The test source code is generated from specification items
by the "./spec2modules.py" script contained in the
git://git.rtems.org/rtems-central.git Git repository.
Please read the "How-To" section in the "Software Requirements Engineering"
chapter of the RTEMS Software Engineering manual to get more information about
the process.
Update #3716.
Use a CPU set which is larger than the internal processor set
representation.
Move the transition map members of the test context to a dedicated
structure. Move the transition variant pre-condition prepare, action,
and post-condition checks to a separate function to reduce the
indentation level and allow skipping of transition variants.
Update #3269.
