* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Use bsptools_bin_SCRIPTS to install scripts.
* configure.ac: Reflect having moved to testsuites/.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* configure.ac: Apply RTEMS_CPU_SUBDIRS for potential CPU-subdirs.
* configure.in: Remove.
* configure.in: Replace AC_CONFIG_SUBDIRS with
RTEMS_CONFIG_BUILD_SUBDIRS.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
on BSPs that install there own tools.
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
