is done by the executing thread (e.g. in its task body). This change
includes sp44 to demonstrate the problem and verify the correction.
* sp44/.cvsignore, sp44/Makefile.am, sp44/init.c, sp44/sp44.scn: New files.
* psxsem01/init.c: Spacing.
PR 1293/tests
* psx10/init.c: Make sure we do not let tv_nsec go to -1.
PR 1291/cpukit
* psx05/init.c, psxmsgq01/init.c: As part of addressing timeouts and
POSIX services taking relative instead of absolute time for timeouts,
these tests were updated.
* psxfile01/test.c: truncate on /dev/console now works.
* sp09/screen09.c: Do not use Simple Vectored Interrupt calls on
architectures they are not supported on.
* fileio/init.c: New argument sequence for rtems_shell_init(). Also
split on multiple lines and document each parameter.
* sp43/init.c, sp43/sp43.scn: Add call to rtems_get_version_string().
* aclocal/rtems-top.m4: Require AC_DISABLE_OPTION_CHECKING.
AC_PREREQ(2.62).
* sp36/strict_order_mut.c: Reflect __STRICT_ORDER_MUTEX__ having
been renamed into __RTEMS_STRICT_ORDER_MUTEX__.
* minimum/init.c: Disable confdefs.h debug.
* iostream/system.h: Init task was close to blowing stack on PowerPC.
* minimum/init.c: Disable Classic API Notepads.
* rtems++/System.h: Account for extra task stacks properly.
* psxrwlock01/main.c, psxspin01/main.c: Now accounts for extra stack
requested for initialization task.
* minimum/init.c: Add CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION and
CONFIGURE_MAXIMUM_PRIORITY. Workspace usage now reduces to 4696 bytes
on psim.
* minimum/init.c: Exerise new ability for application to configure
minimum stack size. This test still runs the same with a 7.5K stack
on the powerpc but reserves 15K less Workspace on the PowerPC.
* tm02/system.h, tm10/system.h: Make configurations more accurate.
* sp28/init.c: Corrections to configuration.
* sp37/init.c: Correctly invoke rtems_interrupt_disable() body.
* spsize/size.c: _ISR_Vector_table only exists on architectures
which use the Simple Vectored Interrupt Model.
* minimum/Makefile.am: Link against all managers.
* minimum/init.c: Use existing confdefs.h macros to turn off more
this test does not use.
* spsize/size.c: Convention calls for leading underscore on private
RTEMS variables.
* itronhello/system.h, itronmbox01/system.h, itrontask02/system.h,
itrontime01/system.h: Add use of
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
* psxstat/psxstat.scn, psxstat/test.c: Eliminate patterns that look
like CVS conflict markers.
