* tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c,
tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c,
tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c,
tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c,
tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c,
tmoverhd/testtask.c: Rename timer driver methods to follow RTEMS
programming conventions.
tmoverhd/testtask.c: Change TEST_INIT to CONFIGURE_INIT. Make
tmacros.h available to all POSIX tests. Add a clock_settime case for
< 1988.
* tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am,
tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am,
tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am,
tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am,
tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am,
tm20/Makefile.am, tm22/Makefile.am, tm23/Makefile.am,
tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am,
tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am,
tmck/Makefile.am, tmoverhd/Makefile.am: Add optional managers to
Makefiles. Clean up test cases so last output line follows END OF
pattern. Make sure test case all run. All tests appeared ok on sis.
* tm02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm15/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm16/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm17/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm18/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm19/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm20/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm21/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm22/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm23/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm24/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm25/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm26/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm27/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm28/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm29/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tmck/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tmoverhd/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* include/timesys.h, tm01/task1.c, tm02/task1.c, tm03/task1.c,
tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c,
tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm20/task1.c,
tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c,
tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Convert to using
c99 fixed size types.
* tm01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* tm02/Makefile.am: Ditto.
* tm03/Makefile.am: Ditto.
* tm04/Makefile.am: Ditto.
* tm05/Makefile.am: Ditto.
* tm06/Makefile.am: Ditto.
* tm07/Makefile.am: Ditto.
* tm08/Makefile.am: Ditto.
* tm09/Makefile.am: Ditto.
* tm10/Makefile.am: Ditto.
* tm11/Makefile.am: Ditto.
* tm12/Makefile.am: Ditto.
* tm13/Makefile.am: Ditto.
* tm14/Makefile.am: Ditto.
* tm15/Makefile.am: Ditto.
* tm16/Makefile.am: Ditto.
* tm17/Makefile.am: Ditto.
* tm18/Makefile.am: Ditto.
* tm19/Makefile.am: Ditto.
* tm20/Makefile.am: Ditto.
* tm21/Makefile.am: Ditto.
* tm22/Makefile.am: Ditto.
* tm23/Makefile.am: Ditto.
* tm24/Makefile.am: Ditto.
* tm25/Makefile.am: Ditto.
* tm26/Makefile.am: Ditto.
* tm27/Makefile.am: Ditto.
* tm28/Makefile.am: Ditto.
* tm29/Makefile.am: Ditto.
* tmck/Makefile.am: Ditto.
* tmoverhd/Makefile.am: Ditto.
* include/Makefile.am: Reformat.
* tm01/Makefile.am: Remove all-local: $(ARCH).
* tm02/Makefile.am: Remove all-local: $(ARCH).
* tm03/Makefile.am: Remove all-local: $(ARCH).
* tm04/Makefile.am: Remove all-local: $(ARCH).
* tm05/Makefile.am: Remove all-local: $(ARCH).
* tm06/Makefile.am: Remove all-local: $(ARCH).
* tm07/Makefile.am: Remove all-local: $(ARCH).
* tm08/Makefile.am: Remove all-local: $(ARCH).
* tm09/Makefile.am: Remove all-local: $(ARCH).
* tm10/Makefile.am: Remove all-local: $(ARCH).
* tm11/Makefile.am: Remove all-local: $(ARCH).
* tm12/Makefile.am: Remove all-local: $(ARCH).
* tm13/Makefile.am: Remove all-local: $(ARCH).
* tm14/Makefile.am: Remove all-local: $(ARCH).
* tm15/Makefile.am: Remove all-local: $(ARCH).
* tm16/Makefile.am: Remove all-local: $(ARCH).
* tm17/Makefile.am: Remove all-local: $(ARCH).
* tm18/Makefile.am: Remove all-local: $(ARCH).
* tm19/Makefile.am: Remove all-local: $(ARCH).
* tm20/Makefile.am: Remove all-local: $(ARCH).
* tm21/Makefile.am: Remove all-local: $(ARCH).
* tm22/Makefile.am: Remove all-local: $(ARCH).
* tm23/Makefile.am: Remove all-local: $(ARCH).
* tm24/Makefile.am: Remove all-local: $(ARCH).
* tm25/Makefile.am: Remove all-local: $(ARCH).
* tm26/Makefile.am: Remove all-local: $(ARCH).
* tm27/Makefile.am: Remove all-local: $(ARCH).
* tm28/Makefile.am: Remove all-local: $(ARCH).
* tm29/Makefile.am: Remove all-local: $(ARCH).
* tmck/Makefile.am: Remove all-local: $(ARCH).
* tmoverhd/Makefile.am: Remove all-local: $(ARCH).
