path: root/testsuites/tmtests/tm27 (follow)
* config: Remove <rtems/btimer.h> includeSebastian Huber2020-03-041-0/+1
| | | | | | | The use of CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER does not define anything, so remove the <rtems/btimer.h> include. Update #3875.
* tests: Use rtems_task_exit()Sebastian Huber2018-10-051-2/+1
| | | | Update #3533.
* testsuite/tmtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-24/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* Remove coverhd.hSebastian Huber2017-11-241-1/+0
| | | | | | | This header file contained timing overhead values which are hard to maintain. Update #3254.
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* score: Prevent assignment to _Thread_ExecutingSebastian Huber2016-11-071-4/+11
* score: Introduce Thread_Scheduler_control::homeSebastian Huber2016-11-021-2/+2
| | | | | | | | Replace Thread_Scheduler_control::control and Thread_Scheduler_control::own_control with new Thread_Scheduler_control::home. Update #2556.
* score: Rename _ISR_Disable_without_giant()Sebastian Huber2016-05-201-2/+2
| | | | | | | | | Rename _ISR_Disable_without_giant() into _ISR_Local_disable(). Rename _ISR_Enable_without_giant() into _ISR_Local_enable(). This is a preparation to remove the Giant lock. Update #2555.
* testsuites: Avoid Giant lockSebastian Huber2016-05-201-2/+2
| | | | | | | | | Replace _Thread_Disable_dispatch() with _Thread_Dispatch_disable(). Replace _Thread_Enable_dispatch() with _Thread_Dispatch_enable(). This is a preparation to remove the Giant lock. Update #2555.
* score: Use thread state lock for current stateSebastian Huber2016-05-121-5/+13
| | | | | | | In addition protect scheduler of thread by thread state lock. Enables use of scheduler per-instance locks. Update #2555.
* tmtests/tm27: Use scheduler lockSebastian Huber2015-06-191-10/+5
* score: Static scheduler configurationSebastian Huber2014-04-151-8/+12
| | | | | | Do not allocate the scheduler control structures from the workspace. This is a preparation step for configuration of clustered/partitioned schedulers on SMP.
* score: Add scheduler control to scheduler opsSebastian Huber2014-04-041-2/+4
| | | | | Scheduler operations must be free of a global scheduler context to enable partitioned/clustered scheduling.
* score: Move priority bit map to scheduler instanceSebastian Huber2014-04-031-6/+5
| | | | | | Delete global variables _Priority_Major_bit_map and _Priority_Bit_map. This makes it possible to use multiple priority scheduler instances for example with clustered/partitioned scheduling on SMP.
* tmtests: convert to test.hbjorn larsson2014-03-251-3/+5
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-213-3/+3
* score: Delete _Thread_Dispatch_set_disable_level()Sebastian Huber2014-03-061-8/+2
| | | | | This function was only used in some tests and can be replaced with other functions.
* tmtests: refactored timesys.h, removed declarationsDaniel Ramirez2013-12-091-0/+2
* tmtests: Make output more uniformJoel Sherrill2013-12-071-7/+7
* smp: Add and use _Assert_Owner_of_giant()Sebastian Huber2013-08-301-2/+2
| | | | | | | | | | | | | | Add and use _ISR_Disable_without_giant() and _ISR_Enable_without_giant() if RTEMS_SMP is defined. On single processor systems the ISR disable/enable was the big hammer which ensured system-wide mutual exclusion. On SMP configurations this no longer works since other processors do not care about disabled interrupts on this processor and continue to execute freely. On SMP in addition to ISR disable/enable an SMP lock must be used. Currently we have only the Giant lock so we can check easily that ISR disable/enable is used only in the right context.
* tmtests/tm27: Fixes for RTEMS_DEBUGSebastian Huber2013-08-011-0/+22
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-114-11/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | PR 1589/build * tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am, tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am, tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am, tm30/Makefile.am, tmck/Makefile.am, tmoverhd/Makefile.am: Remove obsolete optional manager capability.
* 2011-05-09 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-05-091-0/+2
| | | | | * tm26/system.h, tm27/system.h: Ensure these tests use the correct scheduler.
* 2011-04-21 Jennifer Averett <Jennifer.Averett@OARcorp.comJennifer Averett2011-04-211-5/+5
| | | | | | | PR 1777/cpukit * support/include/tmacros.h, tmtests/tm26/task1.c, tmtests/tm27/task1.c: Consolidated access to _Thread_Dispatch_disable_level.
