Unconditionally make a CONFIGURE_TICKS_PER_TIMESLICE value less than or equal
to zero an error.
Update #4986.
This avoids a dependency on the non-standard libxml2 module.
This avoids a dependency on the non-standard libxml2 module. Reorder
test cases according to expected performance.
Use a SPARC-specific method to flush the register windows. This
improves the timing measurements.
The previous method to prevent optimizations no longer worked at least
with GCC 13. Disable intra-procedural optimizations.
brains GmbH.
Add TM27_USE_VECTOR_HANDLER to select the interrupt handler type used by
the <tm27.h> implementation.
Close #4820.
These files had no file header, copyright, or license. Based on git
history, added appropriate copyrights and licenses.
Updates #3053.
+ include
+ tmck
+ tmfine01
+ tmonetoone
+ tmtimer01
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #4625.
Close #3250.
Close #4081.
MrsP semaphores are a generalization of the priority ceiling semaphores
for SMP configurations. Priority ceiling semaphores are required to use
the priority task wait queue discipline. Require this discipline also
for MrsP semaphores.
Close #4347.
Closes #4040.
Rename this header file to later move <t.h> to <rtems/test.h>. The main
feature provided by <rtems/test-info.h> is the output of standard test
information which is consumed by the RTEMS Tester.
Update #3199.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
The use of CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER does not define
anything, so remove the <rtems/btimer.h> include.
Update #3875.
The CONFIGURE_DISABLE_SMP_CONFIGURATION configuration option and
rtems_configuration_is_smp_enabled() were added during the SMP support
development cycle as a workaround to fix some testsuite failures in SMP
configurations. All use cases were replaced with tests for specific
conditions. The configuration option and test macro were undocumented.
Close #3876.
The MrsP semaphore implementation predates the addition of
self-contained synchronization objects. At this time, the potential
memory reduction was justified considering the more complex
configuration and additional use of the workspace. With the
availability of self-contained synchronization options, e.g. POSIX
mutexes, this is no longer justified. Memory constrained applications
should use the self-contained synchronization objects. Remove the
CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option. This has only an
impact on applications which use SMP and a large number of scheduler
instances.
Update #3833.
Use separator character '_' for all test states.
The rtems_test_pause() and rtems_test_pause_and_screen_number() macros
had different implementations depending on the RTEMS_TEST_NO_PAUSE
define. This define was defined to 1 by default. The user was able to
change this via the undocumented --disable-test-no-pause configure
command line option.
Pausing tests and waiting for user input contradicts the goal of having
automated test runs. Remove this feature.
Update #3818.
Update #3818.
Update #3732.
Add rtems_scheduler_get_processor() as a replacement for
rtems_get_current_processor(). The rtems_get_current_processor() is a
bit orphaned. Adopt it by the Scheduler Manager. This is in line with
the glibc sched_getcpu() function.
Deprecate rtems_get_current_processor().
Update #3731.
- Add a small memory test config file.
- Update the small memory PowerPC BSPs to use the new test config.
Update #3533.
calling rtems_print_printer_fprintf_putc() results in usage of vfprintf()
which may use floating point instructions in its implementation.
upgrade to that version.
Close #3387.
Update #3382
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Updates #3000.
maintain.
Update #3254.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Reduce test context size in non-SMP configurations.
Close #3200.
call to printk.
Updates #3170.
Update #2674.
Update #3112.
Update #3113.
Update #3114.
Update #3115.
It is getting harder to prevent the compiler from optimizing away the
recursive function calls.
Do not use the processor count to determine if SMP is enabled. Instead
use a dedicated configuration option. Enable SMP by default in SMP
configurations.
Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
otherwise.
Update #3001.
