* | validation: Test Interrupt Manager | Sebastian Huber | 2022-03-24 | 1 | -14/+32 |
| | | | | | | | | | | | | The test source code is generated from specification items by the "./spec2modules.py" script contained in the git://git.rtems.org/rtems-central.git Git repository. Please read the "How-To" section in the "Software Requirements Engineering" chapter of the RTEMS Software Engineering manual to get more information about the process. Update #3716. | ||||
* | validation: Improve generated test code | Sebastian Huber | 2021-09-02 | 1 | -62/+79 |
| | | | | | | | Move the transition map members of the test context to a dedicated structure. Move the transition variant pre-condition prepare, action, and post-condition checks to a separate function to reduce the indentation level and allow skipping of transition variants. | ||||
* | validation: rtems_interrupt_vector_is_enabled() | Sebastian Huber | 2021-07-26 | 1 | -0/+627 |
Update #3269. |
