was unnecessary. The real fix was an alignment error in the
object extend memory allocation scheme.
more accurate.
mode at the end of the test. This eliminates the possibility of IO
blocking a task unexpectedly and messing up the test.
or posix initialization threads
from the application code, this file required more visibility than
is given by default to application code.
to avoid conflict with the standard POSIX routine pause(2).
like signal dispatching.
correct Information block.
+ some from Andy Bray (andy@i-cubed.demon.co.uk) which do not include
task start up cost.
+ cases for interrupt disable, enable, and flash
for invocation of _Thread_Handler