* 2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com>Joel Sherrill2011-03-161-0/+6
| | | | | | | | PR 1743/cpu * tm26/task1.c, tm27/task1.c: Add Simple Priority Scheduler as complement to existing Deterministic Priority Scheduler. Modify these tests to verify the scheduler they are designed to work with is the default scheduler.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* 2011-02-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-02-181-5/+11
| | | | * tm26/task1.c, tm27/task1.c: Adjust for name changes.
* 2010-11-25 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-11-251-2/+2
| | | | * tm26/task1.c, tm27/task1.c: Update for API changes.
* 2010-11-24 Gedare Bloom <giddyup44@yahoo.com>Joel Sherrill2010-11-241-2/+4
| | | | | | PR 1647/cpukit * tm26/task1.c, tm27/task1.c: Update documentation to reflect refactoring of SuperCore to add Scheduler Handler.
* 2010-10-25 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-10-251-2/+2
| | | | * tm26/task1.c, tm27/task1.c: Do not violate chain API.
* 2010-07-30 Gedare Bloom <giddyup44@yahoo.com>Joel Sherrill2010-07-301-2/+2
| | | | | | PR 1599/cpukit * tm26/task1.c, tm27/task1.c: Rename _Context_Switch_necessary to _Thread_Dispatch_necessary to more properly reflect the intent.
* Fix most warnings.Joel Sherrill2009-05-091-2/+2
* Eliminate _exe_/.exe.Ralf Corsepius2009-04-031-7/+7
* 2008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-141-6/+6
| | | | | | | | | | | | | | | * tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c, tm21/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmoverhd/testtask.c: Run all tests successfully with maxixum number of priorities as 16 instead of 256. This was done by temporarily modifying the score priority.h maximum. This allowed testing of all API code to ensure that it worked properly with a reduced number of priorities. Most modifications were to switch from hard-coded maximum to using the API provided methods to determine maximum number of priority levels.
* 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-08-312-15/+16
| | | | | | | | | | | | | | | | | | | | * tm01/Makefile.am, tm01/task1.c, tm02/Makefile.am, tm02/task1.c, tm03/Makefile.am, tm03/task1.c, tm04/Makefile.am, tm04/task1.c, tm05/Makefile.am, tm05/task1.c, tm06/Makefile.am, tm06/task1.c, tm07/Makefile.am, tm07/task1.c, tm08/Makefile.am, tm08/task1.c, tm09/Makefile.am, tm09/task1.c, tm10/Makefile.am, tm10/task1.c, tm11/Makefile.am, tm11/task1.c, tm12/Makefile.am, tm12/task1.c, tm13/Makefile.am, tm13/task1.c, tm14/Makefile.am, tm14/task1.c, tm15/Makefile.am, tm15/task1.c, tm16/Makefile.am, tm16/task1.c, tm17/Makefile.am, tm17/task1.c, tm18/Makefile.am, tm18/task1.c, tm19/Makefile.am, tm19/task1.c, tm20/Makefile.am, tm20/task1.c, tm21/Makefile.am, tm21/task1.c, tm22/Makefile.am, tm22/task1.c, tm23/Makefile.am, tm23/task1.c, tm24/Makefile.am, tm24/task1.c, tm25/Makefile.am, tm25/task1.c, tm26/Makefile.am, tm26/task1.c, tm27/Makefile.am, tm27/task1.c, tm28/Makefile.am, tm28/task1.c, tm29/Makefile.am, tm29/task1.c, tmck/Makefile.am, tmck/task1.c, tmoverhd/Makefile.am, tmoverhd/testtask.c: Eliminate empty function from every benchmark timer driver. Fix spelling.
* 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-08-311-14/+14
| | | | | | | | | | | * tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c, tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Rename timer driver methods to follow RTEMS programming conventions.
* 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-02-011-1/+1
| | | | | | | | | | | | * tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c, tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a clock_settime case for < 1988.
* 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-05-111-1/+1
| | | | | | | | | | | | | | * tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am, tm20/Makefile.am, tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am, tmoverhd/Makefile.am: Add optional managers to Makefiles. Clean up test cases so last output line follows END OF pattern. Make sure test case all run. All tests appeared ok on sis.
* Eliminate scndir, docdir. Use rtems_testsdir instead.Ralf Corsepius2006-07-111-2/+1
* Convert to using *_PROGRAMS.Ralf Corsepius2005-11-131-12/+8
* Rework.Ralf Corsepius2005-11-111-22/+6
* Cosmetics.Ralf Corsepius2005-11-111-3/+0
* Eliminate TEST.Ralf Corsepius2005-11-111-5/+4
* Expand tmtests.am.Ralf Corsepius2005-11-111-1/+13
