for details.
* generic/difftest.in: Remove more ITRON references.
* * configure.ac: Remove RTEMS_CPU_SUBDIRS.
* configure.ac: Add 2nd arg to RTEMS_TOP.
* configure.ac: Rework. Make package a host compiled package.
* Makefile.am: Ditto.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Use bsptools_bin_SCRIPTS to install scripts.
* configure.ac: Reflect having moved to testsuites/.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* configure.ac: Apply RTEMS_CPU_SUBDIRS for potential CPU-subdirs.
* configure.in: Remove.
* configure.in: Replace AC_CONFIG_SUBDIRS with
RTEMS_CONFIG_BUILD_SUBDIRS.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
