* | api: Remove deprecated Notepads | Aun-Ali Zaidi | 2015-12-24 | 1 | -10/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | Notepads where a feature of RTEMS' tasks that simply functioned in the same way as POSIX keys or threaded local storage (TLS). They were introduced well before per task variables, which are also deprecated, and were barely used in favor of their POSIX alternatives. In addition to their scarce usage, Notepads took up unnecessary memory. For each task: - 16 32-bit integers were allocated. - A total of 64 bytes per task per thread. This is especially critical in low memory and safety-critical applications. They are also defined as uint32_t, and therefore are not guaranteed to hold a pointer. Lastly, they are not portable solutions for SMP and uniprocessor systems, like POSIX keys and TLS. updates #2493. | ||||
* | Enhance Semaphore Blocking and Readying Time Test Cases | Joel Sherrill | 2014-07-14 | 1 | -158/+164 |
| | | | | | | | | | | | | | | | | tm02 and tm03 were modified to be reused for multiple configurations of RTEMS Classic API Semaphores. This added tm31-36. The messages for tm02 and tm03 were modified to indicate the semaphore attributes. tm31 - tm36 were added. This resulted in the following cases: tm02 - rtems_semaphore_obtain: Counting/FIFO not available caller blocks tm03 - rtems_semaphore_release: Counting/FIFO task readied preempts caller tm31 - rtems_semaphore_obtain: Counting/priority not available caller blocks tm32 - rtems_semaphore_release: Counting/priority task readied preempts caller tm33 - rtems_semaphore_obtain: Binary/FIFO not available caller blocks tm34 - rtems_semaphore_release: Binary/FIFO task readied preempts caller tm35 - rtems_semaphore_obtain: Binary/priority not available caller blocks tm36 - rtems_semaphore_release: Binary/priority task readied preempts caller | ||||
* | tmtests_plan.csv: New planning file | Joel Sherrill | 2013-12-07 | 1 | -0/+158 |