* include/timesys.h, tm01/system.h, tm01/task1.c, tm01/tm01.doc,
tm02/system.h, tm02/task1.c, tm02/tm02.doc, tm03/system.h,
tm03/task1.c, tm03/tm03.doc, tm04/system.h, tm04/task1.c,
tm04/tm04.doc, tm05/system.h, tm05/task1.c, tm05/tm05.doc,
tm06/system.h, tm06/task1.c, tm06/tm06.doc, tm07/system.h,
tm07/task1.c, tm07/tm07.doc, tm08/system.h, tm08/task1.c,
tm08/tm08.doc, tm09/system.h, tm09/task1.c, tm09/tm09.doc,
tm10/system.h, tm10/task1.c, tm10/tm10.doc, tm11/system.h,
tm11/task1.c, tm11/tm11.doc, tm12/system.h, tm12/task1.c,
tm12/tm12.doc, tm13/system.h, tm13/task1.c, tm13/tm13.doc,
tm14/system.h, tm14/task1.c, tm14/tm14.doc, tm15/system.h,
tm15/task1.c, tm15/tm15.doc, tm16/system.h, tm16/task1.c,
tm16/tm16.doc, tm17/system.h, tm17/task1.c, tm17/tm17.doc,
tm18/system.h, tm18/task1.c, tm18/tm18.doc, tm19/system.h,
tm19/task1.c, tm19/tm19.doc, tm20/system.h, tm20/task1.c,
tm20/tm20.doc, tm21/system.h, tm21/task1.c, tm21/tm21.doc,
tm22/system.h, tm22/task1.c, tm22/tm22.doc, tm23/system.h,
tm23/task1.c, tm23/tm23.doc, tm24/system.h, tm24/task1.c,
tm24/tm24.doc, tm25/system.h, tm25/task1.c, tm25/tm25.doc,
tm26/fptest.h, tm26/system.h, tm26/task1.c, tm26/tm26.doc,
tm27/system.h, tm27/task1.c, tm27/tm27.doc, tm28/system.h,
tm28/task1.c, tm28/tm28.doc, tm29/system.h, tm29/task1.c,
tm29/tm29.doc, tmck/system.h, tmck/task1.c, tmck/tmck.doc,
tmoverhd/dumrtems.h, tmoverhd/empty.c, tmoverhd/system.h,
tmoverhd/testtask.c, tmoverhd/tmoverhd.doc: URL for license changed.
tm01/Makefile.am: Reflect having moved automake.
tm02/Makefile.am: Reflect having moved automake.
tm03/Makefile.am: Reflect having moved automake.
tm04/Makefile.am: Reflect having moved automake.
tm05/Makefile.am: Reflect having moved automake.
tm06/Makefile.am: Reflect having moved automake.
tm07/Makefile.am: Reflect having moved automake.
tm08/Makefile.am: Reflect having moved automake.
tm09/Makefile.am: Reflect having moved automake.
tm10/Makefile.am: Reflect having moved automake.
tm11/Makefile.am: Reflect having moved automake.
tm12/Makefile.am: Reflect having moved automake.
tm13/Makefile.am: Reflect having moved automake.
tm14/Makefile.am: Reflect having moved automake.
tm15/Makefile.am: Reflect having moved automake.
tm16/Makefile.am: Reflect having moved automake.
tm17/Makefile.am: Reflect having moved automake.
tm18/Makefile.am: Reflect having moved automake.
tm19/Makefile.am: Reflect having moved automake.
tm20/Makefile.am: Reflect having moved automake.
tm21/Makefile.am: Reflect having moved automake.
tm22/Makefile.am: Reflect having moved automake.
tm23/Makefile.am: Reflect having moved automake.
tm24/Makefile.am: Reflect having moved automake.
tm25/Makefile.am: Reflect having moved automake.
tm26/Makefile.am: Reflect having moved automake.
tm27/Makefile.am: Reflect having moved automake.
tm28/Makefile.am: Reflect having moved automake.
tm29/Makefile.am: Reflect having moved automake.
tmck/Makefile.am: Reflect having moved automake.
tmoverhd/Makefile.am: Reflect having moved automake.
* tm01/Makefile.am: Use $(OBJEXT) instead of .o.
* tm02/Makefile.am: Use $(OBJEXT) instead of .o.
* tm03/Makefile.am: Use $(OBJEXT) instead of .o.
* tm04/Makefile.am: Use $(OBJEXT) instead of .o.
* tm05/Makefile.am: Use $(OBJEXT) instead of .o.
* tm06/Makefile.am: Use $(OBJEXT) instead of .o.
* tm07/Makefile.am: Use $(OBJEXT) instead of .o.
* tm08/Makefile.am: Use $(OBJEXT) instead of .o.
* tm09/Makefile.am: Use $(OBJEXT) instead of .o.
