* | tests: Fix warnings | Sebastian Huber | 2015-03-05 | 1 | -1/+1 |
* | tmtests/tmcontext01: Improve cache dirty function | Sebastian Huber | 2014-09-11 | 1 | -14/+24 |
| | | | | Increment by cache line size to allow more cycles per second. | ||||
* | tmtests/tmcontext01: Improve cache dirty function | Sebastian Huber | 2014-09-08 | 1 | -4/+7 |
* | tmtests/tmcontext01: Plot a legend | Sebastian Huber | 2014-09-05 | 1 | -6/+20 |
* | rtems: Rename rtems_smp_get_processor_count() | Sebastian Huber | 2014-04-11 | 1 | -1/+1 |
| | | | | | | Rename rtems_smp_get_processor_count() in rtems_get_processor_count(). Make rtems_get_processor_count() a function in uni-processor configurations to enable ABI compatibility with SMP configurations. | ||||
* | tmtests/tmcontext01: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -11/+5 |
* | tmtests: convert to test.h | bjorn larsson | 2014-03-25 | 1 | -0/+2 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | score: Add SMP lock profiling support | Sebastian Huber | 2014-03-14 | 1 | -1/+1 |
* | score: Add function to destroy SMP locks | Sebastian Huber | 2014-03-11 | 1 | -1/+3 |
* | score: Add local context to SMP lock API | Sebastian Huber | 2014-03-11 | 1 | -3/+3 |
| | | | | | | | | | | | Add a local context structure to the SMP lock API for acquire and release pairs. This context can be used to store the ISR level and profiling information. It may be later used to enable more sophisticated lock algorithms, e.g. MCS locks. There is only one lock that cannot be used with a local context. This is the per-CPU lock since here we would have to transfer the local context through a context switch which is very complicated. | ||||
* | tmtests/tmcontext01: New test | Sebastian Huber | 2014-02-28 | 5 | -0/+596 |
