* | Require autoconf-2.69. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+2 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -2/+0 |
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 1 | -2/+2 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 1 | -1/+1 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -2/+2 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-09-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-09-24 | 1 | -2/+0 |
| | | | | * * configure.ac: Remove RTEMS_CPU_SUBDIRS. | ||||
* | 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-03-25 | 1 | -1/+1 |
| | | | | * configure.ac: Add 2nd arg to RTEMS_TOP. | ||||
* | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-14 | 1 | -1/+1 |
| | | | | | * configure.ac: Rework. Make package a host compiled package. * Makefile.am: Ditto. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -2/+2 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-10 | 1 | -1/+1 |
| | | | | * configure.ac: Reflect having moved to testsuites/. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 1 | -1/+1 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 1 | -1/+0 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 1 | -1/+1 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-20 | 1 | -2/+0 |
| | | | | * configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -2/+2 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-10-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-17 | 1 | -3/+1 |
| | | | | | * configure.ac: Apply RTEMS_CPU_SUBDIRS for potential CPU-subdirs. * Makefile.am: Require automake-1.5. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -0/+28 |
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. |
