path: root/testsuites/tmtests/tm31 (follow)
* Enhance Semaphore Blocking and Readying Time Test CasesJoel Sherrill2014-07-142-0/+42
tm02 and tm03 were modified to be reused for multiple configurations of RTEMS Classic API Semaphores. This added tm31-36. The messages for tm02 and tm03 were modified to indicate the semaphore attributes. tm31 - tm36 were added. This resulted in the following cases: tm02 - rtems_semaphore_obtain: Counting/FIFO not available caller blocks tm03 - rtems_semaphore_release: Counting/FIFO task readied preempts caller tm31 - rtems_semaphore_obtain: Counting/priority not available caller blocks tm32 - rtems_semaphore_release: Counting/priority task readied preempts caller tm33 - rtems_semaphore_obtain: Binary/FIFO not available caller blocks tm34 - rtems_semaphore_release: Binary/FIFO task readied preempts caller tm35 - rtems_semaphore_obtain: Binary/priority not available caller blocks tm36 - rtems_semaphore_release: Binary/priority task readied preempts caller
