Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
It is getting harder to prevent the compiler from optimizing away the
recursive function calls.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Increment by cache line size to allow more cycles per second.
Rename rtems_smp_get_processor_count() in rtems_get_processor_count().
Make rtems_get_processor_count() a function in uni-processor
configurations to enable ABI compatibility with SMP configurations.
Add a local context structure to the SMP lock API for acquire and
release pairs. This context can be used to store the ISR level and
profiling information. It may be later used to enable more
sophisticated lock algorithms, e.g. MCS locks.
There is only one lock that cannot be used with a local context. This
is the per-CPU lock since here we would have to transfer the local
context through a context switch which is very complicated.
