RTEMS_TM27 is defined before the bsp.h is included.
too small when OPERATION_COUNT is less than 10.
Addtional major bugs:
<corsepiu@faw.uni-ulm.de>.
to convert the tmtests directory from Makefile.in to Makefile.am.
<corsepiu@faw.uni-ulm.de> which turns OPERATION_COUNT into a configure
time option.
which allow the BSP to override the default number of objects
that will be created in the timing tests. This is useful for
reducing memory consumption on small targets. The BSP_ITERATION_COUNT
can be used to reduce the number of repititions in some of the
tests. This is useful for extremely slow targets (we haven't seen
any slow enough to justify modifying this one yet though. :)
was unnecessary. The real fix was an alignment error in the
object extend memory allocation scheme.
more accurate.
mode at the end of the test. This eliminates the possibility of IO
blocking a task unexpectedly and messing up the test.
or posix initialization threads
from the application code, this file required more visibility than
is given by default to application code.
to avoid conflict with the standard POSIX routine pause(2).
like signal dispatching.
correct Information block.
+ some from Andy Bray (andy@i-cubed.demon.co.uk) which do not include
task start up cost.
+ cases for interrupt disable, enable, and flash
for invocation of _Thread_Handler
