* | config: Add CONFIGURE_IDLE_TASK_STORAGE_SIZE | Sebastian Huber | 2022-10-14 | 1 | -0/+2 |
| | | | | | | | | | | | | By default, allocate the IDLE task storage areas from the RTEMS Workspace. This avoids having to estimate the thread-local storage size in the default configuration. Add the application configuration option CONFIGURE_IDLE_TASK_STORAGE_SIZE to request a static allocation of the task storage area for IDLE tasks. Update #3835. Update #4524. | ||||
* | validation: Test IO Manager | Sebastian Huber | 2022-03-24 | 1 | -0/+149 |
The test source code is generated from specification items by the "./spec2modules.py" script contained in the git://git.rtems.org/rtems-central.git Git repository. Please read the "How-To" section in the "Software Requirements Engineering" chapter of the RTEMS Software Engineering manual to get more information about the process. Update #3716. |
