Use the item UID converted to CamelCase for Doxygen group names and
testsuite names.
Update #3716.
Clarify wording. Use a function wrapper for the SMP spurious interrupt setup.
Update #3716.
Add TM27_USE_VECTOR_HANDLER to select the interrupt handler type used by
the <tm27.h> implementation.
Close #4820.
The name handler table was a bit misleading after the last rework.
Rename it to distach table. Update the documentation accordingly.
Update #4769.
Use the tm27 support to test a spurious interrupt. This helps to run the
validation test case on targets which have no software interrupt available for
tests (for example riscv/PLIC/CLINT in the SMP configuration).
Make sure that the state of the testable interrupt vector is restored to the
state at the test case begin.
Update #3716.
Ensure that the IDLE storage allocator did allocate a suffiently large area.
Update #3835.
Update #4524.
By default, allocate the IDLE task storage areas from the RTEMS Workspace.
This avoids having to estimate the thread-local storage size in the default
configuration.
Add the application configuration option CONFIGURE_IDLE_TASK_STORAGE_SIZE to
request a static allocation of the task storage area for IDLE tasks.
Update #3835.
Update #4524.
Add the INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED fatal error in case the
creation of an idle thread fails. This may happen due to a failing create
extension provided by the application.
Allow the IDLE stack allocator to change the stack size. This can be
used by applications with a very dynamic thread-local storage size to
adjust the thread storage area of the IDLE tasks dynamically.
Update #4524.
Update #3716.
This function was declared, however, a definition was missing. Add a
validation test for it.
Update #3716.
Update #4662.
Test this option in a configuration with only one processor.
Update #3716.
Update #3716.
Update #4702.
Update #4702.
This gets rid of a cyclic dependency in the specification graph.
Update #3716.
Update #3716.
Update #4662.
Add the direct BSP character ouput to the report hash.
Update #3716.
A relative CLOCK_REALTIME time out shall not be affected by CLOCK_REALTIME
changes through clock_settime(). Since our CLOCK_REALTIME is basically just
CLOCK_MONOTONIC plus an offset, we can simply use the CLOCK_MONOTONIC watchdog
for relative CLOCK_REALTIME time outs.
Update #4690.
Threads may join the thread termination of another thread using the
pthread_join() or rtems_task_delete() directives. The thread cancel operation
used a special case priority boosting mechanism implemented by
_Thread_Raise_real_priority(). The problem was that this approach
* is not transitive,
* does not account for priority adjustments of the calling task
while waiting for the join,
* does not support clustered scheduling, and
* does not detect deadlocks.
All these problems are fixed by using a priority inheritance thread queue for
the join operation.
Close #4679.
Update #3716.
Update #3716.
Update #3716.
Update #3716.
This particular state during a reconsider help request scheduler operation was
only covered by the existing test suites under some timing conditions.
Update #3716.
Update #4670.
Update #4670.
Use CLOCK_REALTIME and CLOCK_MONOTONIC for relative thread queue timeouts
instead of CLOCK_REALTIME_COARSE and CLOCK_MONOTONIC_COARSE. This fixes an
issue with clock_nanosleep() in combination with clock_gettime().
Close #4669.
Some BSPs require that Clear_tm27_intr() is called in the interrupt
service routine.
Update #3269.
In the SMP_FATAL_MULTITASKING_START_ON_NOT_ONLINE_PROCESSOR test case,
the boot processor ends up in the idle body. Do not issue a fatal error
here and instead enter the idle loop. The secondary processor will
terminate the system.
Make the task configuration reusable.
Update #3716.
Add SMP-specifc SMP_FATAL_MULTITASKING_START_ON_NOT_ONLINE_PROCESSOR
fatal error. This fatal error helps to diagnose a broken SMP startup
sequence. Without this error a context switch using the NULL pointer
for the thread control block happens which may be difficult to debug.
The test source code is generated from specification items
by the "./spec2modules.py" script contained in the
git://git.rtems.org/rtems-central.git Git repository.
Please read the "How-To" section in the "Software Requirements Engineering"
chapter of the RTEMS Software Engineering manual to get more information about
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
the process.
Update #3716.