* tm10/Makefile.am: Use $(OBJEXT) instead of .o.
* tm11/Makefile.am: Use $(OBJEXT) instead of .o.
* tm12/Makefile.am: Use $(OBJEXT) instead of .o.
* tm13/Makefile.am: Use $(OBJEXT) instead of .o.
* tm14/Makefile.am: Use $(OBJEXT) instead of .o.
* tm15/Makefile.am: Use $(OBJEXT) instead of .o.
* tm16/Makefile.am: Use $(OBJEXT) instead of .o.
* tm17/Makefile.am: Use $(OBJEXT) instead of .o.
* tm18/Makefile.am: Use $(OBJEXT) instead of .o.
* tm19/Makefile.am: Use $(OBJEXT) instead of .o.
* tm20/Makefile.am: Use $(OBJEXT) instead of .o.
* tm21/Makefile.am: Use $(OBJEXT) instead of .o.
* tm22/Makefile.am: Use $(OBJEXT) instead of .o.
* tm23/Makefile.am: Use $(OBJEXT) instead of .o.
* tm24/Makefile.am: Use $(OBJEXT) instead of .o.
* tm25/Makefile.am: Use $(OBJEXT) instead of .o.
* tm26/Makefile.am: Use $(OBJEXT) instead of .o.
* tm27/Makefile.am: Use $(OBJEXT) instead of .o.
* tm28/Makefile.am: Use $(OBJEXT) instead of .o.
* tm29/Makefile.am: Use $(OBJEXT) instead of .o.
* tmck/Makefile.am: Use $(OBJEXT) instead of .o.
* tmoverhd/Makefile.am: Use $(OBJEXT) instead of .o.
enable this support.
tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c,
tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c,
tm14/task1.c, tm15/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c,
tm19/task1.c, tm20/task1.c, tm21/task1.c, tm22/task1.c, tm23/task1.c,
tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c,
tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Modified.
* tm01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm15/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm16/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm17/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm18/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm19/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm20/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm21/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm22/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm23/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm24/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm25/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm26/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm27/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm28/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm29/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmck/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmoverhd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm27/Makefile.am: include leaf.am instead of leaf.cfg.
* tm26/Makefile.am: include leaf.am instead of leaf.cfg.
* tm24/Makefile.am: include leaf.am instead of leaf.cfg.
* tm16/Makefile.am: include leaf.am instead of leaf.cfg.
* tm18/Makefile.am: include leaf.am instead of leaf.cfg.
* tm02/Makefile.am: include leaf.am instead of leaf.cfg.
* tm10/Makefile.am: include leaf.am instead of leaf.cfg.
* tm11/Makefile.am: include leaf.am instead of leaf.cfg.
* tm15/Makefile.am: include leaf.am instead of leaf.cfg.
* tm19/Makefile.am: include leaf.am instead of leaf.cfg.
* tm04/Makefile.am: include leaf.am instead of leaf.cfg.
* tm17/Makefile.am: include leaf.am instead of leaf.cfg.
* tm28/Makefile.am: include leaf.am instead of leaf.cfg.
* tmck/Makefile.am: include leaf.am instead of leaf.cfg.
* tm08/Makefile.am: include leaf.am instead of leaf.cfg.
* tm12/Makefile.am: include leaf.am instead of leaf.cfg.
* tm03/Makefile.am: include leaf.am instead of leaf.cfg.
* tm13/Makefile.am: include leaf.am instead of leaf.cfg.
* tm29/Makefile.am: include leaf.am instead of leaf.cfg.
* tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg.
* tm20/Makefile.am: include leaf.am instead of leaf.cfg.
* tm09/Makefile.am: include leaf.am instead of leaf.cfg.
* tm01/Makefile.am: include leaf.am instead of leaf.cfg.
* tm21/Makefile.am: include leaf.am instead of leaf.cfg.
* tm07/Makefile.am: include leaf.am instead of leaf.cfg.
* tm25/Makefile.am: include leaf.am instead of leaf.cfg.
* tm22/Makefile.am: include leaf.am instead of leaf.cfg.
* tm06/Makefile.am: include leaf.am instead of leaf.cfg.
* tm05/Makefile.am: include leaf.am instead of leaf.cfg.
* tm14/Makefile.am: include leaf.am instead of leaf.cfg.
* tm23/Makefile.am: include leaf.am instead of leaf.cfg.
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am,
tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am,
tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am,
tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am,
tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am,
tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am,
tmoverhd/Makefile.am: Include compile.am
to convert the tmtests directory from Makefile.in to Makefile.am.
was unnecessary. The real fix was an alignment error in the
object extend memory allocation scheme.
or posix initialization threads
like signal dispatching.
