* | validation/ts-performance-0: Add partition tests | Sebastian Huber | 2020-11-19 | 1 | -0/+437 |
* | validation/ts-performance-0: Add test suite | Sebastian Huber | 2020-11-19 | 3 | -154/+312 |
| | | | | Share a default test suite with ts-validation-0. | ||||
* | Improve automatically generated warning | Sebastian Huber | 2020-11-12 | 3 | -15/+12 |
* | validation: Improve file header comment | Sebastian Huber | 2020-10-08 | 3 | -15/+29 |
* | rtems: Canonicalize name and id checks | Sebastian Huber | 2020-10-01 | 2 | -168/+168 |
| | | | | | | Check the name followed by the id check in all create directives. Compare pointers against NULL. Fix formatting. | ||||
* | tests: Add and use <rtems/testopts.h> | Sebastian Huber | 2020-10-01 | 1 | -1/+2 |
| | | | | | Add the build option RTEMS_TEST_VERBOSITY to control the verbosity of test suites using the RTEMS Test Framework. | ||||
* | validation: Test rtems_message_queue_construct() | Sebastian Huber | 2020-09-28 | 1 | -0/+1868 |
| | | | | Update #4007. | ||||
* | validation: rtems_task_construct() errors | Sebastian Huber | 2020-09-17 | 1 | -0/+2367 |
| | | | | | | | This is the first test case generated from a specification item in the rtems-central repository. Update #3959. | ||||
* | validation: Add general purpose test suite | Sebastian Huber | 2020-09-17 | 1 | -0/+222 |
Add a general purpose test suite for validation tests. This is the first test suite generated from a specification item in the rtems-central repository. Update #3959. |
