Check the name followed by the id check in all create directives.
Compare pointers against NULL. Fix formatting.
Add the build option RTEMS_TEST_VERBOSITY to control the verbosity of
test suites using the RTEMS Test Framework.
Update #4007.
This is the first test case generated from a specification item in the
rtems-central repository.
Update #3959.
Add a general purpose test suite for validation tests.
This is the first test suite generated from a specification item in the
Update #3959.
