Add a library for support functions used by validation tests. Rename
tc-support.* to tx-support.* since this file does not contain test
cases.
In the action requirements, some pre-conditions are not applicable
depending on the state of other pre-conditions. There is no particular
order in the pre-conditions, so we have to check the N/A status
individually.
Fix warning:
testsuites/validation/tc-signal-send.c:634:21: warning: unused variable
'sc' [-Wunused-variable]
Use a common wording for the tests. Use the new templates for action
requirements described in the RTEMS Software Engineering manual.
Update #4244.
