Enable the SMP configuration by default in case SMP is enabled. Add
configuration option CONFIGURE_DISABLE_SMP_CONFIGURATION to disable it
explicitly.
Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
otherwise.
Update #3001.
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Add _CPU_Get_current_per_CPU_control() on SMP configurations. Use SPRG0
for the current per-CPU control. This reduces the code size by three
instructions and is slightly faster.
Update #2805.
The SMP ticket lock release turned out to be suitable for inlining, e.g.
a hand full of instructions, no branches.
The changes in the screen files do not reflect the changes due to this
commit. However, they are now up to date. Obtained on a T4240 running
at 1.5GHz using GCC 7.0.0 20161108..
Binary semaphores (not simple binary semaphores) maintain the resource
count since 8797c76addf22a2f0ffc3717ff977695e35b9b0b. Do this also for
initially locked binary semaphores.
Add plot script.
Replace Thread_Scheduler_control::control and
Thread_Scheduler_control::own_control with new
Thread_Scheduler_control::home.
Update #2556.
This demonstrates the effect of false cache line sharing in case of
Classic mutexes.
Introduce Thread_queue_Lock_context to contain the context necessary for
thread queue lock and thread wait lock acquire/release operations to
reduce the Thread_Control size.
Add _Thread_queue_Context_set_MP_callout() to simplify
_Thread_queue_Context_initialize(). This makes it possible to more
easily add additional fields to Thread_queue_Context.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Uniformly use *_Get() to get an object by identifier with a lock
context.
Use _Objects_Get_local() for _Semaphore_Get_interrupt_disable() to get
rid of the location parameter. Move remote object handling to semaphore
MPCI support.
This is a preparation to remove the Giant lock.
Update #2555.
Rename _ISR_Disable() into _ISR_Local_disable(). Rename _ISR_Enable()
into _ISR_Local_enable(). Remove _Debug_Is_owner_of_giant().
Update #2555.
Rename _ISR_Disable_without_giant() into _ISR_Local_disable(). Rename
_ISR_Enable_without_giant() into _ISR_Local_enable().
Update #2555.
Replace _Thread_Disable_dispatch() with _Thread_Dispatch_disable().
Replace _Thread_Enable_dispatch() with _Thread_Dispatch_enable().
Update #2555.
Replace _Thread_Get() with _Thread_Get_interrupt_disable() to avoid the
Giant lock.
Update #2555.
Update #2555.
In addition protect scheduler of thread by thread state lock. Enables
use of scheduler per-instance locks.
Update #2555.
Update #2555.
This service was marked as deprecated long prior to the 4.11 release
series and is now being removed.
closes #2676.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
Test run performed on T4240 running at 1667MHz in uni-processor
configuration.
Update #2554.
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
This define accidentally re-appeared.
Add rtems_interrupt_local_disable|enable() as suggested by Pavel Pisa to
emphasize that interrupts are only disabled on the current processor.
Do not define the rtems_interrupt_disable|enable|flash() macros and
functions on SMP configurations since they don't ensure system wide
mutual exclusion.
It is wrong to restore the floating point context here. The
_Context_Switch() ends up in _Thread_Handler() which will call
_Thread_Restore_fp(). In _Thread_Do_dispatch() the FP restore is after
the context switch.
There is no NULL pointer access. Please note that
_Thread_Get_executing() != executing variable in Low_task().
This reverts commit 5611839a7e2e371dd1f327c336c785095f634e55.
These tests intentionally use the deprecated method. Eventually
this code in the sections can be deleted.
Add rtems_test_parallel_get_task_id().
Deprecate Classic API Notepads. Mark task_set/get_note() with
the deprecated attribute, and also mark the notepads field.
Replace disable with enable option for notepads in confdefs.h,
and make notepads disabled by default. The previous option
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and
will emit a compile-time warning. A new option
CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn
on notepads, but it also will emit a compile-time warning
to indicate that notepads are deprecated.
Closes #2265
The _Thread_Dispatch() function is quite complex and the time to set up
and tear down the stack frame is significant. Split this function into
two parts. The complex part is now in _Thread_Do_dispatch(). Call
_Thread_Do_dispatch() in _Thread_Enable_dispatch() only if necessary.
This increases the average case performance.
Simplify _Thread_Handler() for SMP configurations.
Update #2273.
Previously, the _Thread_Heir was updated unconditionally in case a new
heir was determined. The _Thread_Dispatch_necessary was only updated in
case the executing thread was preemptible or an internal thread was
unblocked. Change this to update the _Thread_Heir and
_Thread_Dispatch_necessary only in case the currently selected heir
thread is preemptible or a dispatch is forced. Move the schedule
decision into the change priority operation and use the schedule
operation only in rtems_task_mode() in case preemption is enabled or an
ASR dispatch is necessary. This is a behaviour change. Previously, the
RTEMS_NO_PREEMPT also prevented signal delivery in certain cases (not
always). Now, signal delivery is no longer influenced by
RTEMS_NO_PREEMPT. Since the currently selected heir thread is used to
determine if a new heir is chosen, non-preemptible heir threads
currently not executing now prevent a new heir. This may have an
application impact, see change test tm04. Document this change in sp04.
Update #2273.
Increment by cache line size to allow more cycles per second.
tm02 and tm03 were modified to be reused for multiple configurations
of RTEMS Classic API Semaphores. This added tm31-36. The messages for
tm02 and tm03 were modified to indicate the semaphore attributes.
tm31 - tm36 were added. This resulted in the following cases:
tm02 - rtems_semaphore_obtain: Counting/FIFO not available caller blocks
tm03 - rtems_semaphore_release: Counting/FIFO task readied preempts caller
tm31 - rtems_semaphore_obtain: Counting/priority not available caller blocks
tm32 - rtems_semaphore_release: Counting/priority task readied preempts caller
tm33 - rtems_semaphore_obtain: Binary/FIFO not available caller blocks
tm34 - rtems_semaphore_release: Binary/FIFO task readied preempts caller
tm35 - rtems_semaphore_obtain: Binary/priority not available caller blocks
tm36 - rtems_semaphore_release: Binary/priority task readied preempts caller
The current implementation of task migration in RTEMS has some
implications with respect to the interrupt latency. It is crucial to
preserve the system invariant that a task can execute on at most one
processor in the system at a time. This is accomplished with a boolean
indicator in the task context. The processor architecture specific
low-level task context switch code will mark that a task context is no
longer executing and waits that the heir context stopped execution
before it restores the heir context and resumes execution of the heir
task. So there is one point in time in which a processor is without a
task. This is essential to avoid cyclic dependencies in case multiple
tasks migrate at once. Otherwise some supervising entity is necessary to
prevent life-locks. Such a global supervisor would lead to scalability
problems so this approach is not used. Currently the thread dispatch is
performed with interrupts disabled. So in case the heir task is
currently executing on another processor then this prolongs the time of
disabled interrupts since one processor has to wait for another
processor to make progress.
It is difficult to avoid this issue with the interrupt latency since
interrupts normally store the context of the interrupted task on its
stack. In case a task is marked as not executing we must not use its
task stack to store such an interrupt context. We cannot use the heir
stack before it stopped execution on another processor. So if we enable
interrupts during this transition we have to provide an alternative task
independent stack for this time frame. This issue needs further
investigation.
