The TM27 support may define TM27_INTERRUPT_VECTOR_ALTERNATIVE to provide
an alternative software generated interrupt request which is raised by
_TM27_Raise_alternative() and cleared by _TM27_Clear_alternative().
Both functions shall return an RTEMS status code. This interrupt vector
may be used to test the interrupt controller support on targets which do
not provide generic software generated interrupts.
Update #3716.
Let the BSP define TM27_INTERRUPT_VECTOR_DEFAULT to more efficiently and
reliably get the TM27 default interrupt vector.
Update #3716.
brains GmbH.
Add TM27_USE_VECTOR_HANDLER to select the interrupt handler type used by
the <tm27.h> implementation.
Close #4820.
Use the tm27 support to test a spurious interrupt. This helps to run the
validation test case on targets which have no software interrupt available for
tests (for example riscv/PLIC/CLINT in the SMP configuration).
Some BSPs require that Clear_tm27_intr() is called in the interrupt
service routine.
Update #3269.
Update #3269.
