path: root/testsuites/tmtests/tmck (follow)
* updated copyright to 1998Joel Sherrill1998-02-173-3/+3
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-083-6/+6
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-223-15/+15
* tests now specify whether they are using rtems initialization tasksJoel Sherrill1996-05-301-0/+2
| | | | or posix initialization threads
* The name of the test support routine pause was changed to rtems_test_pauseJoel Sherrill1996-02-221-1/+1
| | | | to avoid conflict with the standard POSIX routine pause(2).
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-192-2/+2
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-5/+24
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-7/+5
* committing for rtems-3.2.01 snapshotJoel Sherrill1995-07-181-2/+2
* Initial revisionJoel Sherrill1995-05-113-0/+223
