Unconditionally make a CONFIGURE_TICKS_PER_TIMESLICE value less than or equal
to zero an error.
Update #4986.
Updates #3053.
Updates #3053.
The use of CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER does not define
anything, so remove the <rtems/btimer.h> include.
Update #3875.
- Add a small memory test config file.
- Update the small memory PowerPC BSPs to use the new test config.
Update #3533.
Update #3382
maintain.
Update #3254.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Use a per-CPU thread dispatch disable level. So instead of one global
thread dispatch disable level we have now one instance per processor.
This is a major performance improvement for SMP. On non-SMP
configurations this may simplifiy the interrupt entry/exit code.
The giant lock is still present, but it is now decoupled from the thread
dispatching in _Thread_Dispatch(), _Thread_Handler(),
_Thread_Restart_self() and the interrupt entry/exit. Access to the
giant lock is now available via _Giant_Acquire() and _Giant_Release().
The giant lock is still implicitly acquired via
_Thread_Dispatch_decrement_disable_level().
The giant lock is only acquired for high-level operations in interrupt
handlers (e.g. release of a semaphore, sending of an event).
As a side-effect this change fixes the lost thread dispatch necessary
indication bug in _Thread_Dispatch().
A per-CPU thread dispatch disable level greatly simplifies the SMP
support for the interrupt entry/exit code since no spin locks have to be
acquired in this area. It is only necessary to get the current
processor index and use this to calculate the address of the own per-CPU
control. This reduces the interrupt latency considerably.
All elements for the interrupt entry/exit code are now part of the
Per_CPU_Control structure: thread dispatch disable level, ISR nest level
and thread dispatch necessary. Nothing else is required (except CPU
port specific stuff like on SPARC).
for details.
PR 1589/build
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am,
tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am,
tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am,
tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am,
tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am,
tm28/Makefile.am, tm29/Makefile.am, tm30/Makefile.am,
tmck/Makefile.am, tmoverhd/Makefile.am: Remove obsolete optional
manager capability.
* tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c,
tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c,
tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm16/task1.c,
tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c, tm21/task1.c,
tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c,
tm28/task1.c, tm29/task1.c, tmoverhd/testtask.c: Run all tests
successfully with maxixum number of priorities as 16 instead of 256.
This was done by temporarily modifying the score priority.h maximum.
This allowed testing of all API code to ensure that it worked
properly with a reduced number of priorities. Most modifications were
to switch from hard-coded maximum to using the API provided methods
to determine maximum number of priority levels.
* tm01/Makefile.am, tm01/task1.c, tm02/Makefile.am, tm02/task1.c,
tm03/Makefile.am, tm03/task1.c, tm04/Makefile.am, tm04/task1.c,
tm05/Makefile.am, tm05/task1.c, tm06/Makefile.am, tm06/task1.c,
tm07/Makefile.am, tm07/task1.c, tm08/Makefile.am, tm08/task1.c,
tm09/Makefile.am, tm09/task1.c, tm10/Makefile.am, tm10/task1.c,
tm11/Makefile.am, tm11/task1.c, tm12/Makefile.am, tm12/task1.c,
tm13/Makefile.am, tm13/task1.c, tm14/Makefile.am, tm14/task1.c,
tm15/Makefile.am, tm15/task1.c, tm16/Makefile.am, tm16/task1.c,
tm17/Makefile.am, tm17/task1.c, tm18/Makefile.am, tm18/task1.c,
tm19/Makefile.am, tm19/task1.c, tm20/Makefile.am, tm20/task1.c,
tm21/Makefile.am, tm21/task1.c, tm22/Makefile.am, tm22/task1.c,
tm23/Makefile.am, tm23/task1.c, tm24/Makefile.am, tm24/task1.c,
tm25/Makefile.am, tm25/task1.c, tm26/Makefile.am, tm26/task1.c,
tm27/Makefile.am, tm27/task1.c, tm28/Makefile.am, tm28/task1.c,
tm29/Makefile.am, tm29/task1.c, tmck/Makefile.am, tmck/task1.c,
tmoverhd/Makefile.am, tmoverhd/testtask.c: Eliminate empty function
from every benchmark timer driver. Fix spelling.
tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c,
tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c,
tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c,
tmoverhd/testtask.c: Rename timer driver methods to follow RTEMS
programming conventions.
tmoverhd/testtask.c: Change TEST_INIT to CONFIGURE_INIT. Make
tmacros.h available to all POSIX tests. Add a clock_settime case for
< 1988.
* tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am,
tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am,
tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am,
tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am,
tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am,
tm20/Makefile.am, tm22/Makefile.am, tm23/Makefile.am,
tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am,
tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am,
tmck/Makefile.am, tmoverhd/Makefile.am: Add optional managers to
Makefiles. Clean up test cases so last output line follows END OF
pattern. Make sure test case all run. All tests appeared ok on sis.
* tm02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm15/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm16/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm17/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm18/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm19/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm20/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm21/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm22/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm23/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm24/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm25/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm26/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm27/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm28/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm29/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tmck/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tmoverhd/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
PR 597/tests
* tm02/system.h, tm03/system.h, tm04/system.h, tm05/system.h,
tm06/system.h, tm07/system.h, tm08/system.h, tm10/system.h,
tm11/system.h, tm12/system.h, tm13/system.h, tm14/system.h,
tm15/system.h, tm16/system.h, tm17/system.h, tm18/system.h,
tm19/system.h, tm21/system.h, tm22/system.h, tm23/system.h,
tm24/system.h, tm25/system.h, tm26/system.h, tm27/system.h,
tm27/task1.c, tm29/system.h: The actual workspace needed by the
tmtests depends on OPERATION_COUNT, but the definitions of
CONFIGURE_MAXIMIM_xxx in the their system.h files do not reflect
this. This results in unnecessary memory exhaustion on small-memory
systems such as the SS555.
* include/timesys.h, tm01/task1.c, tm02/task1.c, tm03/task1.c,
tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c,
tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm20/task1.c,
tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c,
tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Convert to using
c99 fixed size types.
* tm01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* tm02/Makefile.am: Ditto.
* tm03/Makefile.am: Ditto.
* tm04/Makefile.am: Ditto.
* tm05/Makefile.am: Ditto.
* tm06/Makefile.am: Ditto.
* tm07/Makefile.am: Ditto.
* tm08/Makefile.am: Ditto.
* tm09/Makefile.am: Ditto.
* tm10/Makefile.am: Ditto.
* tm11/Makefile.am: Ditto.
* tm12/Makefile.am: Ditto.
* tm13/Makefile.am: Ditto.
* tm14/Makefile.am: Ditto.
* tm15/Makefile.am: Ditto.
* tm16/Makefile.am: Ditto.
* tm17/Makefile.am: Ditto.
* tm18/Makefile.am: Ditto.
* tm19/Makefile.am: Ditto.
* tm20/Makefile.am: Ditto.
* tm21/Makefile.am: Ditto.
* tm22/Makefile.am: Ditto.
* tm23/Makefile.am: Ditto.
* tm24/Makefile.am: Ditto.
* tm25/Makefile.am: Ditto.
* tm26/Makefile.am: Ditto.
* tm27/Makefile.am: Ditto.
* tm28/Makefile.am: Ditto.
* tm29/Makefile.am: Ditto.
* tmck/Makefile.am: Ditto.
* tmoverhd/Makefile.am: Ditto.
* include/Makefile.am: Reformat.
* tm01/Makefile.am: Remove all-local: $(ARCH).
* tm02/Makefile.am: Remove all-local: $(ARCH).
* tm03/Makefile.am: Remove all-local: $(ARCH).
* tm04/Makefile.am: Remove all-local: $(ARCH).
* tm05/Makefile.am: Remove all-local: $(ARCH).
* tm06/Makefile.am: Remove all-local: $(ARCH).
* tm07/Makefile.am: Remove all-local: $(ARCH).
* tm08/Makefile.am: Remove all-local: $(ARCH).
