for details.
* tm30/init.c: Make benchmark_barrier_create,
benchmark_barrier_ident, benchmark_barrier_delete static.
PR 1589/build
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am,
tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am,
tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am,
tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am,
tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am,
tm28/Makefile.am, tm29/Makefile.am, tm30/Makefile.am,
tmck/Makefile.am, tmoverhd/Makefile.am: Remove obsolete optional
manager capability.
* tm26/fptest.h: Use PRIu32 to print uint32_t.
* tm26/system.h, tm27/system.h: Ensure these tests use the correct
scheduler.
* tm01/task1.c, tm02/task1.c, tm03/task1.c, tm15/task1.c: Remove
warnings.
PR 1777/cpukit
* support/include/tmacros.h, tmtests/tm26/task1.c,
tmtests/tm27/task1.c: Consolidated access to
_Thread_Dispatch_disable_level.
PR 1743/cpu
* tm26/task1.c, tm27/task1.c: Add Simple Priority Scheduler as
complement to existing Deterministic Priority Scheduler. Modify these
tests to verify the scheduler they are designed to work with is the
default scheduler.
* tm26/task1.c: Update for API change.
* configure.ac: Add AC_CONFIG_HEADER(config.h).
* tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c,
tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c,
tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c,
tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c,
tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tm30/init.c,
tmck/task1.c, tmoverhd/empty.c, tmoverhd/testtask.c: Add HAVE_CONFIG_H.
* tm26/task1.c, tm27/task1.c: Adjust for name changes.
* README: Add initial small set of POSIX Timing Tests.
* tm26/task1.c, tm27/task1.c: Update for API changes.
PR 1647/cpukit
* tm26/task1.c, tm27/task1.c: Update documentation to reflect
refactoring of SuperCore to add Scheduler Handler.
* tm26/task1.c, tm27/task1.c: Do not violate chain API.
PR 1599/cpukit
* tm26/task1.c, tm27/task1.c: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
* Makefile.am, configure.ac: New test for barrier create, ident, and
delete.
* tm30/.cvsignore, tm30/Makefile.am, tm30/init.c, tm30/tm30.doc: New
files.
* tm20/task1.c: Use rtems_test_assert() consistently instead of system
assert(). rtems_test_assert() is designed to integrate into the RTEMS
test suite infrastructure.
* tmoverhd/testtask.c: Apply RTEMS_GCC_NOWARN_USED.
* tmoverhd/dumrtems.h: Rework undef/define cascade.
Add RTEMS_GCC_NOWARN_USED.
* tmoverhd/system.h: Add prototype for Empty_directive();
* tm26/task1.c: Use true/false instead of TRUE/FALSE for "bool"s.
* tm15/task1.c: Make time_set a "bool".
Eliminate TRUE/FALSE.
* tmck/task1.c: Use PRIu32 to print uint32_t's.
* tm05/task1.c, tm18/task1.c, tmoverhd/empty.c,
tmoverhd/system.h: Add missing prototypes.
* tmck/task1.c: Ignore numbers that are too large but keep going -- do
not abort.
* tmck/task1.c: Remove support for "unix".
* tm08/task1.c: Convert calls to legacy routine rtems_clock_get(
RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..).
tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am:
tmoverhd/Makefile.am: Eliminate _exe_/.exe.
* include/timesys.h: Array of task names should be of type rtems_name
not rtems_id.