* tm09/Makefile.am: Remove all-local: $(ARCH).
* tm10/Makefile.am: Remove all-local: $(ARCH).
* tm11/Makefile.am: Remove all-local: $(ARCH).
* tm12/Makefile.am: Remove all-local: $(ARCH).
* tm13/Makefile.am: Remove all-local: $(ARCH).
* tm14/Makefile.am: Remove all-local: $(ARCH).
* tm15/Makefile.am: Remove all-local: $(ARCH).
* tm16/Makefile.am: Remove all-local: $(ARCH).
* tm17/Makefile.am: Remove all-local: $(ARCH).
* tm18/Makefile.am: Remove all-local: $(ARCH).
* tm19/Makefile.am: Remove all-local: $(ARCH).
* tm20/Makefile.am: Remove all-local: $(ARCH).
* tm21/Makefile.am: Remove all-local: $(ARCH).
* tm22/Makefile.am: Remove all-local: $(ARCH).
* tm23/Makefile.am: Remove all-local: $(ARCH).
* tm24/Makefile.am: Remove all-local: $(ARCH).
* tm25/Makefile.am: Remove all-local: $(ARCH).
* tm26/Makefile.am: Remove all-local: $(ARCH).
* tm27/Makefile.am: Remove all-local: $(ARCH).
* tm28/Makefile.am: Remove all-local: $(ARCH).
* tm29/Makefile.am: Remove all-local: $(ARCH).
* tmck/Makefile.am: Remove all-local: $(ARCH).
* tmoverhd/Makefile.am: Remove all-local: $(ARCH).
* include/timesys.h, tm01/system.h, tm01/task1.c, tm01/tm01.doc,
tm02/system.h, tm02/task1.c, tm02/tm02.doc, tm03/system.h,
tm03/task1.c, tm03/tm03.doc, tm04/system.h, tm04/task1.c,
tm04/tm04.doc, tm05/system.h, tm05/task1.c, tm05/tm05.doc,
tm06/system.h, tm06/task1.c, tm06/tm06.doc, tm07/system.h,
tm07/task1.c, tm07/tm07.doc, tm08/system.h, tm08/task1.c,
tm08/tm08.doc, tm09/system.h, tm09/task1.c, tm09/tm09.doc,
tm10/system.h, tm10/task1.c, tm10/tm10.doc, tm11/system.h,
tm11/task1.c, tm11/tm11.doc, tm12/system.h, tm12/task1.c,
tm12/tm12.doc, tm13/system.h, tm13/task1.c, tm13/tm13.doc,
tm14/system.h, tm14/task1.c, tm14/tm14.doc, tm15/system.h,
tm15/task1.c, tm15/tm15.doc, tm16/system.h, tm16/task1.c,
tm16/tm16.doc, tm17/system.h, tm17/task1.c, tm17/tm17.doc,
tm18/system.h, tm18/task1.c, tm18/tm18.doc, tm19/system.h,
tm19/task1.c, tm19/tm19.doc, tm20/system.h, tm20/task1.c,
tm20/tm20.doc, tm21/system.h, tm21/task1.c, tm21/tm21.doc,
tm22/system.h, tm22/task1.c, tm22/tm22.doc, tm23/system.h,
tm23/task1.c, tm23/tm23.doc, tm24/system.h, tm24/task1.c,
tm24/tm24.doc, tm25/system.h, tm25/task1.c, tm25/tm25.doc,
tm26/fptest.h, tm26/system.h, tm26/task1.c, tm26/tm26.doc,
tm27/system.h, tm27/task1.c, tm27/tm27.doc, tm28/system.h,
tm28/task1.c, tm28/tm28.doc, tm29/system.h, tm29/task1.c,
tm29/tm29.doc, tmck/system.h, tmck/task1.c, tmck/tmck.doc,
tmoverhd/dumrtems.h, tmoverhd/empty.c, tmoverhd/system.h,
tmoverhd/testtask.c, tmoverhd/tmoverhd.doc: URL for license changed.
